Author Topic: Having trouble re-threading throttle cables to throttle tube...  (Read 1887 times)
Offline 1977_cb550k
« on: October 08, 2017, 04:08:30 AM »
Hi - I decided to flip and lower my stock handlebars on my CB550k, and although I'm completely green at any modifications, everything seemed to go OK....until it came time to re-fit my throttle cables onto the throttle tube. I can get one cable back in the tube easily enough, but the tighter cable is a bastard and I just can't get it back on?! I was using needle-nose pliers to help, but it's too tight to work the cable end back into the slot.
Any tips or tricks to this? Any help appreciated.
Thanks - Jason.
1977 CB550k3
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: Having trouble re-threading throttle cables to throttle tube...
« Reply #1 on: October 08, 2017, 05:59:54 AM »
need a longer cable?
cb750 k6 - ugly
Offline RandomOrbit
« Reply #2 on: October 08, 2017, 07:08:56 AM »
Are you mixing up the push and pull cables? They have different ends, and each will only fit in it's correct hole.
CB750k6 owned since 1991
Offline robvangulik
  • Honda Fourever
« Reply #3 on: October 08, 2017, 10:25:57 AM »
Did you loosen the ends at the carb side? You should!   ;D
Offline 1977_cb550k
« Reply #4 on: October 08, 2017, 02:07:27 PM »
Hi Rob, no I didn't loosen the cables at the carbs. Is that tricky? Will that mean rebalancing the carbs?
1977 CB550k3
Offline robvangulik
  • Honda Fourever
« Reply #5 on: October 08, 2017, 02:11:08 PM »
No, just loosening 3 m6 nuts and disconnect the cables, carbs can be left where they are.
Offline 1977_cb550k
« Reply #6 on: October 08, 2017, 02:16:16 PM »
Thanks,  I'll give it a go. I assume I need to remove the tank etc?
1977 CB550k3
« Reply #7 on: October 08, 2017, 03:00:09 PM »
Hi - I decided to flip and lower my stock handlebars on my CB550k...
Now why would you want to do that?   I could understand changing bars but flipped over stock bars sounds goofy.
« Reply #8 on: October 08, 2017, 03:58:11 PM »
Not goofy, straight up retarded...dude perfectly good handlebars cost about $40, in any bend you want
Offline 1977_cb550k
« Reply #9 on: October 08, 2017, 07:45:53 PM »
Yeah, sounds weird, but I just wanted to get a feel for what Clubmans or clip-ons might feel like as you can't "try before you buy" with handlebars. Also, I just wanted to get some experience changing the gear and learning how it is put together etc.
1977 CB550k3
Offline Gene
  • Chat enuf you too can be a
« Reply #10 on: October 09, 2017, 04:31:40 PM »
Without rearsets upside-down handlebars are just going to be uncomfortable, and possibly dangerous. Be careful.
*1973 CB750K3 (Bow)
Offline 1977_cb550k
« Reply #11 on: October 09, 2017, 11:49:56 PM »
Yep, thanks Gene - I probably won't ride with them that way - just learning and playing around with position etc.
1977 CB550k3
« Reply #12 on: October 10, 2017, 06:40:23 AM »
BTW - to change handle bars, the throttle cables do not need to be disconnected. The entire R control can just slide off after the bars are loosened and moved over.
Offline 1977_cb550k
« Reply #13 on: October 11, 2017, 02:18:22 PM »
Thanks steve, I mistakenly took the controls off first. But won't do that again!
1977 CB550k3
« Reply #14 on: October 11, 2017, 02:32:57 PM »
Thanks steve
Sure...happy to help.   Do you want "racer" bars?  They are very uncomfortable!   Superbike bars are excellant, I have them on a couple of my bikes...
http://www.ebay.com/itm/Emgo-Universal-Chrome-Clubman-Handlebars-7-8-23-12538-Motorcycle-bars-824639-/231144432040?epid=171212066&hash=item35d14821a8:g:6ysAAOSwaNBUj0J4&vxp=mtr
http://www.ebay.com/itm/Emgo-Street-Handlebars-H-Bar-7-8-Superbike-Blk-Black-23-12571-0601-2618-824662-/331114933185?epid=171240704&hash=item4d17fcebc1:g:SQ4AAOSwr7ZW3lo8
Keep in mind that with lower bars, especially clubmans, your cables [clutch and throttle] and brake line will be too long and need to be replaced
« Reply #15 on: October 11, 2017, 04:44:33 PM »
After around 1975  orcso...fixed it for you.
« Reply #16 on: October 11, 2017, 05:06:08 PM »
True but only if the bikes wiring is in the handlebars.  His is not.  ('77 model)
Offline 1977_cb550k
« Reply #17 on: October 12, 2017, 02:22:02 PM »
Thanks stev-o,
I quite like the look of these bars:
https://www.ebay.com.au/i/232081404187
Keen to hear any experience with this shape and style. Comfortable?
1977 CB550k3
« Reply #18 on: October 12, 2017, 04:19:40 PM »
those are an excellent choice
« Reply #19 on: October 23, 2017, 02:37:45 PM »
+1.  Do you plan to run your wiring within the bars?
Offline 1977_cb550k
« Reply #20 on: October 24, 2017, 07:10:40 PM »
Maybe. It looks neater. What are the pros and cons. I'm guessing it's harder to wire thru the bars.
My current setup is externally wired.
1977 CB550k3
« Reply #21 on: October 25, 2017, 08:19:50 AM »
Pro: cleaner install
Con: pain in ass to install
Personally, I dont do it.  You still have a clutch cable on left and a brake line on the right, I typically just neatly zip tie the wiring to them and it looks neat.
Offline evinrude7
  • not a kung-fu
« Reply #22 on: October 25, 2017, 07:34:29 PM »
it took me 15 minutes to run my wires inside the bars.  spray silicone and electrical tape if you need it.  these were bars with about a 5 inch rise.
cb750 k6 - ugly
