Author Topic: 550F Seat Pan Painting  (Read 621 times)
Offline Ace Blackwell
  • 1977 CB550F - Resurrection in progress
« on: September 22, 2017, 12:56:05 PM »
All,
I recently bought a seat on EBay. Not bad shape for the $.  The pan has some minor surface rust. I am going to sand rust and repaint. Any suggestions on...
- paint ( just black or some sort of ecoat in a can?)
- sand grit ( or should I spray with some sort of biting primer first?)
Thanks
Ace
1977 CB550F Work in Progress
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: 550F Seat Pan Painting
« Reply #1 on: September 22, 2017, 01:44:07 PM »
Stock seat or custom?
« Reply #2 on: September 22, 2017, 01:48:45 PM »
Stock 550F seat 1977
  • Holy Cow! I'm a
« Reply #3 on: September 22, 2017, 02:49:56 PM »
So after you've got the rust ground down.  1st coat use a rust inhibiting primer.  Let dry, sand smooth up to 400.  Spray gloss black and be done.  Go ride
« Reply #4 on: September 22, 2017, 02:57:06 PM »
Paint will need a cure time to either catalyze or outgass its solvent carriers.
If you apply foam or covering fabric too soon, it will adhere using the paint as a glue.
Two part paints need a week, as a rule. Aerosol spray cans  need a month to harden.
« Reply #5 on: September 23, 2017, 11:12:24 AM »
Thanks all. Getting started today.  No rush the bike isn't driveable yet anyways.  Mainly bought the seat so that the bike looks a little more complete. When rubbing and scrubbing you start feeling like you will never be done. Was looking for some motovation.
Ace
