Author Topic: Carburettor insulator F2 and K7  (Read 1784 times)
Offline Vin750
« on: October 14, 2017, 07:58:16 AM »
Does anyone know if the carburettor insulators of K7 and F2 are the same? They look the same but the part numbers are different m.
The airbox top part is the same from what I can tell and the length of the carburettors is the same as far as I can tell.
Sent from my iPhone using Tapatalk Pro
Re: Carburettor insulator F2 and K7
« Reply #1 on: October 14, 2017, 09:56:07 AM »
One end is larger on the F2/F3 (head end??)
Offline Vin750
« Reply #2 on: October 15, 2017, 10:37:53 AM »
You are correct, tried today it’s loose. Will get the K7 ones.
Offline martin99
  • UK Based, Non-
  • Adventure before Dementia
« Reply #3 on: October 16, 2017, 02:15:42 PM »
I have K7 insulators on my F2. The difference is in the length, diameters are the same (K ones are slightly shorter). Part no. 410 denotes F2, 405 denotes K7.
Interchangeable if you’re running pods or some other bolt-on air box derivative, but not so if you use the standard intake system. Must be subtle difference in the frame/air box mounting points I reckon.
Build threads:
1977 CB750 F2
1958 Norton Model 99
Offline Vin750
« Reply #4 on: November 11, 2017, 06:42:52 PM »
Does anyone know where I can buy cheap aftermarket insulators for the K7
Offline dusterdude
« Reply #5 on: November 12, 2017, 02:43:42 PM »
Vintagecb750.com 100 bucks.best ive found
Sent from my R1 HD using Tapatalk
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
