Author Topic: CB500K2 Stock Carb Settings  (Read 7938 times)
Offline AndyH
  • My religion:-
  • Pretty well West of Everywhere in Aus!
Re: CB500K2 Stock Carb Settings
« Reply #25 on: October 29, 2017, 02:24:40 AM »
im running 100/40 jets,with 4-1 and stock airbox,bike hauls,i have a fairly long muffler which helps,some are too short to be any good,i broke third gear few months ago and put a spare motor in,used the same carbs no changes,still hauled arse,the air screw in or out guys get too finicky with it,its not a be all and end all,technically each cylinder will require a slightly different setting.
What was your jet needle setting Dave?  I have a similar setup with Keihin 100/40 jets and 4-1 with stock airbox etc. and have set the jet needle to 3rd groove.
1971 CB750K1 (US import)
1972 CB500 Four K1 (SOLD)
Previously owned..
1967 Honda Sports 90
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
« Reply #26 on: October 29, 2017, 02:29:59 AM »
you got me there andy,im sure its the stock setting though?069A carbs,on decell I have a little pop pop pop,not excessive,i can crank the throttle quickly open from say 3500/4000 and it just goes.i run electronic igniton though with just over the stock advance setting,that helps,if you run points you truly aint in the game,too many variables.
Offline AndyH
  • My religion:-
« Reply #27 on: October 29, 2017, 02:41:12 AM »
Ah....I run 627B carbs, I wonder what the difference is with 069A jobs?  I thought 069A were on the 550s... :-\
I also run electronic ign...  Dyna S, and will give some consideration to increasing the adv. a tad!
Thanks for the tip!
« Last Edit: October 29, 2017, 02:47:02 AM by AndyH »
Previously owned..
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
« Reply #28 on: October 29, 2017, 02:59:19 AM »
yeah use a timing light and just go to the far side of the second dash mark,maybe a tad more,use 95 or 98,my engine is a 550,so is my spare,i haven't run a 500 for years,i don't like the clutch and transmissions on em.detail your emulsion tubes,chamfer those air bleed holes,try and use the Honda ones with the staggered size and the extra one on its own.
« Reply #29 on: October 29, 2017, 03:01:17 AM »
heres a brand new pair of keyster slow jets,more like keystone cops?look close at the left one!
Offline AndyH
  • My religion:-
« Reply #30 on: October 29, 2017, 03:09:53 AM »
Fark!!   :o   The aftermarket ones I got from Crusinimage look very close to Keihin, except for the jet needle which has a linear taper.
Previously owned..
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
« Reply #31 on: October 29, 2017, 03:17:25 AM »
I think the Honda taper is more compound?
Offline AndyH
  • My religion:-
« Reply #32 on: October 29, 2017, 03:31:20 AM »
Yep, quite a bit Dave, someone on here posted pics of aftermarket vs genuine but I can't find it...bugger!!  >:(
Previously owned..
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
« Reply #33 on: October 29, 2017, 03:37:29 AM »
hang on to your Honda jet rods!i like Rochester quadrajet spreadbore four barrel carbs,i keep every single part of them!
Offline AndyH
  • My religion:-
« Reply #34 on: October 29, 2017, 03:40:34 AM »
 ;D ;D  Time for tea, cop u later!  ;)
Previously owned..
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
Offline mrmunsell
« Reply #35 on: October 29, 2017, 11:47:35 AM »
I first got this bike running with unrestored carbs borrowed from my other cb500. With these stock setup carbs fitted it ran almost perfect without changing anything despite having a 4 into 1 fitted!
So I sent the original highly corroded carb set that came with the bike to harisuluv to be reconditioned. They came back in pristine condition looking almost brand new.
I started with the original jets (100/40) and needle clips #4 position and initially still had the 4 into 1 with a rather loud muffler fitted. At first the bike would only run properly if it was stone cold - after 30 seconds it would start to blubber like as if the choke was left on full and soon after the plugs would stop firing and when removed, were found to be wet with fuel which had to be dried off to get them to spark again!
I bought second hand 4 into 4 pipes for it one by one hoping that they would make the tuning easier.... but it still took me years to get it to where it is now  :-[
(on my low income I have to save up the money each time before being able to buy new different size genuine jets)
Very interesting.  Do you know what your float height was before the overhaul?  I am wondering if it was higher than the stock spec like mine was (= higher measured float level = lower measured fuel bowl level).
I seem to recall reading some other threads here where someone had experienced that their CB500 was running excessively rich after overhauling the carbs.  Usually, those threads stopped before the problem was resolved.  Starting to wonder if maybe there is some variable at hand related to float heights.  If maybe the spec varied with years and/or markets… causing people going by the 22 mm spec to create this problem in some cases when they 'correct' the float height.
To summarize from my prior posts, I received my bike with ~24 mm float heights, stock jetting, and an aftermarket 4-1 exhaust (rusting out).  And it actually ran okay in the initial 1/4 throttle range.  And then after overhauling the carbs (to include correcting the float heights to 22 mm) and installing a new aftermarket 4-1 exhaust, my bike ran excessively rich in the initial 1/4.
