Author Topic: 42a from a 80-81 750f carbs on a 77 750a  (Read 1798 times)
Offline Ryeguy9191
« on: September 23, 2017, 10:42:23 PM »
Im curious if a set of 42A round top carbs from what I believe is an 1980-81 will work on my 750a.
My current carbs are kinda ruined. Came that way. Brackets are bent between 1 and 2, as well as carb and throttle rods.
I found a set of free carbs, just need a rebuild and a diaphragm. But before I order a rebuild kit, I'd like to know if theyd match up. They fit on my current boots to the engine, but not to the air box
Offline kmb69
Re: 42a from a 80-81 750f carbs on a 77 750a
« Reply #1 on: September 24, 2017, 06:45:50 AM »
Can be done and the CV carbs work nicely on an Automatic.
Offline Ryeguy9191
« Reply #2 on: September 24, 2017, 09:43:43 AM »
Ok. Then I shall order a rebuild kit with diaphragms.
Any idea on what style throttle cables I need? The 1977 cables dont exactly match up.
« Reply #3 on: October 23, 2017, 09:06:42 PM »
 I'd guess the cables the carbs were born with, maybe the throttle tube too.
