Author Topic: allen size  (Read 1198 times)
dwebber
allen size
« on: June 03, 2005, 05:15:28 PM »
I need the allen wrench size for the hex caliper bolts in a 1974 CB750K2
Offline Tim.
  • www.DOTHETON.com
    • DO THE TON
Re: allen size
« Reply #1 on: June 03, 2005, 05:23:25 PM »
Ok, so two posts, and the same question twice.
Are you asking what size hex-head to use in a bolt on your bike?  These bikes didn't have hex-head bolts on them originally.  Probably 6mm if it's a larger bolt, but it could be 7 or 8mm as well.  Smaller hex-head bolts for the engine cases tend to all be 5mm.
Beyond that - seriously, get out your wrenches and figure it out.
Roule comme dans les annĂ©es 70...   Roll as in the Seventies...
Online Terry in Australia
Re: allen size
« Reply #2 on: June 03, 2005, 05:30:29 PM »
Tintin, the "Doc" is asking what size allen head bolt "Hex Key" to use on a a CB750K2 caliper, to seperate the two halves. The OEM bolts are of the "Allen head" (internal hex) variety. The answer is 8mm. Cheers, Terry. 8)
