Author Topic: Bike won't turn after flathead start  (Read 1092 times)
Offline Wilskinz
« on: August 10, 2017, 07:09:44 PM »
Hey guys, I have a 76 cb550k I've been starting with a flathead for the past few days(waiting on throttle starter assembly AND kicker spring) and was just messing with the idle and the thing died and now I am getting no response from putting the flathead between to start the bike? What did I do!?
Re: Bike won't turn after flathead start
« Reply #1 on: August 10, 2017, 07:18:44 PM »
 I am guessing you have been starting it off the solenoid maybe ?? Is there any power for light etc. or completely dead. May want to check the main fuse or see if the battery is dead.
Offline Wilskinz
« Reply #2 on: August 10, 2017, 07:23:51 PM »
Yes I've been jumping from the two nuts located under the left side panel. I have power to the lights so I think I burned the starter? It Sparks and I hear a tiny sound like it's about to start turning but don't get anything
« Reply #3 on: August 10, 2017, 07:44:14 PM »
What is a flathead start ? How many volts ?
Offline Wilskinz
« Reply #4 on: August 10, 2017, 07:51:30 PM »
Edit;
Let the bike sit for a bit, went out and tried again and was getting it to turn and getting a response from the throttle but it wouldn't fire up completely and died again. Went to start immediately afterwards and ran into the same "spark and no turn" problem. Am I flooding the bike? What's going on?
« Last Edit: August 10, 2017, 08:08:17 PM by Wilskinz »
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #5 on: August 10, 2017, 08:31:32 PM »
Put the bike in gear and try to roll it.
If you think you flooded it, pull the plugs and try pushin see what happens.
Offline Wilskinz
« Reply #6 on: August 10, 2017, 09:17:46 PM »
Alright gonna have to try in the morning, thanks guys
« Reply #7 on: August 12, 2017, 04:54:05 PM »
The old use a flathead screwdriver to jump the solenoid trick.
Offline Smudgemo
  • Maker of Stuff
« Reply #8 on: August 12, 2017, 08:13:55 PM »
If your starter button is broken, fix it in under an hour: http://forums.sohc4.net/index.php/topic,163170.0.html
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
