Author Topic: For SCIENCE! (weak charging)  (Read 5921 times)
Offline RandomOrbit
« on: October 20, 2017, 06:21:23 AM »
So the condition of my charging system came up in an earlier thread, but that thread wasn't really ABOUT that, so I'm starting a new thread to talk about my charging issues.
All summer, probably for years actually, my charging system has been sub optimal. The battery never dies on me, but it never gets a very full charge either. It's not really been a big problem as I use the kick starter out of habit. Probably a habit that started twenty some odd years ago when I was in college and couldn't afford a new battery when I needed one. But as I've been working on my bike this summer I'm trying to clean up all the little glitchy bits so instead of just working it works WELL. Charging system has been on my mind, but not a high priority. Good news is I am now onto the lower priority items!
SO last weekend while I was ordering turn indicator lenses, and shiny new chain adjuster bolts I also threw a new regulator/rectifier into my cart. Why, you may ask would I do that without first testing my charging system to verify that one of those components was the problem? That's a very valid question, and the answer is that although I wasn't SURE either of them was faulty, I've never touched either of them in the 26 years that I've owned the bike, so I know they are at LEAST that old, but more likely they are from 1976. As I've been working on my bike I order parts, wait a few days, then often discover I should have ordered more parts, and summer is short here in Vermont, and my riding days are numbered. So I figured it was a good bet that those components are not as good as they were back when our nation was celebrating it's bicentennial. So I threw that part in my cart and looked forward to tackling the charging system next weekend.
Now like I said I think it's a good bet that one or both of those components is due for replacement, but it's not very scientific. So FOR SCIENCE I figured I should get some baseline before readings before I tear into the system this weekend.
This morning before leaving for work engine cold ignition and headlight on, but not running, voltage read 11.6. At 2000+ RPM with the choke on in my driveway it was reading 13.4 not too bad. Certainly respectable. I didn't rev it any higher in my driveway at 7am because I don't want my neighbors to strangle me in my sleep.
I tested it again at the work end of my ride after 40 minutes at about 5000rpm. This is where things get interesting.
  • Ignition off, 12.0 volts
  • Ignition and headlight on, but not running 11.6
  • 2000 RPM 12.26
  • 3000 RPM 12.34
  • 4000 RPM 12.35
  • 5000 RPM 12.36
  • 6000 RPM I work on a college campus. Do you want to get me fired?!
Never got anywhere near the 13.4 volts I was getting in my driveway at 2000 RPM first thing this morning. So I'm thinking the charging system is working better cold than it does after having run for 40 minutes. This was a total surprise to me and I'm not sure what to make of it. Like I said in all these years I've never touched the charging system yet, so maybe folks more familiar with them would not be so surprised.
CB750k6 owned since 1991
Offline Deltarider
Re: For SCIENCE! (weak charging)
« Reply #1 on: October 20, 2017, 06:54:16 AM »
In order to interpret things right, we must know where you connected the probes when you tested riding. Also whether you started with a well charged and sound battery* or not. A well charged battery will read - once disconnected from its charger and after it was left in peace for a couple of hours - 12,6 V min. Whilst you're there, you could do a few simple checks. What do the battery terminals look like? Any sign of buildup corrosion? Any sign of that where the POS cable is connected to the starter relay? Check that NEG cable is connected to a clean and unpainted part of the frame. There should be zero resistance.
* 12,6 V does not say all, btw. How old is your battery? Was it ever depleted? For how long?
« Last Edit: October 20, 2017, 07:21:09 AM by Deltarider »
CB500K2-ED Excel black
Offline RandomOrbit
« Reply #2 on: October 20, 2017, 07:13:57 AM »
In order to interpret things right, we must know where you connected the probes when you tested riding. Also whether you started with a well charged and sound battery or not. A well charged battery will read - once disconnected from its charger and after it was left in peace for a couple of hours - 12,6 V min. Whilst you're there, you can do a few simple checks. What do the battery terminals look like? Any sign of buildup corrosion. Check that NEG cable is connected to a clean and unpainted part of the frame. There should be zero resistance.
Taking the reading at the battery terminals. Battery is new as of this spring, and terminals are clean, but the charge state of the battery is closer to 12.0 than 12.6 due to the not great charging system. I'll put it on the charger this weekend while I'm working on it, but I know from recent experience that it WILL hold a charge. I charged it up while I was working on the lights a few weeks back, and it held that charge for at least a week before dipping back to where it is now.
