Author Topic: My first complete build 72 CB750 - completed for now...  (Read 55893 times)
Offline Gamma
  • Bike Magazine august 1980 page 71. me on my F1
Re: My first complete build 72 CB750 - completed for now... maybe not
« Reply #350 on: June 01, 2021, 07:33:43 AM »
Following your post now, as I’m getting close to doing the same and turning her over on a spare battery
Offline algophobe
« Reply #351 on: June 03, 2021, 10:56:13 AM »
I was reading your post, nifty build, following as well. you sure make it look easy.
apparently a truck battery didn't give me better results any. since i used an aftermarket oil reserve tank i had to double check again to make sure I didn't cross up the inflow and return hoses. looks like I isolated the oil pump as being the issue, so it'll have to come out. I wish I had know prior to putting the engine back together and now wondering whether the oil pump may have been the issue all along that made me have to take the engine apart, don't recall the oil light coming on either. will see what awaits me from the bottom of the crank case.
« Last Edit: June 03, 2021, 11:10:54 AM by algophobe »
Ducati Hypermotard 950 SP 2020 "Percolo"
Honda cb750 café 1972 "Satmui"
Kawasaki zx6r 2005 "Garuda"
Kawasaki zx7r 1998 "Dharma" (stolen)
Honda Magna V4 1982 (sold)
Offline calj737
  • I refuse...
« Reply #352 on: June 03, 2021, 11:21:23 AM »
when you refer to a shim, are you talking about placing a thin ring to fill the gap like this? pardon the bad disproportionate drawing.
No, between the lug and the frame lug. Spacing the two halves apart. That prevents the welding heat from "pulling" the sections together so tightly you can't separate them later.
You'll always be able to cinch them up with a bolt when installing though.
Offline algophobe
« Reply #353 on: June 03, 2021, 11:18:28 PM »
So before I go and remove the oil pan and pump, and I did some reading thru various repair manual and they all mention the need to prime the pump before installing it.  I dont’ remember doing this for the first part of the build and yet the oil still primed itself, during the first iteration of this build.  At the time I was using a much thinner oil so by miracle or dumb beginner’s luck, I was able to get it to prime by just turning running the engine with the battery/starter. So the pump may have introduced air bubble when I kept it dry for the last year and having turned it over many times by hand, dry of oil. So I’m curious if anyone would know the answer to this? Is priming the oil pump completely necessary? Would using thinner oil prime easier without submerging the pump in oil prior to installation? For this go round I started right off with 20w50 without priming, which may have made it difficult to rid of air from the system.
« Last Edit: June 04, 2021, 06:27:33 AM by algophobe »
Offline Gamma
« Reply #354 on: June 04, 2021, 01:22:51 PM »
I finally got around to reading your full build. Lots of interesting things to think about. I did prime my oil pump when I installed it several years ago, I have hand turned the engine several times since then, with some oil in the engine.  I am now getting nearer to getting the electrics sorted (I made my own loom like you)  I expect to turn the motor on a car battery with the spark plugs out and wait for the oil light to go out😁 Also my plugs are Iridium ones😃
Offline algophobe
« Reply #355 on: June 04, 2021, 04:19:03 PM »
There was a post on here about using a shop vac to pressurize the oil tank to force oil to displace the air. I may try that first prior to dismantling the oil pump and submerge it to prime.
My luck with iridium ones was bad, the D7EAs seem to get better burn.
Offline algophobe
« Reply #356 on: June 05, 2021, 09:55:19 PM »
Good progress today, the problem did turn out to be air lock in the oil pump. I modified a technique a member on the forum wrote on how to push out air from the oil pump. Instead of a shop vac and rag. I ended using my air compressor with trigger nozzle, and bought a rubber cork at ACE Hardware for $1.99 and fitted the nozzle as such. I clamped the vent hose to the lower case on the aftermarket Cognito Moto oil tank (see green clamp) and 20w 50 oil that I have in the engine already (with tank filled with 2 quarts of oil). Didn’t use thinner oil as I initially intended to. Then lightly pressurized the tank while kicking the engine over about 10 times. Air did hiss out of the top end via return hose but pressure built just enough. Then as if the Motorcycle God finally had pity on me and allowed oil to spill from the inlet at the oil filter.
I replaced the oil filter and cranked the engine over with the car battery and lo and behold the pressure on gauge shot up to 65 psi with oil pouring out of all holes on the top end.
Imagine my relief of not having to order another oil pan gasket and dismantling the pump just to prime and scraping the gasket off while laying on the ground.