And to save someone having to ask the question: Yes, I set my float height per the shop manual procedure.  Starting with the carbs in the normal upright position, I slowly tilted them forward until the float tang just touched the float needle spring pin, without depressing it.  Then I measured the float height using a dial caliper set to 22 mm - from the carb bowl flange to the highest point on the float pontoon.  I considered the height correct when the caliper just touched the pontoon, without moving / depressing it.  And I did that for both pontoons of each float.  And I actually went through that process twice (once during overhaul, and then a second time when I had the carbs off again later).
First let's check if we all agree on what is a turn out. In my book one turn out is a 360o turn.
In mine as well.  With the air screw seated, I made an alignment mark on the air screw and carb body.  So as I back out the screw, I am 1 turn further out each time it aligns with that mark.  I am typically making adjustments a 1/4 or 1/8 turn at time, over multiple riding sessions / days, etc.  The marks help keep track of where I am and prevent rounding errors from accumulating (so that four consecutive 1/4 turns made at four different times always adds up to one full turn, etc).  A few times along the way, I turned the air screws all the way in, counting the turns, just to confirm I was where I thought I was.
What I hope, is that you haven't turned out the airscrew so far out to achieve a highest rpm at idle. That may be common practice for most motors and will work fine for them, not for ours. I can turn my airscrews out as far as Mrmunsel has and I'll be rewarded with a silky engine that purs like a kitten. But the bike won't accelerate well anymore.
I do understand these bikes are supposed to run rich in the pilot circuit.  I made my adjustments based on feedback from the bike (behavior, performance, and plugs).  Not while idling nor based on idle speed / quality / etc.
Mine was excessively rich with the stock carb configuration - fouling plugs to the point of causing missing in a matter of minutes.  Very blackened plugs.
The bike runs great with the configuration noted in my prior post.  If anything, I suspect the pilot circuit may actually still be richer than necessary with that configuration.  I can open the throttle quickly under any conditions I have tried thus far, and it handles it well (no hesitation, etc).
Since my prior post, I have tried turning the air screws further out.  I wanted to experience what it was like when the pilot circuit was leaner than ideal (not necessarily lean, just not as rich as it should be, etc).  And ultimately, I want to understand if the 2 3/4 setting was best or if there might be an even better setting.  It seemed apparent to me when I had gone too far out.  Cranking open the throttle too much / too fast sometimes results in a hesitation.  Noticed popping on deacceleration more often (was pretty rare at 2 3/4).  This was at 3 1/2 turns out.  I am no carb expert… but it seemed like the bike is telling me it likes the air screws somewhere between 2 3/4 turns and 3 1/2 turns out (with the current jetting, intake, exhaust, etc).  I have started going back the other way now (at 3 1/4 right now, but haven't ridden it yet).  Performance / drivability was great at 2 3/4, but mileage was increasing with them further out… so just trying to find the best compromise between the two.  It could be that 2 3/4 was the best compromise already... but given my inexperience with these bikes - I won't know until I have tried some settings beyond that.
My gas mileage after my carb overhaul was consistently 30-32 MPG US***.  With all air screw settings I tried on the #40s.  Ditto on the #38s.  That didn't start improving until I got to the #35s.  At 2 3/4 turns out on #35s, it was consistently getting 34-36 MPG US.  I had several fill ups with that config.  I don’t have a full tank with the air screws at a consistent position that is further out than 2 3/4 on the #35s.  On my last tank though, I had the air screw at various settings between 3 and 3 1/2 turns out - and it got 38.8 MPG US.  That is the best since the rebuild (prior best was 35.95 MPG at the 2 3/4 turns out).
***Note: That is only counting tanks that included mostly typical riding for me.  For reasons I can only speculate about, my bike actually achieved better mileage early on in the tuning process on tanks that largely did not reflect my typical riding.  Lots of WOT runs and hard acceleration, trying not to stay in the first 1/4 too long to avoid plug fouling, etc.  Far less steady state cruising than typical.  More typical conditions for me would be pretty much the opposite of what I just described.  Lots of time in the first 1/4 throttle, occasional spirited runs, occasional hard acceleration to merge with highway traffic, etc.  I am guessing that because the pilot circuit was so excessively rich at that point, I was actually better off from a fuel economy perspective on tanks where time spent at lower throttle angles was minimized.
Since I had to turn my air screws so far out on #35s to get it running well, I have been considering going to #32 pilot jets.  I was pretty close to ordering some last week, but decided to hold off for now and get some more time on the #35s.  My concern is whether there is any overlap in metering from one available size to the next (in this case, #35 to #32).  For example, if I went to #32s, would there be an air screw position that provides similar metering as my current #35s at ~3 turns out.  If not, then I anticipate the pilot circuit will end up too lean with #32s.  Also, I don’t want to make this small carb orifice any smaller than it truly needs to be.  Plus it is running so well after so many iterations of adjustments, I am hesitant to make any major changes unnecessarily… just enjoying riding it for a little while.
