Author Topic: 1975 CB400F VIN plate info  (Read 1044 times)
Offline Flyin900
« on: October 13, 2017, 09:50:39 PM »
« Last Edit: October 14, 2017, 09:37:23 PM by Flyin900 »
1978 CB550K - Super Sport
1982 CM450A - Hondamatic
1982 CB900C - Custom
1983 CX650E - Eurosport
Offline FuZZie
Re: 1975 CB400F VIN plate info
« Reply #1 on: October 14, 2017, 03:40:49 AM »
You need to match the bikes area code to.
"Exclusive parts for each area" in the honda cb400f oem parts list is showing enough differences to be out a few pounds. ;)
also A and CM should match up well.
Offline Bodi
« Reply #2 on: October 15, 2017, 08:36:44 AM »
I looked at my 76. There's a GVWR, and front/rear axle weights... all show the max rated load with all up, GWVR is over 700 lb and the rear over 400. I got called away before I could write down the numbers, and a pic wouldn't work because a lot of wires and stuff go over the plate. If it would be useful I can get these numbers for you.
Offline FuZZie
« Reply #3 on: October 15, 2017, 04:12:11 PM »
Your numbers should be a match bodi hey both would be f1 bodies and cm country code, mine is the 77 f2 cm.
I have all the factory manuals but I can't find any info to verify the ratings are the same for all the models.
