Author Topic: How to rebuild my brakes... like a boss?  (Read 7754 times)
Offline ilikepinkcrayons
  • Extra medium newb
  • I pedal bike too.
Re: How to rebuild my brakes... like a boss?
« Reply #25 on: September 14, 2017, 08:26:13 AM »
I'm just kidding guys. Just to make a point. Even with the terrifying possibilities of soaking aluminum in a dangerous concoction of boiling hydrogen hydroxide, hydroxilic acid, and dihydrogen monoxide, I'm pretty damn confident there will be no issues.
I've read a handful of horror stories of people struggling to free their stuck pistons or pull their circlips. My MC looked and felt like someone used epoxy instead of brake fluid, then stored it in salt water for the past 10 years. After boiling it in water, dissolving some of the rust off with vinegar, and soaking the circlip in penetrating oil for a grand total of about 30 minutes, disassembly was a breeze with almost no cursing, swearing, or wishing I was dead.
It took a total of 3.5 hours of soak time, plus another hour of hands on time (including water changes, rinsing, finding a tool that will work to get the circlip out, complete disassembly, and a preliminary cleaning of the bore). This just makes sense to me. It could have been luck too. Or aliens.
1968 MGB
1975 CB550K
1981 Volvo 244 GLT
  • Extra medium newb
  • I pedal bike too.
« Reply #26 on: September 19, 2017, 09:27:08 AM »
I'm finally placing an order for the diaphram and plate, plus some crush washers, and I've got a few questions:
1. After looking at this diagram from Western Honda, I noticed that I also don't have the bushing, #31. I'll pick one up, but what is that thing? I can't tell what it does.
2. It seems like I've got to put some serious pressure in the system before my brake light turns on. Is there a more sensitive switch out there that I can use? It's installed in the stock location.
3. Is there anything else I should pick-up that isn't exactly an obvious one to grab, but should probably be replaced?
1968 MGB
1975 CB550K
1981 Volvo 244 GLT
« Reply #27 on: September 19, 2017, 01:42:39 PM »
1. It's a bushing and it's purpose is a good question.
2. Not that I know of. Have not heard of that issue before...
3. Brake pads?
« Reply #28 on: September 19, 2017, 08:16:26 PM »
It's a rubber baby bumper, Steve. ;) It's a cushion for the brake lever when released. My K1 MC had one, but not my K7 MC; it didn't have the hole where it would have gone.
Offline CycleRanger
  • No comment about being an
« Reply #29 on: September 19, 2017, 08:24:12 PM »
The first time I rebuilt a master cylinder I actually bought that part from Honda.  ::)
Every one after that I just use a piece of rubber tubing.
Offline m00ntan
« Reply #30 on: September 20, 2017, 04:54:45 AM »
Any help on that brake stop switch? From what I read, my switch is corroded from switching to DOT 5 and new switch shouldn’t have a compatibility issue.
CB750K4
CB550K1
CM400C
« Reply #31 on: September 26, 2017, 04:56:14 AM »
Regarding the stop switch
The trick is to determine the pressure level that triggers the switch, many old cars used the fluid pressure switches. Even Volvo 240s made from '75-'93 used them. My '66 Volvo used them. Not sure if the '00 Ford does...imagine it might.
I believe that a few places who cater to those replacing lines with braided will move the switch to the caliper area because of the line change eliminating that junction block in the stock system that has the brake pressure switch.  It is likely triggered at something like 5PSI....but can withstand hundreds of psi in pressure.
Check 4 into 1 to see if they have them, maybe call them...
Cognito Moto, Dime City Cycles, etc.
David
  • Extra medium newb
  • I pedal bike too.
« Reply #32 on: September 28, 2017, 12:59:43 AM »
The trick is to determine the pressure level that triggers the switch, many old cars used the fluid pressure switches. Even Volvo 240s made from '75-'93 used them. My '66 Volvo used them. Not sure if the '00 Ford does...imagine it might...
What do you mean by "the trick is to..."? The problem I have is that at the pressures I typically use to slow down at stop lights is actually less than the pressure required to turn the light on. This means I'm slowing down (albeit slowly), without the light going on. Bad news. The only time it comes on is if I really jerk on it (did she say that?). Also, I'm pretty sure my '81 Volvo 244 GLT has a switch at the brake pedal. I'm not 100% sure, but as I recall from the last time was a rolling around underneath the dash, it's got a little switch resting against the brake pedal arm.
Side note: Since I'm out of town on business and I can't work on the bike, I figured I'd just read forum pages, and I found this thread in the tips and tricks about people's DIY snap ring pliers. It's so hilarious. I love you guys!
« Last Edit: September 28, 2017, 01:02:02 AM by ilikepinkcrayons »
1968 MGB
1975 CB550K
1981 Volvo 244 GLT
  • Extra medium newb
  • I pedal bike too.
« Reply #33 on: November 15, 2017, 02:49:24 PM »
I'm finally back to working on the bike! I got everything disassembled, cleaned and honed the internals, then powder coated everything myself. I used a "0-10%" matte black. Just pulled them out of the oven, removed the thread/hole plugs and masking tape, and BAHM! I love them!
There's a bit of pitting on the surfaces, and I wish I spent more time sanding the casting marks and stuff off. After sand blasting, the texture hid some of the imperfections of the metal, but now that there's a uniform finish, the flaws kinda pop out.
The goal is to eventually have matte black lowers, dual matte black calipers, and super shiny hardware and fasteners, so that's why these are matte black.
1968 MGB
1975 CB550K
1981 Volvo 244 GLT
« Reply #34 on: November 15, 2017, 04:00:11 PM »
BAM!  Nice job...
  • Extra medium newb
  • I pedal bike too.
« Reply #35 on: November 16, 2017, 08:27:27 AM »
Good tip. Thanks. That could be why mine have been squealing so badly!
1968 MGB
1975 CB550K
1981 Volvo 244 GLT
Offline DV Red Herring
  • Army RETIRED
« Reply #36 on: November 17, 2017, 10:45:08 PM »
Boiling the MC...
  • Extra medium newb
  • I pedal bike too.
« Reply #37 on: November 21, 2017, 12:47:58 PM »
Boiling the MC...
Don't hate, girl. Don't hate, get down...
1968 MGB
1975 CB550K
1981 Volvo 244 GLT
