Author Topic: cam sprocket wear and other related questions  (Read 547 times)
Offline ts354
« on: September 08, 2017, 08:05:05 PM »
Took the head of my 550 off and was inspecting the cam sprocket.  It went like this; good tooth, good tooth, good tooth, really worn tooth, good tooth, really worn, good, good..... and so on.  What makes the uneven wear of the sprocket?  As far as I can tell the chain looks great.
Is the drive sprocket on the crank shaft made out of the same stuff or is it a little stronger/harder?
So, in doing a freshen up of the top end, I was thinking about a hotter cam.  In changing the cam, the rockers have to be treated, new sprocket, and a new chain.
How strong is the bottom end?  Would I have to have new bearings?  Rods? Pins? Pistons?
I really don't know much about these engines.  Any help my way would greatly be appreciated.  Anybody like me can buy parts (when they have the money) but the bigger picture questions I struggle with.  Ones like; How much wear is too much wear?  If you replace this part, what other parts depend on it and need replaced?  etc..etc..
I know, lots of questions, so let's just start with this, What causes uneven wear of the cam sprocket?  Is it a bigger issue causing it?
Re: cam sprocket wear and other related questions
« Reply #1 on: September 08, 2017, 08:51:03 PM »
None of it matters ,if its a Bobber or Brat bike....
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: September 08, 2017, 09:10:19 PM »
Hard to say on the worn cam sprocket.    Check the links of the chain, maybe some were damaged.  Or was the machine stored in the elements for a long while?
The simplest cam upgrade is a stock sohc cb650 part swap.  Made my bike a little more exciting to ride.  No other changes required.
Either way you have to split the cases to change the cam chain.  Might as well order yourself a new primary chain, cam tensioner bow, cam chain guide.
No one can tell you if you'll need crank bearings until you're into it.  The tech manuals have measurement specs.
Offline ts354
« Reply #3 on: September 08, 2017, 11:41:26 PM »
754  -  hahaha, you caught that.