Since it came up in the other thread, the fuse block is surprisingly good. Most of the bullet connectors in the wiring system have that dull chalky corroded look to them, but the fuse block is clean and shiny. It basically looks like new.
Offline uksparky
  • Track days
« Reply #3 on: October 20, 2017, 07:16:43 AM »
Went through this with my 550 few weeks back only charging 12.50 volts on highway 5,000 rpm.....main fuse 15 amp was hot to the touch......cleaned that fuse and where it fits real good,...then the plug connector to regulator.....charging good now 14.3 volts
Present bike 1982 900C Custom
Offline Deltarider
« Reply #4 on: October 20, 2017, 07:30:46 AM »
It's better not to have the batteries at a voltage < 12,5 V for an extended period of time, to avoid sulphatisation.
Offline RandomOrbit
« Reply #5 on: October 20, 2017, 07:40:21 AM »
Also, I'm just gonna toss in a plug for 4into1.com here as they've been AWESOME for me. I've ordered some parts from other places and had it take 10-16 days to get to me. It sucks to wait that long for a part especially if you need it to get back on the road.
4into1 always ships my parts right away (next business day if I order them on the weekend) and it generally only takes a couple days to get to me in Vermont from California via USPS. If that was everything, that would be enough to earn my loyalty, but they've gone above and beyond a couple of times. Once I ordered the wrong parts, during the day, and realized on my way home that it wasn't a new master cylinder I needed at all it was just the diaphragm for the cap that was leaking. So I emailed them as soon as I got home 6pm my time. Fortunately they hadn't shipped yet and they refunded my order so I could order what I actually needed. Fast forward to this weekend. I ordered parts on Saturday  and then when I was changing my oil on Sunday I discovered I needed a new tach cable. So I put in a second order, and let them know in the comments it would be fine with me if it was easier for them to ship both orders together. And do you know what they did? They refunded me $8 for shipping! I know I can count on them to get me parts in a timely manner & their customer service rocks!
« Reply #6 on: October 20, 2017, 10:05:07 AM »
Search for charging + Twotired. He has explained this very detailed with description how to measure and where in several threads. Chapter 8 in Honda shop manual  will help too (attached file). Read the entire chapter first, then check your bike, measure the voltage over the battery poles at various rpm, clean and adjust/service the regulator etc. Fully charge battery or not will affect the result too.
Offline RandomOrbit
« Reply #7 on: October 20, 2017, 10:56:42 AM »
Thanks! Will have a look this evening. Not sure I will bother too much testing the old components since I'm planning to replace them with the new Reg/rectifier. I'll focus most of my energy on cleaning contacts. I won't throw them out either though in case they can be refurbished.
« Reply #8 on: October 20, 2017, 11:04:13 AM »
1. get a battery tender and keep it hooked up
2. fully charge your battery then carry it in for a load test at a place like Advance Auto. Not interested in a voltage test.
3. start testing your harness at the connections
4. clean ALL your connections including the ignition switch
I'll bet all your hardware tests out fine and your connections are your problem.
« Last Edit: October 20, 2017, 11:07:20 AM by Jerry Rxman Griffin aka MuthaF'er »
« Reply #9 on: October 20, 2017, 11:22:33 AM »
Was lighting on or off?  Charging system voltage function is load dependent  A battery at 11.6 is under severe load and/or depleted.  This is why charging system tests are performed with a known good fully charged battery.
  • 2000 RPM 12.26
  • 3000 RPM 12.34
  • 4000 RPM 12.35
  • 5000 RPM 12.36
You're developing a good process/methodology.  However, the starting basis or foundation is unanchored.  Castles built on sand...
What? Come on, this is NOT scientific exploration, this is speculation, unfounded in fact.  Hit five pot holes instead of 2 this morning?  One phase of the alternator output lead come apart?
I believe you should have better results if you think differently, objectively, about this matter.  Your bike's situation is actually a physics matter in its root.
Facts.
The voltage measurement shows a battery that is in a depleted state, rather than a charging system condemnation.  Understand the is a reservoir that under ideal conditions neither rises or falls in voltage state quickly (this is a good thing).  Your charging system should be good for about 14 amps output or 210 Watts @ 5000RPM.
