SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
SOHC/4 Bikes
Topic:
Is this hole for a bolt or a bleeder?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Is this hole for a bolt or a bleeder? (Read 1336 times)
JBCB500
Enthusiast
Really enjoying this!
on:
September 19, 2017, 01:16:55 pm »
Is the hole in the top of the front brakes manifold (shown) for a bleed screw or a bolt?
Just now there is a bolt in mine. I am attempting to bleed the brakes and I have good pressure at the lever but nothing is coming from the calipers. I suspect this should not be a bolt and that the bolt is blocking the flow of fluid???
CB750 with dual front calipers.
Logged
Scott S
Global Moderator
Really Old Timer ...
Re: Is this hole for a bolt or a bleeder?
Reply #1 on:
September 19, 2017, 04:13:19 pm »
The hole(s) on either side of your thumb are for bolts. They attach the splitter to the the lower triple tree. The other threaded hole, across from your thumb nail, is for the brake light pressure switch. The banjo bolts go in the top and bottom.
Logged
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
JBCB500
Enthusiast
Reply #2 on:
September 19, 2017, 04:25:03 pm »
Thanks Scott, I forgot all about the pressure switch as mine is one the MC. Turned out the splitter was crudded up and blocked. The bolt was correct as a delete for the switch. I replaced the cruddy splitter with a good one and managed to bleed both brakes in about 20 minutes - all good now!
Thanks for the advice as always!
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
SOHC/4 Bikes
Topic:
