hi
I have a few questions which i can't find answers to, they might seem a bit random but I have a pile of bits that I am turning into a bike
1, would you favour (sorry about the spelling I'm British) early or late -accelerator pump-carbs
2, what is the offset on k7 fork yokes - I am using a Kawasaki z1r front end which has thicker forks and brakes from a gpz1100 and I want to make the steering geometry more or less stock. Incidentally a gpz1100 rear wheel fits an f2 swinging arm with minimal machining of spacers and sprocket carrier and gives you a 2.5" rim even the brake torque arm lines up
3, is there going to be any noticeable performance difference running k6 pistons with a k7 head (this is what is in the motor i have been stripping) the bores are fine and all I really want to do is fit new rings given that I have done the whole bottom end and gearbox and even the primary cush drive rubbers this has already got expensive enough and pistons aren't cheap
4, is an f2 cam re timed to k spec going to give a noticeable performance improvement over the k7 cam
5, have you noticed any adverse effects on handling after making the frame tubes removable with any of the kits that are available
I'm only trying to build a daily rider but i want to get it as good as I can first time so that I don't have to do it twice