The 750 battery is capable of putting out 500-1000 Watts for short periods of time, but does not in normal usage.
To recharge a fully depleted battery, you have to put back in 120% (chemical conversions aren't 100% efficient) of what was taken out.  If you want your bike to recharge your depleted battery, better have it rev to 5000 RPM for about 10 Hours, shorter if you turn the lights off.  I'd rather put it on an off bike charger.
The key point is, the charging system doesn't dominate instantaneous voltage readings, the battery charge STATE does.  That's why you check the bike's charging system with a known good, fully charged, battery.
Not enough data.  Load?  Average RPM during your trip?  More measurement data needed.  The data will point to the problem.
Charging system methodical verification checks, CB750, CB550, CB500, CB400, and CB350.
Begin with problem verification and characterization with recorded data.
A -- Fully charge a known good battery.  Let it rest for 2 hours, off the charger, and measure the battery voltage.  (Target is 12.6-12.8V.)
B -- Start the bike and measure the battery voltage at idle, 2000, 3000, 4000, and 5000 rpm.
C -- Repeat the measurements of B with lighting off.
The above tests identify charging system success, failure, or degree of "faulty".  The success voltages are listed in the Shop manual.
D -- Assuming the above indicates faulty, do check the RECTIFIER diodes with a diode tester or ohmmeter capable of testing diodes and uses more than .7 volts to make the test(s).
Of the twelve test made in D, six must read low ohms and six must read very high ohms.
E- assuming no faults were found in D,  Measure the white and green wires disconnected from the REGULATOR.  CB750s should 6.8 ohms - ish,  CB550s/350s/ and 400s should read 4.9 ohms- ish.
F- If there are no bullet holes or road rash/divots on the alternator case, the stator is probably good.  But, you can check for yellow to yellow continuity (.35 ohms) among all the wires, and that no yellow wire has continuity to the engine case.
G- Assuming no faults found in D, E, and F, measure the disconnected terminals of the REGULATOR.  The black and white terminals should measure zero ohms (subtract meter error if there is any).  Higher than Zero ohms, indicates internal contact contamination needing cleaning and attention per shop manual.
H - Assuming D, E, F, and G have not found faults. We can verify all the of the charging system minus the regulator is functioning correctly, by using a temporary jumper to connect the disconnected white wire (normally attached to the REGULATOR) and connecting the White directly to the the battery POS terminal.  Repeat the B and C tests.  However, if at any time the battery voltage rises above 15V, stop the test.  Such an indication would prove the charging system capable of maintaining a known good battery.  If this test never achieves 15V, then there is a wire/connector issue in either the ground path leading back to the battery NEG terminal, a wiring/ connector issue withe the rectifier RED path to the battery POS terminal, or you made a mistake in D through G.
I - (not used, can be confused with L)
J -  The only parts that remain to prove or expose are the REGULATOR (in active mode) and the electrical path between the battery POS terminal and the black wire that connects to the REGULATOR.
K - Lying to and starving the regulator
The regulator can only do its job correctly if it gets a proper voltage report of true battery voltage status.  The Vreg monitors the Black wire for this status.  Measuring the voltage lost between the Battery terminals and the Vreg connections identifies problems that are not really the charging system's fault.
Two connection paths must be checked, the Battery POS terminal to the Black wire connection at the VReg, and the Battery NEG terminal to the Green wire connection to the Vreg.  A volt meter can measure these losses directly by placing a probe between the two identified points, Black path and then the green path.  The numbers are summed and the error seen by the Vreg quantified.  Anything over .5V loss is cause for concern and anything over 1V is a certain issue to be corrected.  Each connector, terminal, fuse clip, or switch in the pathway can cause voltage reporting loss.
The regulator also passes the received voltage on to to the Alternator field coil to create a magnetic field within the alternator,  The voltage level determines the strength of the magnetic field and the maximum output capability of the alternator.  Therefore, starving  the Vreg of true battery voltage leads to reduced max output capability of the alternator.
L - regulator operation/verification.
  The Vreg sends voltage to the alternator field in response to measured voltage which is battery state of charge.  Any voltage at the battery of less than 13.5V sends full black wire voltage to the alternator's white wire.  The alternator output will vary with RPM, even if "told" to produce max power by the Vreg.  If the alternator has enough RPM to overcome system load, any excess power is routed to the battery which will raise the battery voltage (slowly if depleted and rapidly if nearly full).   When the battery reaches 14.5V, the regulator reduces the voltage to the alternator, reducing output strength and preventing battery overcharge.  If the battery exceeds 14.7V, the regulator clamps the alternator field coil power to zero (0V), effective shutting off the alternator.
