Author Topic: Front end rattle?  (Read 5286 times)
Offline BobR
Re: Front end rattle?
« Reply #25 on: October 22, 2017, 07:01:10 AM »
My assembly. The one piece style pictured in the manual wont have the same type of issue/solution. HTH Bob
« Last Edit: October 22, 2017, 08:15:14 AM by BobR »
Reality is merely an illusion, albeit a very persistent one. Albert Einstein
 CB750K4(F2 engine)
Offline BobR
« Reply #26 on: October 22, 2017, 03:22:48 PM »
OK update:  This is only pertinent to those that have this style set up. I took the caliper off. Then loosened the two bolts holding the upper bracket of the pivot. Used a vise grip(with electrical tape wrapped on the ends) to clamp down the bracket a little. Checked the movement. As long as the spring could return the arm I was happy. Reassembled-voila! Zero play!
  Now unfortunately I cant say if the clunk is gone as I haven't ridden it yet. The play however is gone. HTH Bob
 CB750K4(F2 engine)
Offline jonda500
« Reply #27 on: October 25, 2017, 03:25:27 PM »
Have this too. Been that way since I got the bike in 98 and fixed it up. Recent renewed interest in riding it has me finally looking to fix the annoying clunk. Might be a stupid question but are there any internal "bumpers" to soften full fork extension? Seems to me that's when I get it. Bob
I will be following this thread as I also have a front end rattle and a loud clunk when I rock the bike back on the center stand so that the forks fully extend???
John
A starter clutch thread:
Offline BobR
« Reply #28 on: October 25, 2017, 04:30:55 PM »
John
 Ive yet to ride mine since I took out the play in the caliper holder. Will report back when I do. bob
 CB750K4(F2 engine)
Offline AndyH
  • My religion:-
  • Pretty well West of Everywhere in Aus!
« Reply #29 on: October 25, 2017, 08:29:22 PM »
John
+1 John.  I was thinking lack of fork oil but now I'm not so sure... :-\
1971 CB750K1 (US import)
1972 CB500 Four K1 (SOLD)
Previously owned..
1967 Honda Sports 90
1971 Yamaha CT2 175
1973 Yamaha RD250
1975 Kawasaki KX125
1983 Yamaha XT250T
BMW R65
BMW R80
BMW R100LT
Offline BobR
« Reply #30 on: October 28, 2017, 02:20:34 PM »
  Got a chance to ride the bike today.  The majority of clunking is gone AND no more brake squeal! That alone is worth the price of admission! Still get a bit of a clack hitting hard bumps -not as loud and sounds more like something around the headlight. If you have the caliper arm bracket like mine-take the play out as I described. If its a one piece like the one pictured in the manual, make a shim. HTH Bob
 CB750K4(F2 engine)
Offline Desert-SOHC
  • It's old
« Reply #31 on: October 28, 2017, 03:56:18 PM »
Mine does it too, I'll have to check the caliper.
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline ef9tuning
« Reply #32 on: October 31, 2017, 11:43:49 AM »
My 78k would make a similar sound as you're describing. I found out it was the gas tank rubber strap/holder causing a clunk sound over some bumps!
1978 CB750K
Offline Desert-SOHC
  • It's old
« Reply #33 on: October 31, 2017, 01:26:43 PM »
Yup, my caliper was moving, tightened it with pressure on the bracket.  1 more noise is gone... ;D
11 Ranger S/C 2wd
Offline Dunk
« Reply #34 on: November 12, 2017, 06:54:14 PM »
I tried to take my own advice on this one and the first attempt failed. I could not punch the required size hole in the feeler gauges I had, not wide enough so they broke each time I tried. I measured the end play in the caliper bracket at .005". I learned a aluminum beverage can is .004" thick, what's .001" between friends? Punched out a washer to shim it and reassembled. Should be more better!
Offline Dunk
« Reply #35 on: November 12, 2017, 06:57:38 PM »
Offline Dunk
« Reply #36 on: November 12, 2017, 06:58:12 PM »
Offline Dunk
« Reply #37 on: November 12, 2017, 06:58:46 PM »
Offline scunny
  • don't call me expert
« Reply #38 on: November 12, 2017, 09:55:08 PM »
Are you related to Terry ?
nice thinking by the way.
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
