Author Topic: What is the point Car Question.  (Read 2358 times)
« on: September 28, 2017, 06:58:29 PM »
 Saw an ODDie today,  really wide rims, too wide for the tire, plus the lowest profile tire I have ever seen..
 255 30   size .. what a wasted I think a pothole could take out a rim.
 I doubt there was 2 inches of rubber past the rim.
Offline eigenvector
Re: What is the point Car Question.
« Reply #1 on: September 28, 2017, 07:07:52 PM »
See plenty of those in Seattle.
No different than low-rider trucks, those bouncy air-shock cars (whatever they're called)
Just for showing off.
I've seen one guy at my work who has axle blades - stick out about 4" from the hub.  Don't know if they're sharp - but they are metal.
Rob
2018 HD Softail Heritage
1979 CB750K Limited Edition
1977 CB550K
1984 CB700SC Nighthawk
1983 VF750S Sabre
« Reply #2 on: September 28, 2017, 08:07:28 PM »
 The tire is also usually smaller in diameter than the rim.
Offline jgger
« Reply #3 on: September 28, 2017, 08:17:00 PM »
Standard low rider crap. I have seen this with the A-arm suspension relaxed all the way and the wheels lean toward each other at the top about 5 to 10 degrees. If it is in front of me on the freeway I usually pass them so I don't catch any flying parts. Tires probably last 5 to 10K miles at best.
Offline Steve F
« Reply #4 on: September 29, 2017, 04:33:30 AM »
Can you imagine RIDING in a car like that for 5 to 10K miles?  Dang.
Offline Bailgang
  • Scott
  • Indiana
« Reply #5 on: September 29, 2017, 04:38:27 PM »
I remember as a kid when your car wasn't cool unless it had a set of Gabriel HiJacker air shocks pumped way up with a set of 50's tires on the rear, more points if they were mounted on Cragar's or aluminum slots.
Scott
71 cb350 twin
77 cb750 F2
83 gl1100 Interstate
Offline dusterdude
« Reply #6 on: September 29, 2017, 05:04:32 PM »
Hell yea!!!!
Sent from my R1 HD using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #7 on: September 29, 2017, 05:21:09 PM »
Car culture is an ever evolving thing.
Unfortunately, this so-called "stanced" look that frank described.  Was developed by "tuners" who never paid attention in high school geometry, or physics.
« Reply #8 on: September 29, 2017, 05:22:53 PM »
Dude, that's not a tire ......  that is an O ring..
  • Holy Cow! I'm a
« Reply #9 on: September 29, 2017, 05:40:38 PM »
I certainly hope that none of the future "auto customizers" fall under the delusion that "less tire on the ground" is improving the drivability of their cars.
There a beacon on the horizon.  A few car guys are in on it, as a joke.
Offline my name is nobody
  • I like Pontiacs and Hondas
« Reply #10 on: September 29, 2017, 07:41:59 PM »
The guys who slam them into the weeds w/lowering springs used to come to me and want them aligned.
They don't understand why the thing eats front tires. They also don't understand what bump steer is. (I sure do)
It's amazing to actually watch the camber change happen when your along side one. And the fireworks
that happen after dark on a road with dips.. Lowering spindles are a must IMO if you want to lower a vehicle.
I've done a few s-10s and they turned out almost like they were factory. Availability is somewhat of an issue
tho, as drop spindles aren't made for every kind of vehicle. More to look cool than anything else. There are benefits if you do it right for better handling. Some of the junk out there is downright scary to drive.
Offline MikeSimon
  • MotoManiac
  • Motorcycle Addict
« Reply #11 on: September 30, 2017, 04:12:57 AM »
I have two cars that came from the factory with 35 profile tires 8) Nothing wrong with it. I run a slightly higher pressure in them (42PSI).
Yes, ride is not particularly comfortable, but neither car is supposed to be a "long distance touring sedan". Handling is superb.
1973 CB350F -sold
1974 CB350F -218 orig miles, sold
1976 CB750K - in restoration
Other Hondas:
3 x CBX
CB1100R
GB500
Plus Kawasakis, BMws & Ducatis
« Reply #12 on: September 30, 2017, 04:48:22 AM »
Yes I can remember getting pulled over in my hot rod Roadrunner around 1980 and after the cop peeked inside to see what was going on he had me walk to the back of the car with him while he pulled out a tape measure to see if my back bumper was too high.Didn't get a ticket but was told to drop her down a little.  Man those were the days,cheap muscle cars everywhere.
« Reply #13 on: September 30, 2017, 10:18:51 AM »
not exactly sure what us old guys are #$%*ing about at this point...I think a few here need to google the word DONK...or are we talking about tuner car mods...or just #$%*ing about these new fangled tire trends in general
Offline J-Rod10
« Reply #14 on: September 30, 2017, 10:56:24 AM »
You can't stance a car without adding some camber.
Offline Desert-SOHC
  • It's old
« Reply #15 on: September 30, 2017, 11:15:03 AM »
The "stretched" tire look is also dangerous, its very easy to pop a bead at speed that way, I've watched it happen.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
« Reply #16 on: September 30, 2017, 12:03:19 PM »
Mike - my 370Z has [stock] 275/35's on it, that is not what they are talking about.
The car Frank saw had REAL wide rims with narrower tires - I dont like that look either.
Kinda like this...
  • Holy Cow! I'm a
« Reply #17 on: September 30, 2017, 12:21:45 PM »
I thought we were talking about these pieces of uniquely urban ungenuity
Offline eigenvector
« Reply #18 on: September 30, 2017, 01:17:56 PM »
+1 for the stupid oversized air spoiler on the front wheel drive car.
The only thing it's missing is brat style handlebars!  ;D
Rob
1977 CB550K
1983 VF750S Sabre
« Reply #19 on: October 01, 2017, 01:24:37 AM »
Geez those were the days mate, I had Gabriel Hijackers just to level out my (Aussie built) Valiant VIP, it was a bit saggy in the rear end! ;D