Yes, the air screw settings I reference here are my ‘nominal setting’.  I start by adjusting the carb air screw settings in tandem (1/4 or 1/8 step across all four, repeat as necessary).  Once I get it to a setting that seems good, I start tweaking the cylinders individually based on the plug appearances.  I have consistently found on my bike, #1 and #2 look the same with the same air screw setting.  While #3 needs the air screw slightly further in to achieve similar appearance.  And #4 a little further still.  The exact difference in air screw setting across the cylinders varies (seems to require less difference when the air screws are further in, etc).
« Last Edit: October 29, 2017, 08:11:42 PM by mrmunsell »
Offline mrmunsell
« Reply #36 on: October 29, 2017, 07:19:24 PM »
Update: I got to ride my CB500 about 75 miles today.  I had the air screws 3 1/4 turns out per my earlier post.  It was a beautiful day and it turned out to be a beautiful ride as well.  The bike performed very well.  I did not experience the hesitation I had experienced occasionally at 3 1/2 turns out.  I tried to invoke it intentionally multiple times in various conditions.  Throttle response might have been a little better at 2 3/4 turns out, but I think it is still very good at this setting.  I would have to try both settings back to back to be sure there really is a difference and how much of a difference it is.  I did experience occasional exhaust popping on deceleration.  I had experienced that at 2 3/4 turns out as well, but I only recall it occurring there when transitioning from hard acceleration to closed throttle deceleration.  Now, I also sometimes notice it when transitioning from more moderate acceleration or sometimes even cruising to deceleration.  I do recall the bike did that when I got it.  Anyway, it does not bother me as the popping only occurs occasionally and it is pretty mild and subdued with the new exhaust... unless someone chimes in to tell me this a symptom of a problem (pilot circuit not rich enough, etc).
Also, the bike achieved its best mileage today (in the time I have owned it).  43.9 MPG US.  That tank was mostly rural highway riding… a lot of cruising with with some spirited jaunts and a few WOT runs from a stop or low speed up to highway speed.  The prior 38.8 MPG US tank I mentioned in my last post was a mix of highway and city and included varying air screw settings (3 to 3 1/2 turns out).  I was just turning the screws out a 1/4 turn or so at a few points along the way... trying to find where the pilot circuit started getting ‘not rich enough’.
Not enough time on this 3 1/4 turns out configuration yet to draw any conclusions.  I will run this for awhile and see how it pans out… unless any problem symptoms surface (hesitation, etc).  So that is two variables since my prior 2 3/4 air screw configuration: new air screw position and the change from OEM to K&N air filter.
Jet needle position = 3
Pilot jet size = #35
Main jet size = #105
Air screw position = 3 1/4 turns out*
*Nominal setting. Individual cylinders are then fine tuned as needed to get similar looking plugs across all four cylinders.  For my bike, #1 and #2 end up at this nominal setting and #3 and #4 have to be turned in from there.
Bike config:  About 750 ft above sea level.  CB500K2 (US model w/627B carbs).  About 15K miles.  New Delkevic 4-1 exhaust.  Stock air intake boots and manifold with K&N filter and adapter plate (replaces the stock air filter box).  Dynatek 5 ohm coils.  New OEM points and condensers (Tek).  HondaMan ignition.  Points and valve clearances recently adjusted.  Carbs recently overhauled and synced (bench then vacuum, multiple times along the way).  Keihin needles / jets / air screws.  New OEM float seats / valves from Honda.  Float levels set to 22 mm during overhaul and then further adjusted on the bike to get the fuel bowl levels to 3 mm below the carb bowl flange.  New intake manifold O-rings and boot clamps.
Offline Deltarider
« Reply #37 on: October 30, 2017, 12:53:04 AM »
On popping, a little sidestep if you allow me. Just recently I understood that Hondaman's module does NOT include condensers, so in my view you need the stock condensers to be connected. In my view it's not facultative but mandatory, this to have a reliable ignition at all rpm. But you probably did. To be on the safe side, I'd discharge condensers before I'd connect them to unknown electronic parts.
« Last Edit: October 30, 2017, 06:49:49 AM by Deltarider »
CB500K2-ED Excel black
Offline mrmunsell
« Reply #38 on: October 30, 2017, 06:51:36 AM »
On popping, a little sidestep if you allow me. Just recently I learned that Hondaman's box does NOT have condensers inside, so in my view you need the stock condensers to have connected as they are. It's not facultative but mandatory. But you probably did.
Thanks.  I did indeed leave my condensers connected.  The directions that came with mine had an installation diagram showing the condensers still connected and the installation steps did not call for disconnecting them.  The troubleshooting steps indicated that old leaky condensers can cause timing to run advanced... and they could be disconnected if this is suspected.  And it went on to say that the HM ignition did not require them, but they can help with smoothing timing on older bikes and would be needed if you need to go back to points.  And I had installed new Tek points and condensers by that point... so I did not see any reason to disconnect mine.
