Author Topic: cb650 bolt kits  (Read 1664 times)
Offline westhewelder
cb650 bolt kits
« on: August 12, 2017, 08:47:20 PM »
hey guys I'm working on a 79 cb650 and I'm just having a bear of a time trying to find any engine bolt kits or small parts here or there. so the question to you guys out there is there anyone who makes a engine bolt kit? Would it be better to spend a day and my local bolt supply picking and choosing my hardware to make my own kit? for example the head bolts have a shoulder on them is that relevant or does it not matter? i mean I've checked partzilla and to be honest 5$ a bolt is pretty crazy. Can I just go with an allen bolt?
2011 Kawasaki Vulcan 2011
1969 Honda cb750 (project)
Online CycleRanger
  • No comment about being an
Re: cb650 bolt kits
« Reply #1 on: August 12, 2017, 09:00:17 PM »
It may be cheaper to assemble your own kit but it's a hell of a lot easier to just buy a kit.
Here's one example.
http://www.ebay.com/itm/HONDA-1979-1982-CB650-CB650C-CB650SC-SOHC-POLISHED-STAINLESS-ENGINE-BOLT-KIT/311904436631
I would think a 550 kit would mostly work as well.
For carb screws I usually make a list and visit the local bolt store.
Usually the factory parts list indicates size and number of screws required.
Also, use a bit of anti-seize with stainless-into-aluminum.
Re: cb650 bolt kits
« Reply #2 on: August 12, 2017, 09:41:41 PM »
Wheat about the internal bolts for mounting the head to the cylinders? Could I use bolt from a supplier or are they a special bolt?
Sent from my SM-G920W8 using Tapatalk
Online CycleRanger
Re: cb650 bolt kits
« Reply #3 on: August 12, 2017, 09:44:54 PM »
What wrong with your current bolts?
Re: cb650 bolt kits
« Reply #4 on: August 12, 2017, 10:00:33 PM »
Well besides being rusty I'm missing a bunch. Pretty much all the valve to head bolts and missing 2 head to cylinder bolts, the rest are rusty
Online CycleRanger
Re: cb650 bolt kits
« Reply #5 on: August 12, 2017, 10:26:52 PM »
Ah, ok. Well I'd probably get new new internal engine bolts from Honda if they are still available just to be sure.
Re: cb650 bolt kits
« Reply #6 on: August 12, 2017, 10:30:04 PM »
I can get them from partzilla but all the bolts end up 150$ so that's why I was wondering if I could go to a standard bolt of the same dimension.
Online CycleRanger
Re: cb650 bolt kits
« Reply #7 on: August 12, 2017, 10:40:03 PM »
Yikes! you do need a few bolts!
You might make a post in the "Wanted" forum listing the specific bolts you need and see if another forum member can help you out.
Offline calj737
  • I refuse...
Re: cb650 bolt kits
« Reply #8 on: August 13, 2017, 02:39:35 AM »
You can get replacement 8x120 and 8x145 hex 8.8's here:
http://www.allensfasteners.com/search_results.asp?txtsearchParamCat=79
Re: cb650 bolt kits
« Reply #9 on: August 13, 2017, 06:59:45 AM »
Ya we have a store like that here called bolt supply but my question is can I use any grade 5 or grade 8 bolt of internal use
Offline calj737
  • I refuse...
Re: cb650 bolt kits
« Reply #10 on: August 13, 2017, 07:19:47 AM »
I don't see why not. The torque spec isn't beyond the grade strength.
Re: cb650 bolt kits
« Reply #11 on: August 17, 2017, 11:27:45 PM »
Metric fasteners use a different grade number than SAE bolts.  An SAE bolt will have a grade 2,  5 and grade 8, whereas, a Metric has a 8.8 and 10.8 equivalent marking.
A bolt with no hash marks that is SAE would be a Grade 2 bolt.  Three hash marks on the head indicate Grade 5 and 6 hash marks represent a Grade 8 bolt.  Metric fasteners generally have the grade cast on the bolt head .
