Author Topic: Cam cover tunnel  (Read 1236 times)
Offline Gordo
Cam cover tunnel
« on: August 15, 2017, 01:19:50 PM »
Hi guys doing some work on a project 1976 550f. Its a horror show under the breather cover it has two sections on the exhaust side of the cam sprocket tunnel missing. Is it toast or can it be run like this.
Re: Cam cover tunnel
« Reply #1 on: August 15, 2017, 03:23:34 PM »
Sounds like it got eaten up by the cam chain.
The question is where did the missing metal go? Do you feel lucky?!
« Reply #2 on: August 15, 2017, 04:18:24 PM »
 Have you ever heard it run yet ?
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #3 on: August 15, 2017, 05:26:01 PM »
If you're talking about the lousy holes that get punched in the corners around the sprocket dome, that's normal.
Offline Smudgemo
  • Maker of Stuff
« Reply #4 on: August 15, 2017, 08:37:37 PM »
Yeah, I freaked out when I got my "improved" cover from an ebay seller until I realized it was normal.  Whew.
-Ryan
Thread - How to fix your starter button (for real): http://forums.sohc4.net/index.php/topic,163170.0.html
Offline Gordo
« Reply #5 on: August 15, 2017, 10:24:44 PM »
Cheers sounds like exactly what I'm looking at. Just have to remove the two threaded bars used as studs from under the breather cover. And fit a gasket kit as one of the head pucks is just clean not present.
  • Holy Cow! I'm a
« Reply #6 on: August 15, 2017, 11:56:31 PM »
You really need those pucks to be there
Offline Gordo
« Reply #7 on: August 16, 2017, 12:05:05 AM »
Yep told when I acquired the bike it had a top end rebuild 3000 miles ago. So glad I went in to have a look one of the four bolts under the breather cover not present, two of the others replaced with studs, one puck missing. That's just where I'm at now.
Offline scunny
  • don't call me expert
« Reply #8 on: August 16, 2017, 01:35:54 AM »
While your in there, have a good look around, so you don't get any nasty surprises. these bikes aren't rocket science, one of the PO's took short cuts.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