« Last Edit: June 05, 2021, 10:43:01 PM by algophobe »
Offline algophobe
« Reply #357 on: June 20, 2021, 03:11:31 PM »
got the bike running again, I did some preliminary mods to the Keihin CR31's. Previously she idles well only if the air screw was 1/4 turn from completely down, I increased the Pilot (slow) jet to 62's which allowed me to have more room with the air screw.  now she idles well at 3/4 turn from bottom. I knew the bike was running too rich at 1/2 throttle and up so I did some prelimiary adjustments with wider needles yy9 and increasing the main air jet to 250. i'm certain that i'll need to go down on the main jet too but i'll just work with the clip position on the needle first. the carbs were originally put together by Dime City which was slight variation from stock settings for CR31 according to the manual. some light turn of the throttle to 1/2 turn produced some dark exhaust smoke, so either the clip position need to change or go smaller on the main jet.  After a couple of twist of the throttle to full, loud clanging was noted on the top end. Lo and behold this happened. hopefully tightening the tapet bolts will correct it and correct the noise. the damage seems superficial on the tappet covers, hopefully thats it. also i took out the spark plug to inspect and number 1 and 2 cylinder (left two spark plugs) were significantly darker than 4, #3 is ok but cold be better. not sure what the difference would be due to but, looks like there are a few issues i need to sort out before dealing with the difference in combustion from 1/2 to 4. more to come.
« Last Edit: June 20, 2021, 03:22:27 PM by algophobe »
Offline algophobe
« Reply #358 on: July 10, 2021, 11:10:28 PM »
I readjusted the rocker tapers again and tightened them down snug, she seems to run fine now. Had a chance to check the timing again, advanced her to 10+, recheck the carbs for balance. I lowered the size of the main jet and drop a clip level on the needle. She seems to be running leaner as I want her to. I’d like to take her on the road again and do the series of spark plug chop to really see how the plugs do with the smaller jet. Problem is I don’t have a final drive chain.
I do, but need a master link. I bought some 530 JT x ring chains from Bike Bandit years ago, but seems like their stock is on back order for a few weeks now. Anyone have any thoughts on using O or X ring chain versus the original chains? I’ve plugged up the oiling mechanisms so have to keep with the O ring types. I see that 4into1 has the Fire Power brand.. but it doesn’t say if they are O ringed or not.
« Last Edit: July 10, 2021, 11:12:40 PM by algophobe »
« Reply #359 on: July 10, 2021, 11:37:04 PM »
X-ring has replaced o-ring chains. Improved design.
Use a modern good quality x-ring chain on a street bike.
Lubricate frequently so the x-rings do not wear and let the grease out.
I killed a strong chain with chain wax. It was not new, but no signs of giving up the nearest rear tire life.
Used Maxima Chain Wax and the wear accelerated really quick. A strange red brown dust around front sprocket cover that I later understood was rust.
X-rings worn out and the links degraded within 3000 km.
One of the markets strongest 530 chains. Chain looked like the stretch was sideways.
I do not like lubricants that are sticky. Chain will look lubricated but is not when lube can not flow where needed when scuffed off which happen when driving.
My favourite lube is Motorex Road, strong.
I have a bottle of Motul that is the sticky variant too. Maybe possible to mix with a cheap not sticky.
Best lube is not the one that does not make rear wheel dirty.
Offline algophobe
« Reply #360 on: July 13, 2021, 07:56:02 PM »
funny thing, i was at a track day event and was criticize by a suspension expert for using chain wax on an xring chain. he insisted that all you need is WD for for cleaning only. i guess its only partly true
« Reply #361 on: July 14, 2021, 04:52:04 AM »
I think MTB guys and other bicycle racing guys use WD40.
Racing guys use most likely what gives less power losses.
Thinner chains and probably thinner lubricants.
I met one guy that lubed the chain everytime he filled the tank. Bike on centerstand, spray thin lithium grease spray.
I always hear from the dyno guys to lube chain and higher rear wheel pressure to get max power on dyno. I use what I ride with.
Dirt bikes have no x/o-rings at all if I have got it right.
« Last Edit: July 14, 2021, 06:57:51 AM by PeWe »
« Reply #362 on: July 14, 2021, 08:43:10 AM »
Plenty of oring and xring chains on dirt bikes nowadays, PeWe.
I have had best durability with just cleaning sealed chains with wd40, no lube until chain is near finished, just to squeeze a few more miles out.  I have been getting 15 to 20000 miles out of street bike chains this way.
Offline algophobe
« Reply #363 on: July 14, 2021, 09:33:34 PM »
i guess i'll continue doing the wd40 thing from here on.
the replacement master links for JT chains are finally in and finally buttoned up the bike. with all the parts on, the new location regulator/rectifier doesn't look like too much of an eyesore as i thought. almost forgot what the bike looks like all together since she's been in pieces for a few years. hopefully i'll have a chance to test run her this weekend and maybe even do the first series of spark plug chop.
what i think may have happened with the first iteration of the build, there was quite a bit of oil leak into the combustion chamber, the spark plugs were quite wet and black with the addition of running her too rich as well. the leaks likely came from the valve guides. after running the bike with the new rebuilt top end, the spark plugs are much drier and dark. more like a rich fuel mix than oil leak. now with the smaller main jet and raised clip position of the needles, hopefully i'll get better results... crossing my fingers.
side note: i met Vincent and his CR750 at Newcombs Ranch up in Angeles Crest Highways about a month ago. boy its a thing of beauty even with a dent in the tank. we swapped stories about our builds and how he just simply dropped in his Keihin carbs and never had to fuss with them. even with the rebored cylinder he was using CRS29 carbs. makes me think i was headed for this trouble with a rich mixture since i started out with CRS31's on essentially a stock top end.
