Author Topic: 350F Carb clean  (Read 672 times)
Offline Shepusa
350F Carb clean
« on: August 28, 2017, 10:26:12 AM »
1973 350F
When I pulled the bowls off the bottom of the carbs there are no leaf springs on any of them.
What are these used for ? Will it matter if I do not use them ?
Thanks
Simon
Re: 350F Carb clean
« Reply #1 on: August 28, 2017, 11:23:25 AM »
They prevent your main jet and emulsion tube from falling into the bowl.
They are important.
Offline carnivorous chicken
Re: 350F Carb clean
« Reply #2 on: August 28, 2017, 12:52:21 PM »
They are important.
Yep. I worked on a set of 400F carbs where the PO had taken out (or lost?) the springs and remedied it by wrapping wire around the jets and their mounts. I can't say that was the only problem -- drilled out jets, bent floats, no air filter(s), etc. were all there too -- but once rebuilt with proper parts and including the springs the thing ran like a top.
