Author Topic: 1980 cb 650 82 650 custom engine  (Read 604 times)
Offline Tcainthompspn
« on: October 10, 2017, 05:35:04 AM »
Ok so I have a 80 cb650 I got a good deal on a new engine 82 custom at the time I didn't know enough about them the 82 has a different head and carbs so I put my 80 carbs on the 82 custom engine got it running rode to town 6to8 miles and started losing power soon as I pulled into town pow it locked up the engine I assume I got it home took off the side plate and turned it loose till the engine would start with the  starter agin this time it ran fine in the driveway about 15 mins then the big pow engine seized again I know they had different heads and carbs I'm trying to get it bake on the road is the possible the carbs are doing this maybe put the head off my other 650 engine on there just wanted other opinions
Sent from my SAMSUNG-SGH-I337 using Tapatalk
Offline Scott S
Re: 1980 cb 650 82 650 custom engine
« Reply #1 on: October 10, 2017, 05:58:17 AM »
 Holy Run On Sentence, Batman!
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline calj737
  • I refuse...
« Reply #2 on: October 10, 2017, 06:22:28 AM »
The wrong carbs won’t seize an engine in any way I can think of. If you can, try to be descriptive (maybe with some proper grammatical structure too  ;) )about exactly what “pow” means and what “locked up” means. The motor won’t rotate, or won’t fire, or won’t catch?
Offline DaveBarbier
« Reply #3 on: October 10, 2017, 06:34:05 AM »
Use these for your next reply
