Author Topic: Ignition issue  (Read 1056 times)
Offline rotortiller
Ignition issue
« on: August 27, 2017, 05:46:29 AM »
Offline rotortiller
Re: Ignition issue
« Reply #1 on: August 27, 2017, 02:59:53 PM »
 My advice is to seal any non-sealed loose fitting grommet (non molded to wires or sealant free grommet) so water does not easily follow the wires into the unit like a pipe.
RT
« Last Edit: August 27, 2017, 04:22:48 PM by rotortiller »
Offline tlbranth
Re: Ignition issue
« Reply #2 on: August 27, 2017, 08:20:31 PM »
Is that a Hondaman box? If so, I asked him about sealing the grommet and he said it should be left as-is so that moisture could escape. Probably a good plan would be to direct the wires downward from the box though eh?
Don't own a Vanagon
Don't work at Boeing
Life is good
1970 CB750 K0
1975 GL1000
1999 GL1500
Terry
Offline madmtnmotors
  • When did I get to be a
  • Sunny Central Florida
Re: Ignition issue
« Reply #3 on: August 28, 2017, 04:43:01 AM »
Mount the box so the grommet is on the bottom.  8)
Oh yeah, don't park it next to the ocean either!  ;)
TAMTF...
Wilbur
Projects:
Sent from my Tandy TRS-80!
Offline rotortiller
Re: Ignition issue
« Reply #4 on: August 28, 2017, 07:00:57 AM »
LOL it's a design feature!  :P  Guess the unit should have a this side up decal and limited mounting position.
 Most properly designed ignition boxes, electronic regulators  for bikes are potted in epoxy or rubber or at least properly sealed. ECUs, reg/rectifiers etc follow the same practice. This is because engineers understand what moisture can do.
Being fussy I had a hard time fitting the unit where it was away from view and the elements due to wire length and space restrictions. Never occurred to me that water could still get in it where I had it mounted and felt safe. I decided to mount it flat and lengthwise under the seat to the upper battery tray flange lower surface to be accessible by loosening the battery tray by the 3 upper bolts. Even a stock hollow mechanical regulator and fuse panel fare better than this water bowl. LOL.  Hindsight is 20/20 so I should have sealed the grommet and drilled a drain hole at the bottom or potted the inside with a caulking gun using suitable RTV.  I'm sure that would have rectified the situation. The unit did work well until it pooched, even though the stock points ride the same (but will need a bit of cleaning once in a while). There is something fine to be said about the stock ignition reliability and ease of servicing.
Anyway nothing against the product, the intent is to prevent someone else having a similar issue with suspect add-ons.  Maybe over the winter I will troubleshoot and fix the unit.
rt
