Author Topic: Any wiring specialist ? electrical break down CB 750 K2  (Read 5748 times)
Offline aminemed
« on: September 25, 2017, 02:25:15 PM »
Hi
I installed (or at least tried) to install the m flash from motogadget as per the instructions in the attached picture, for a CB 750K2: m flash red wire should wire with bike 12v and m flash black wire should be wired with bike ground, but I did it wrongly. Instead I hooked bike black wire with m flash black wire (supposed to be wired with ground) and bike gray wire (turn signal main) with m flash red wire (supposed to be wired with +12v wire) then....boom! No more lights, no more electrical start at all in the bike even when I removed the m flah and went back to my original wiring scheme with my old flasher. Any thoughts on what happened ? (i changed the fuse) Now only thing i get is that engine turns over (i can hear it), but there is no ignition.
« Last Edit: September 26, 2017, 04:34:00 AM by aminemed »
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: No more lights
« Reply #1 on: September 25, 2017, 03:15:47 PM »
i couldn't tell you but one thing i did notice.  english isn't the instruction author's first language.  no offense to those who's first language is not english.
cb750 k6 - ugly
Offline 540nova
Re: No more lights
« Reply #2 on: September 25, 2017, 03:48:12 PM »
It's from Germany. The M-unit instructions are somewhat lacking in clarity.
Sent from my SM-G955U using Tapatalk
Offline Phinn
  • Subversive
Re: No more lights
« Reply #3 on: September 25, 2017, 04:12:47 PM »
The solution is to learn German and read the instructions as originally written. Alles klar!
1978 CB750K -- "Mouse," a former basket case, resurrected
Offline Mr. Mike
Re: No more lights
« Reply #4 on: September 25, 2017, 09:46:30 PM »
I'm no electronic wizard, but this is my observation;
I don't understand your "black to black" hook up as black on the bike is 12v right?. This unit appears to be in series (or inline) with the grey wire. Sounds like you might've  put 12v to the negative side of the unit for a direct short.
I'm thinking it should look like this;
[flasher relay]-grey--><MFred---[MFUnit]---MFBlk><---grey----->>>>turn signal swx.
Anyone have anything else to offer?
2002 Electra Glide
1978 750K
1966 CL77 (sold)
2020 CB500X
Offline aminemed
Re: Any wiring specialist ? electrical break down CB 750 K2
« Reply #5 on: September 26, 2017, 02:50:07 AM »
That's what I did. After my mistake, i connected the black +12v bike wire with m flash red wire and then turn signal main gray wire with m flash black wire but i got no electrical signal at all. I then went with my old flash relay and connected wires as they used to be, again, no luck, no electrical signal at all. I don't know what's going on. What is wrong !
Offline AndyH
  • My religion:-
  • Pretty well West of Everywhere in Aus!
« Reply #6 on: September 26, 2017, 03:09:58 AM »
Did you check the fuse(s)?
1971 CB750K1 (US import)
1972 CB500 Four K1 (SOLD)
Previously owned..
1967 Honda Sports 90
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
Offline aminemed
« Reply #7 on: September 26, 2017, 03:11:56 AM »
Yes, changed the fuse for a new one...very weird :s :s
no lights at all in the bike. Engine turns over when i hit the starter, but can't get an ignition. I guess that keeping on trying will drain the battery.
« Last Edit: September 26, 2017, 03:37:34 AM by aminemed »
Offline Bodi
« Reply #8 on: September 26, 2017, 05:16:26 AM »
Probably the surge made a dodgy connection or switch contact fail. You need to follow voltage through the harness and find where it stops. Corrosion and wear take a toll on connectors and switches.
Offline aminemed
« Reply #9 on: September 26, 2017, 05:35:58 AM »
Is a multimeter ok for that ? To follow voltage ?
Offline Mr. Mike
« Reply #10 on: September 26, 2017, 06:48:47 AM »
Yes a multimeter is exactly what you need, along with the electrical print for the bike.
And a good stroke of luck to find your point of trouble.
Although your first post is not the original, the end is the same. Dig into this forum on "how to check a selenium rectifier".
« Last Edit: September 26, 2017, 07:05:46 AM by Mr. Mike »
2002 Electra Glide
1978 750K
1966 CL77 (sold)
2020 CB500X
Offline aminemed
« Reply #11 on: September 26, 2017, 08:19:52 AM »
Let's suppose i was able to find out the failed contact, how can i fix it ?
And by the way, now that i did this big mistake, what should be the wiring of the M FLASH according to the instructions ?
Gray (turn signal main) with black and +12V black wire with M FLASH red ?
