Hondaman and I have a difference of opinion regarding the idle screws on the earlier, non PD carbs.
I did exhaust analyzer testing of a 74 CB550, that clearly indicated that the air screws on those carbs made the mixture richer when turned inward. Further, when I turned those air screws outward for leanest exhaust gas readings (ended up being 6 to 8 turns), the off idle engine response was dismal to non-existent, even though it idled beautifully. Certainly un-rideable as I just couldn't get the engine to rev up with the bike in any gear.
Gradually and incrementally turning the air screws inward eventually restored the throttle twist problem until it was street acceptable. The Exhaust gas analyzer once again indicated it was rather rich during idle operation. And, surprise surprise, my stock configured bike exhaust and intake ran best at Honda recommended air screw setting. Who'da?
Hondaman explained the exhaust gas analyzer was being fooled, and the bike was getting too rich to accelerate. My tuning experience just doesn't support this.
Too rich bikes blubber going in and out of too-rich-to-support-combustion mixtures. Too lean mixtures have a fine border edge of tune where they either fire or don't. Nothing to "clean up" when going in an out of combustion range, no blubber/no burble. The Cb550 example had a throttle that acted more like a switch. On idle it ran fine, off idle under load it didn't, like the coils were turned on and off and on. No blubber, no burble to me means not a too rich indication. I simply can't believe my exhaust gas analyser was being fooled, as engine behavior matched indications.
Finally, Honda's own tech article explains, inward rich and outward leaner for air screws... Which Hondaman also says is wrong.
Therefore, as a result of my findings, I have to disagree with Hondaman's assertion, and maintain that turning air screws outward leans the idle mix and turning them inward makes the idle mix richer. Of course the Idle Mixture Screws (IMS) found on PD carbs work the opposite way.
I can infer that since the CB750 Carbs have the same physical pilot/idle circuit arrangement as those found on the CB550, they would function in the same way as the Cb550 early carbs. But, I have no early model 750 carbs to characterize. If there is some subtlety about 750 carbs I'm unaware of, well believe what you wish. But, I don't see any sort of venturi in the pilot circuit, the air screws meter the amount of air available to mix with pilot jet output, and regulate the pressure presented to the pilot jet output. Opening the screw reduces the pressure in the pilot circuit, making it closer to outside atmospheric pressure, which equates to less fuel draw from the jet orifice while simultaneously providing more air. This makes for leaner pilot circuit delivery. Closing off the air screw, allows less air availability for mixing with the jet output, while simultaneously allowing the low pressure source (the carb throat) to exert more draw on the pilot jet exit. E.G. the mixture gets richer.
Pity there is controversy about this.
