Author Topic: My 1ST ever K7 Build with 0% knowledge and 110% determination  (Read 6047 times)
Offline Maverick
Re: My 1ST ever K7 Build with 0% knowledge and 110% determination
« Reply #25 on: October 11, 2017, 08:28:05 PM »
Every thing is looking great! And that black sandy stuff is carbon build up. No fun, but if you carefully clean it and check that your valves seat properly, it should be all right
Offline fiascoelment
« Reply #26 on: October 11, 2017, 08:58:46 PM »
Thanks maverick ! Yeah since this is my first ever build I'm going try to be as thorough as possible here some more closer pictures of the Cylinder walls
Sent from my SM-G935P using Tapatalk
« Reply #27 on: October 11, 2017, 08:59:28 PM »
+misc pictures
« Reply #28 on: October 17, 2017, 04:29:08 PM »
Hi Guys,
Im in need of your help. So I am trying to get the Cylinder Block separated from the case. Anyone know an efficient (non back breaking way) to get this off.
I have read the cotton rope in the cylinder trick, any one want to elaborate on that?
As much as possible I don't want use brute force.
Please let me know.
Thanks,
VT
« Reply #29 on: November 04, 2017, 11:28:38 PM »
I was finally able to separate the block from the case here some pictures of my motor next im going to inspect the pistons and see if they are still good. I am getting closer to disassembling this thing down to the case! Any advice from here on?
Sent from my SM-N950U1 using Tapatalk
« Reply #30 on: November 04, 2017, 11:29:58 PM »
Here are the cylinders, from the who are experienced can you tell the condition from there's pictures?
« Reply #31 on: April 19, 2018, 10:24:53 AM »
Hi guys,
I havent made much progress since I last posted but here I am still standing tall. I followed some of you guys here and got a harbor freight engine stand and fab up brackets to be able to mount them. Please let me know if I can get away with this mount without having the engine fall on me foot . I found it to be a little shaky maybe because of the lack of support on the other half of the engine.
I am now trying to split the case so I can inspect and maybe change the crank bearings, rod bolts and send the case for vapor blasting.
Any other things I should look out for to change or inspect while/when the case is split?
« Reply #32 on: April 19, 2018, 10:27:43 AM »
Can anyone also let me know if this bent on the shifter drum is normal? I noticed this while disassemble the shifter assembly