Because, there is electrical load from the system, an alternator that is not producing power allows the battery to deplete and the voltage falls.  The Vreg responds by turning the alternator back on in accordance with battery state/ charge level.
The Vreg state changes can be monitored/verified by observing the battery voltage state, and the White wire to the alternator field.  (Two meters are handy for this.)  The "trip" voltages can be adjusted with the adjust screw, while changing engine RPM and electrical load that the bike presents to the battery/charging system to "make" the battery reach the voltage levels need for the set trip points.  IE. with load reduced (lighting off) and the engine above 2500 RPM, a charged battery will attain 14.5 V.  Anything above that and the adjust screw needs to be backed out to keep the battery safe from harm.
The shop manual outlines bench set up mechanical adjustments that should be performed on unknown or tampered units.  These should be resolved before final trip point adjust tuning.
Note that while the system is working, the Vreg can change states rapidly before your very eyes., changing 5 times or more while you blink.  Therefore, you may have to mentally average values measured on the White wire if your selected meter doesn't do that for you.
Offline Deltarider
« Reply #10 on: October 20, 2017, 11:24:15 AM »
I'd rather not. Every 5-6 weeks a fresh-up charge is all what it takes. I did over 8 years with my last standard battery this way. Not all tenders are reliable and some cook your battery to death. Besides, it's a waste of energy. Better invest in that simple 'tell-it-all' three color LED that Pewe presented. It tells you when your battery needs to be charged and is an overall charging watch. Modest in size too.
2. fully charge your battery then carry it in for a load test at a place like Advance Auto. Not interested in a voltage test..
Or do your own test. Do electric start and see how far voltage drops whilst cranking. Shouldn't get below 9,5V. Best checked with an analogue voltmeter.
« Last Edit: October 20, 2017, 11:36:26 AM by Deltarider »
Offline RandomOrbit
« Reply #11 on: October 20, 2017, 11:48:09 AM »
There is a lot to respond to in your post @TwoTired, and first off I know my testing was pretty slapdash. What can you expect first thing in the morning on my way to work. I put less than 5 minutes into it and this was just to get a baseline for where I am and where I've been for months. Battery was new this spring, I charged it overnight before installing it and once again when working on the lights, but other than that, it's been reliant on the motorcycle charging system. I will put the battery on the charger tonight, and bring it up to a full charge before I go to work on this.
I think I mentioned that my commute is 40 miles, 38 of which are interstate at a steady 5000-5500RPM so I think an average of 5000rpm over 40 minutes is a pretty good estimate. I don't have a lot of time for riding outside to my commute, so the vast majority of my riding is this. Again I know I don't have a lot of hard data, but my bike has been performing the same for months, or probably more like years, so I don't think there has been any sudden change in the charging output, but I would not be surprised to find that the hot/cold behavior is not consistent, and maybe not even related to temperature or time as it initially appeared to be. I may repeat the before and after ride tests on my way home if I have time just to see if I get similar results.
edited to add: I don't have an off switch for my lighting, so I've never tested it this way, but I suppose I could pull the headlight and tail light fuses to get that reading easily enough.
« Last Edit: October 20, 2017, 11:52:59 AM by RandomOrbit »
« Reply #12 on: October 20, 2017, 12:02:12 PM »
If you want to SEE how your charging system works while riding. Install a simple LED that will show you. I have written about this in several posts and I'm really pleased with its function. It will lit green around 4000 rpm, before that yellow.
 Sometimes indicating overcharging for a short while green/red flash, a few minutes only. It will stop overcharge quicker with headlight on. I do not care about short period of higher voltage, neither will my Hondaman ignition module that is specified up to 20V something.
It look like an alarm system while parked with ignition off, blinking green every 2 seconds.
http://www.ebay.co.uk/itm/LED-Motorcycle-Battery-Alternator-Charge-monitor-level-indicator-warning-bike-G-/200826330214?epid=0&hash=item2ec22e9c66:m:mkmYChJxuSeWHHrNu2SCeIw
With this small gadget you will know if your battery is draining or charging.
