Author Topic: CB750 F2 Restoration - Engine and frame paint help  (Read 5746 times)
Offline Vin750
« on: September 12, 2017, 08:36:50 AM »
Hi All,
I am restoring my F2 which I bought from the first owner a couple of years ago.
I am having a hard time matching the black paint for the engine, frame, calipers, forks and so on. It seems that people have no consensus on what type of black to use. I have been told many times to use satin but satin is not even close to the black used for the engine and frame.
It seems the black used by Honda is a lower gloss but still glossy black.
Does anyone know what paint I can use to replicate the original black on the engine, frame, calipers and so on?
And were there more types of black or are they all the same black?
Any help would be much appreciated.
Thanks
Offline nvr2old
Re: CB750 F2 Restoration - Engine and frame paint help
« Reply #1 on: September 12, 2017, 09:07:03 AM »
VHT in my opinion makes a satin black engine enamel that is very close to factory.  So does DupliColor, but it's not as gas resistant.  I would go with powder coating for the frame.  SO much easier then prepping it for paint.  But if you do paint the frame go with a single stage urethane.  It's about as good/durable as you can get with paint.  There are special caliper paints also available in spray cans that work really well, too.
'76 CB550F-'72 XL250-'82 MB5-'82 CX500 Turbo-'77 naked Goldwing-'75 CB400F cafe'-'79 Suzuki GS1000S..hey, it's a Wes Cooley..
« Reply #2 on: September 12, 2017, 09:32:28 AM »
+1
Its all in the prep.  I spend countless hours with paint stripper, wire wheel, and acetone.  then baked the finished product.....but gas spills and drips do nothing to it.
« Last Edit: September 12, 2017, 10:04:45 AM by flybox1 »
« Reply #3 on: September 12, 2017, 09:45:00 AM »
3 parties do not a picture make.
 :D
« Reply #4 on: September 12, 2017, 09:47:19 AM »
« Reply #5 on: September 12, 2017, 09:56:06 AM »
They view fine on my end  ;D
http://forums.sohc4.net/index.php/topic,168102.0.html
Old ipad IOS 5.1.1
No hope there.  Just pb advertising propagation for me.
« Reply #6 on: September 12, 2017, 10:06:12 AM »
Sorry TT.  Thought the fix might work for everyone.
...attached original pics  ;D
« Reply #7 on: September 12, 2017, 10:21:32 AM »
Purty .
I've got three of those to do when time allows.
Offline Jnel
« Reply #8 on: September 12, 2017, 11:03:21 AM »
This is a VHT job.  It's saposed to be heat and fuel resistance.  We'll see about that.
Sent from my SAMSUNG-SM-N930A using Tapatalk
« Last Edit: September 12, 2017, 11:09:43 AM by Jnel »
Offline CycleRanger
  • No comment about being an
« Reply #9 on: September 12, 2017, 11:53:38 AM »
+1
I too am a fan of VHT.  I use it without primer and have been happy with the results.
Offline Jnel
« Reply #10 on: September 12, 2017, 11:58:59 AM »
+1
Offline Vin750
« Reply #11 on: September 13, 2017, 05:30:08 AM »
I haven't used the satin enamel but have used vht case paint satin which I  is epoxy and it is way too far from the original black of the engine which has a gloss to it.
Offline Vin750
« Reply #12 on: September 13, 2017, 05:36:24 AM »
+1
What paint did you use on the black engine?
« Last Edit: September 13, 2017, 05:39:10 AM by Vin750 »
Offline Vin750
« Reply #13 on: September 13, 2017, 05:38:03 AM »
What's the black you used for the cylinders? It looks like what I need.
Offline Bankerdanny
  • Endeavor to persevere
« Reply #14 on: September 13, 2017, 06:00:29 AM »
Harbour Freight sells a satin black frame paint that I used on my project bike and to touch up my rider. I am really happy with how it looks.
Offline ilikepinkcrayons
  • Extra medium newb
  • I pedal bike too.
« Reply #15 on: September 13, 2017, 08:53:11 AM »
Is the VHT engine enamel resistant to brake cleaner? I wash my dog, clean the dishes, gargle, etc. with brake clean, and would want the paint to stand up to it...
1968 MGB
1975 CB550K
1981 Volvo 244 GLT
Offline CycleRanger
« Reply #16 on: September 13, 2017, 09:41:37 AM »
Nope.
Offline Jnel
« Reply #17 on: September 13, 2017, 11:46:19 AM »
It's BIT gloss black.  Hi temp.
Offline Jnel
« Reply #18 on: September 13, 2017, 11:48:20 AM »
What's the black you used for the cylinders? It looks like what I need....
This is VHT gloss black.  High temp.
« Reply #19 on: September 13, 2017, 12:12:34 PM »
Unless the paint is self catalysing, like a two part epoxy, an out gassing paint gets harder and more resistant to solvents the longer it has to outgas (dry).  Think months.
But, there is usually some chemical that will attack any paint.
Personally, I think your brake kleen resistant paints will have to be 2 part epoxy types, which have uv sensitivities.
I also find such demands for brake kleen resistance a bit unrealistic, as they can change their formulation on a whim.  Kinda why they offer it by brand name, rather than chemical name.
Offline Vin750
« Reply #20 on: September 20, 2017, 05:43:25 PM »
Here is my attempt at matching the original sheen of black on the F2 engine.
From left to right:
- Dupli-color low gloss engine enamel
- VHT satin black calliper paint
- VHT gloss black calliper paint
- VHT case paint which supposedly is satin but looks matte
The original F2 engine paint looks thick and has a dull gloss to it but it's not satin. It's the same paint used on the callipers.
Offline kap384@telus.net
« Reply #21 on: September 21, 2017, 01:38:17 PM »
Able to try the high gloss VHT as a test?  I had the same challenge when I repainted my engine.  Mine is too satin currently.  Curious how the high gloss VHT engine paint compares.
« Last Edit: October 05, 2017, 06:03:36 PM by kap384 »
1965 Honda CB450K0
1972 Honda CT70K1
1975 Honda MR50
1975 Honda CB400F Supersport
1977 Honda CB750F2 Supersport
1978 Honda XL100
1979 Honda CBX Supersport
1982 Honda VF750S Sabre - Adventure Bike modified
1983 Honda CX650T
1995 Honda VFR750
2016 Honda CRF1000L Africa Twin
2015 KTM 200 XC-W
1963 Suzuki T10
My 1977 CB750F restoration - http://forums.sohc4.net/index.php?topic=66779.0
My 1975 CB400F restoration -
http://forums.sohc4.net/index.php?topic=145196.msg1651779#msg1651779
'More Stock Than Not' thread - http://forums.sohc4.net/index.php?topic=90807.500
My CT70 Resurrection - http://forums.sohc4.net/index.php?topic=145221.0
Best Motorcycle Tool Ever - https://www.engduro.com
Offline Jnel
« Reply #22 on: September 21, 2017, 02:19:39 PM »
VHT BLACK GLOSS. VHT  on the valve cover too.
Offline Vin750
« Reply #23 on: October 05, 2017, 11:45:43 AM »
The gloss will be way too high gloss for my engine.
Offline Jnel
« Reply #24 on: October 05, 2017, 12:40:52 PM »
Ok... good.  In the end we have to be happy.  I've done some thing in an effort to expedite a project and have regretted it.  So i agree, if its not right... Don't do it.  Keep us updated on the results.  🤙
John
Sent from my SAMSUNG-SM-G935A using Tapatalk
