Author Topic: What’s This Sound??  (Read 1225 times)
Offline t_lilj
What’s This Sound??
« on: August 29, 2017, 09:01:55 AM »
Hey everyone,
I started hearing this metallic sound yesterday. Before the bike had been pretty quiet other than my cam chain. It’s a CB750K3, roughly 1100 miles on a rebuilt engine. I went on a ride on Saturday and it possibly overheated(?), I was on the freeway doing ~75 and it would start slowing down. If I stopped for a minute I could start going again just fine for a couple more minutes and then it’d start slowing again. I haven’t had time to check compression, but on Friday it was ~85 for all 4 cylinders. My thought is maybe my camshaft warped and my valves aren’t opening smoothly, but I’m new at this.
Thanks in advance.
1973 CB750K3 - Rebuild In Progress (2016+)
Re: What’s This Sound??
« Reply #1 on: August 29, 2017, 09:08:15 AM »
sounds like an exhaust leak around #4
« Reply #2 on: August 29, 2017, 09:11:34 AM »
open a tappet cover and make sure oil is splashing around.  everything should be wet in there.
Pull all 4 of your plugs and post a picture showing all of their tips. Line them up L to R, 1234
When was the last time it had a complete 3000mi tuenup?
...also, your fuel is off  ;)
Offline t_lilj
« Reply #3 on: August 29, 2017, 09:15:29 AM »
I’ll check that tonight. The engine only has 1100 miles on it, but I’ve done a everything on a tune up except for valve clearance because I don’t have a 6 point wrench to get the covers off. On my petcock that’s the reserve position, not the off position ;)
« Reply #4 on: August 29, 2017, 09:25:12 AM »
Did you pick out the old exhaust crush washers and put new ones in when your exhaust went back on?
« Reply #5 on: August 29, 2017, 10:01:51 AM »
Or compression leak?
Offline t_lilj
« Reply #6 on: August 29, 2017, 11:05:54 AM »
I didn’t have the tools/know how to rebuild the engine, so I aid someone else to do it last fall (regrets there), so I can’t say about the exhaust washers. Also it has been burning some oil, is there a special tool to do a leak test?
« Reply #7 on: August 29, 2017, 11:42:31 AM »
eliminate the exhaust gasket possibility, first.
Offline disco
« Reply #8 on: August 29, 2017, 03:40:59 PM »
Sounds like your valves are in need of adjustment. You can hear the metallic hammering.
1976 CB750 K6 Sapphire Blue
1972 CB750 K2 Candy Red
1972 CB750 K2 Candy Gold'