Thank you
« Last Edit: September 26, 2017, 08:46:35 AM by aminemed »
Offline aminemed
« Reply #12 on: September 26, 2017, 02:20:07 PM »
Please help ! I bought a multimeter but don't know what to do exactly...what a mess ! Can't believe that this wrong wiring is causing all that
Offline aminemed
« Reply #13 on: September 26, 2017, 02:29:25 PM »
Stock except for the combined rectifier/regulator i've installed
Offline 540nova
« Reply #14 on: September 26, 2017, 03:53:55 PM »
Calj737 will sort you out. Be confident in what he says, he's the Motogadget guru.
Offline aminemed
« Reply #15 on: September 27, 2017, 06:34:43 AM »
I will run all these tests when i get back home. But just for my knowledge, can a wrong polarity damage a battery ? I mean in my old flash relay (picture), i was plugging the black wire and the gray wire at the same time. Didn't have room for green ground wire. Thanks for your explanations
Offline aminemed
« Reply #16 on: September 27, 2017, 02:24:52 PM »
Ok so i run through tests:
battery = ok ! 13 volts +
fuse continuity = ok
voltage across fuse box = ok
Turned key on, still no lights.
checked black & white going to engine coils = ok, showing same voltage as battery.
Still no start of engine. As said before, can hear it turning over, but no ignition.
Then what i did is tested both black and gray wires that i plugged in the M Flash, so black = ok (voltage = battery), but gray wire is not giving any good output. Guess it might be the issue. How can i be sure and how can i fix it eventually ? Thank you
Offline Bodi
« Reply #17 on: September 27, 2017, 03:40:17 PM »
Inexplicably, I thought about this while driving home just now.
Nothing you could do by connecting any flasher to just black and gray could possibly cause the issues you are describing. Either you're leaving some things out of the story, or the failure happening just when you connected the M-Flash is a coincidence.
That assumes the harness hasn't been ravaged by a PO or has damage that cross connects wires.
Depending on what lamps you have in the signals, reversing the connection might damage the M-flash module if you try the signals that way.
And yes, the M-flash module should connect with red-black and black-gray. But stop worrying about it: it isn't the problem, and didn't cause the problem.
Offline aminemed
« Reply #18 on: September 27, 2017, 11:27:29 PM »
yes very weird then. I remember that before installing the m flash I turned the key to on and tested my lights, all ok. Then replaced the old flasher with the m flash and turned key on and total black out, you know the story. By the way when looking at the diagram I think that gray wire if not connected to a flasher would show no voltage at all so that's why my gray wire was nit displaying anything on the meter
And just to be sure on how to measure with the meter (we never know) meter black with battery black and meter red with the wire to be tested, right ?
Lastly, can I check my headlight lamp for example with my battery to see if I have lights, maybe all my lamps are gone
« Last Edit: September 27, 2017, 11:31:18 PM by aminemed »
Offline aminemed
« Reply #19 on: September 28, 2017, 03:31:52 PM »
I'm definitely going to give up on this motorcycle..I'm spending 2 hours at least every night trying to figure out what's going on with a wife yelling at me because I spend too much time doing what I do. Anyways, things are getting worst, I don't have anymore Power. At least until yesterday engine was turning over without ignition, now, all no more power at all. Pressing the switch does not do anything. Anyways..don't know what I'll discover tomorrow..
Offline 540nova
« Reply #20 on: September 28, 2017, 03:41:06 PM »
Where are you located? Maybe someone on here is nearby, and can lend a hand. Don't give up, if anything, just walk away for a while, and come back fresh, and start from the beginning. It CAN be fixed!
« Reply #21 on: September 28, 2017, 07:33:41 PM »
If you connected the Motogadget backward, it may have destroyed the Motogadget itself. Electronic devices do not usually survive reverse-polarity power.
Offline aminemed
« Reply #22 on: September 29, 2017, 01:16:26 AM »
funny thing is that i spent so much time on this wiring harness and wiring diagram that now i know by heart every wire in the diagram..!
Offline aminemed
« Reply #23 on: September 29, 2017, 01:03:04 PM »
stock harness but had to rewire when i painted the frame.
But I'm getting closer I believe: I cleaned the the fuse box a bit so the engine cranked again a little..Now when I put the key in ignition 2 (turn key twice) brake light is on...but only brake light !!
Offline magnum56
« Reply #24 on: September 29, 2017, 01:17:24 PM »
Second position is "park" I believe.  (only turns on some lights) First position from OFF is the normal run position.
Have you tried looking at the interactive wiring diagram ...
http://oldmanhonda.com/MC/wiring.html
You can disable sections of the diagram not involved with what you are trying to research.
I know it helped me focus on just the aspects of the diagram I was interested in.
'74 CB750K
