Author Topic: Push/pull throttle cable replace  (Read 764 times)
Offline nolanwells
« on: September 08, 2017, 06:49:41 PM »
Hi folks,
I'm oh-so-close to replacing the push and pull throttle cables (on my '73 cb350f) but I'm not able to get the ends attached to both the throttle grip and the bell crank at the same time–there isn't enough length. Is there an order of operations or a tip/trick that anyone could recommend? Thank you!
Offline el pachuco
Re: Push/pull throttle cable replace
« Reply #1 on: September 17, 2017, 11:51:13 PM »
first install the cable ends to the throttle tube and close the housing up with the bolts. then drop down to the carbs and install the ends there.
