Author Topic: Wiring  (Read 3842 times)
Offline Cb55076
Re: Wiring
« Reply #25 on: October 11, 2017, 10:39:33 AM »
Yes thanks but i dont have that
Offline Bankerdanny
  • Endeavor to persevere
Re: Wiring
« Reply #26 on: October 11, 2017, 10:57:47 AM »
OK. You need to take and post some pictures for us so that we can see what you are seeing. It is possible whoever you bought from replaced the box with something else, but we are flying blind here without pictures.
If you have a smart phone you can easily take pictures and upload them directly from your phone using whatever browser you have or you can download the Tapatalk app that works with the forum and upload with that.
Offline Cb55076
Re: Wiring
« Reply #27 on: October 11, 2017, 11:25:33 AM »
Yes i will send you a photo in an hour or so, keep an eye out thanks.
Offline Cb55076
Re: Wiring
« Reply #28 on: October 11, 2017, 12:06:59 PM »
Heres a lil older one
Offline Cb55076
Re: Wiring
« Reply #29 on: October 11, 2017, 12:07:40 PM »
They should be under the seat, under the triangular body panel. That’s where your stock “electrics” are
Offline Cb55076
Re: Wiring
« Reply #30 on: October 11, 2017, 12:08:34 PM »
In the pic you cant see a fuse box, i will send u a closer front and back by battery pic
Offline Bankerdanny
Re: Wiring
« Reply #31 on: October 11, 2017, 12:19:58 PM »
OK. That vertical bracket with the 2 holes in it is where the fuse box should be mounted. The prior owner either relocated the box or replaced it with something else. You are going to have to do some detective work.
Follow the red wire in your picture with the fuse holder built in. It is very possible that the prior owner replaced the entire fuse box with that single fuse.
Offline Cb55076
Re: Wiring
« Reply #32 on: October 11, 2017, 12:45:29 PM »
Oh ok
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
Re: Wiring
« Reply #33 on: October 11, 2017, 01:10:25 PM »
There are two threads on this?
Offline Cb55076
Re: Wiring
« Reply #34 on: October 11, 2017, 01:32:46 PM »
Lol yes first with wiring as learning but now trying to hire someone to come help
  • Holy Cow! I'm a
Re: Wiring
« Reply #35 on: October 11, 2017, 02:18:33 PM »
Okay, though one thread would help us help you better.
Seems the other thread turned a bit sour, so staying here is a safe bet.
Might want to take up mj on his offer for skype tech assist.  As I mentioned these things are as straightforward as they come.  Even with the apparent hacking that has gone on with your bike, its nothng too unusual.
Offline Cb55076
Re: Wiring
« Reply #36 on: October 11, 2017, 02:46:23 PM »
Understand