« Last Edit: July 14, 2021, 09:53:21 PM by algophobe »
« Reply #364 on: July 15, 2021, 07:49:29 AM »
Just my $0.02 but CR31s are better suited for a high performance motor and can be finicky for street use.  Probably good for displacements over 900cc or you will run rich.  The CR29s are easier to tune for street use on a stock motor up through a higher performance/compression 836 with a cam/port job.
« Last Edit: July 15, 2021, 07:53:19 AM by SOHC4 Cafe Racer Fan »
Offline algophobe
« Reply #365 on: July 15, 2021, 03:27:41 PM »
with hind sight. i completely agree, it was under the advice of Dime City who built it for me... maybe a little bit of upselling?
Offline algophobe
« Reply #366 on: July 24, 2021, 01:11:29 PM »
so i ran her around the block for the first time in 2 years since the bike broke down coming home from the OG moto show in Los Angeles. The brakes are squeeky as hell even with the shims purchased from our fellow SOHC4 member... i'm hoping it takes some more break in than just 100 miles.
she runs fine at idle to 1/8 turn of the throttle, hesitates like crazy at 1/4 turn up to 1/2 turn, and has a burst of power at 1/2 turn all the way to full throttle. I had lowered the clip on the needle from 5th to 4th position hoping to lean it out and may have been too much, which have been in addition to using a leaner (thicker diameter needle) needle yy8 to yy9.
but the spark plugs are looking great, the char from the same spark plug are turning more brown and drier.
next step would be to set the clip position back to 5th position and if the hesitation disappears then i'll proceed with a spark plug chop.
oh and a gratuitous pic of the kids on with the bike.
« Last Edit: July 24, 2021, 01:25:18 PM by algophobe »
Offline algophobe
« Reply #367 on: July 25, 2021, 08:02:00 PM »
lowering the clip to 5th position sure helped with the 1/4 turn throttle to 1/2 throttle. however now i'm noticing a flat spot just before 1/4 throttle, a faint hesitation but doesn't occur all the time. of course this hesitation only occurs around the neighborhood. I took her up a little higher in the canyons near my house and she sure likes the thinner air (which is where I intend her to perform best in). i'll play with the air screw a little bit before swapping the needle to YY8's (Skinnier).
what i did learn is that the reserve setting on the petcock is crap! i decided to test it by running it half the test on reserve. the bike dies and gasp for fuel to fill the float bowl. certainly better with the petcock on "on" position. but i still feel it may not be enough.
anyone have advice on the Pingel adapter/petcock? or is there a known issues with air lock on the OEM petcock?
Offline algophobe
« Reply #368 on: July 26, 2021, 03:42:29 PM »
who knew a 1/4 turn inward to richen the air screw made such a difference. the throttle is smooth throughout the range. she runs well at normal commute type altitude around town, im sure it would be perfect in the canyons. no fueling issues with the petcock on "on" position. performed the spark plug chop down a straight 1/2 mile road near the house at 1/2 and full throttle without having the neighbors calling the cops on me. not sure if 1/2 mile is sufficient enough to cause the discoloration marks as desired. but i can't imagine sustaining full throttle for that long. definitely learned that the bike can get quite squirrely and gives a massive head shake if you put too much weight over the front wheel in a full tuck, i forget i have more seat to buck up into to distribute more weight over the rear wheel.
the only resemblance of results with the light discoloration ring on the 1/2 throttle #2 plug. i'm not sure how much i'm learning from today's chop exercise, but she's running great so I can't complain. at some point i may just put her on a dyno and see what i get, and maybe a steering damper may be a good idea.
« Last Edit: July 26, 2021, 04:04:47 PM by algophobe »
Offline algophobe
« Reply #369 on: July 26, 2021, 04:11:29 PM »
A little photo shoot at the end of the test... for now she's done.
« Last Edit: July 26, 2021, 04:16:25 PM by algophobe »
Offline Jimcg
« Reply #370 on: August 15, 2021, 06:14:24 AM »
What a great looking bike! Such a beauty!!!
/Jim
1982 CB650Z RC03 owner in Eskilstuna, Sweden
About my bike:
http://forums.sohc4.net/index.php/topic,183848.0.html
Just the pictures and no text:
https://www.flickr.com/photos/189154615@N04/?
Offline algophobe
« Reply #371 on: September 21, 2021, 03:08:50 PM »
thank you jim, i'm liking your color scheme as well. similar taste.
Offline greenjeans
  • 1972 CB750K2
« Reply #372 on: January 04, 2022, 12:10:31 PM »
Just found this thread.  Somehow I feel a bit of kinship with you as I fought my 836 build with The CR29 carbs.  Took a bit of tuning, but definitely worth it afterward.
Great build, I really dig those colors on there.  Well done sir.
