Author Topic: Exploded diagram of a 78 cb550k starter motor.  (Read 2581 times)
Re: Exploded diagram of a 78 cb550k starter motor.
« Reply #25 on: October 15, 2017, 09:21:05 PM »
Thank you for all of your help!
You're Welcome
Reward us all with a success story!
Offline gbal06
« Reply #26 on: October 15, 2017, 09:45:04 PM »
Will do! You
Offline gbal06
« Reply #27 on: October 17, 2017, 02:07:20 PM »
TwoTired
Once back together and I touch the cable to the positive of a battery it should spin correct? Because it isn’t 😭
« Reply #28 on: October 17, 2017, 05:47:17 PM »
Um, you know you need two connections, right? The motor case to batt neg, and the big cable to batt pos.
Offline gbal06
« Reply #29 on: October 17, 2017, 06:15:53 PM »
So I just realized that a bike is usually a neg ground so the motor grounds to bike which completes the circuit  :o  ya I am kinda slow
Offline gbal06
« Reply #30 on: October 17, 2017, 06:19:10 PM »
Also does any one have the two long screws I think they are 5mm x 101mm
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=s94rs7fj7c1ve8ibtdma5a6iq0&/topic,60973.0.html
« Reply #31 on: October 18, 2017, 12:08:35 PM »
you can bay thredent shaft in meters..and cut the needet lenghts..its not a strong type threds but.. can do the job..if they sell metric stuff..near by..?
i hate all this v-w.... vords
Offline gbal06
« Reply #32 on: October 18, 2017, 08:34:24 PM »
Thank you for your help.  Does your part list give the part number to the long screws that hold the end caps on?
Offline strynboen
« Reply #33 on: October 19, 2017, 02:55:17 AM »
no the long bolts are not numbered...but try to bay some used...bay used on e bay are to kosty..gold diggers  all over...easyest to bay some metric long threads..m4 or m5( cant even renember)
« Reply #34 on: October 20, 2017, 03:11:16 PM »
Can you measure the length of the bolts you need?
With your starter assembled, measure the length needed.
I have a line on a box of used starter motors.
Mght be able to get what you need.  But, none of the starters are marked where they come from.