« Last Edit: October 20, 2017, 12:06:06 PM by PeWe »
Offline Deltarider
« Reply #13 on: October 20, 2017, 12:08:38 PM »
Thanks Pewe. Saved me the trouble to look it up. Great little thing that won't spoil the looks of your bike. Positioned where it should be, intuitive to read, not distracting. Perfect.
« Last Edit: October 20, 2017, 12:11:59 PM by Deltarider »
Offline RandomOrbit
« Reply #14 on: October 20, 2017, 12:10:51 PM »
That's pretty cool!
Offline Deltarider
« Reply #15 on: October 20, 2017, 12:27:51 PM »
Sometimes indicating overcharging for a short while green/red flash, a few minutes only. ... I do not care about short period of higher voltage
I had the same results when I once had a DMM connected to monitor charging en route. I don't know if this has to do with a digital device being used where an analogue meter would have dampened it out. I never bothered. After every ride I return with a better charged battery than I took of with and so far I didn't have those typical (smoke inside) blown bulbs that indicate overcharging.
« Last Edit: October 20, 2017, 12:33:45 PM by Deltarider »
Offline RandomOrbit
« Reply #16 on: October 20, 2017, 12:31:19 PM »
This is what I've got for a multimeter. Not sure is my Ohmmeter capable of doing this test?
Offline Deltarider
« Reply #17 on: October 20, 2017, 12:35:57 PM »
Yes, capable.
« Reply #18 on: October 20, 2017, 12:36:30 PM »
It is.  Note the function knob position  -|>-
This is the diode symbol.
Offline RandomOrbit
« Reply #19 on: October 20, 2017, 12:37:16 PM »
Thanks for all your help!
Offline Spanner 1
« Reply #20 on: October 21, 2017, 09:04:14 PM »
At the end of a 40 min ride @ 5000 rpm, your battery is back to full charge so a charge reading of 12.whatever is normal and what you want to avoid 'boiling' the battery. In other words the regulator is working as designed and has 'clicked over' to the1/2 power setting. Ride and enjoy. When the voltage drops below ( about ) 12v the regulator will 'click back' to full power and you would see that 13.5 volts or more again, like you did just after you started the bike cold ... ;)
« Reply #21 on: October 21, 2017, 10:17:41 PM »
Um...that's not what the Honda manual says, or the guidelines from Yuasa batteries on charging proceedures.  Or, what the Yuasa automatic chargers do on the bench.
They slow charge the batteries up to 14.5 to 14.7 volts.  At this point they should be gassing freely.  Then they switch to maintenance mode and hold the battery volts to 13.2 to 13.4 volts.
Most autos with larger batteries and larger loads try to maintain running volts at 13.8v. The 13.5v range should never cause the battery to outgass.
I guess I'm going to have to disagree with your position on charging systems and battery charging.  Sorry.
Offline Spanner 1
« Reply #22 on: October 22, 2017, 09:01:16 AM »
Comparing an automatic charger which 'slow charges' the battery up to 14.5v, then switches to maintenance mode has no relation to what's happening on your bike! The bike having only full ( fast ) charge and low power ( voltage loss ) charge. So when the battery voltage exceeds 14+ volts the regulator then switches to  about a 0.7A charge rate which is a 'loss' charging rate and so the battery voltage will drop until the magnetic field in the relay coil is unable to hold the contact and the regulator switches back to full charge mode. At what voltage does the depleting battery cause the reg. to switch back to full charge ? The reported voltage of 12.5v may be normal while the battery is in low charge mode. Honda only states the high switch over point to be 14.5v, says nothing about what voltage the battery must deplete to before the reg. switches back to full charge mode.
Offline Deltarider
« Reply #23 on: October 22, 2017, 10:25:13 AM »
Would like to know the (estimated) frequency of this switching per second.
« Reply #24 on: October 22, 2017, 10:46:25 AM »
Ah, the sweeping dismissal argument.  Nice.  ;D
...But wrong. (How's THAT for counterpoint?)  There IS a relation, actually.  And, it is all determined by the vreg, the bike's electrical load, and alternator RPM. ;)
The best automatic chargers begin charge at their fast rate and taper off current (in stages) as it nears the 14.5V trip to revert to maintenance float charge mode.  Sneaking up on the charge voltage peak in stages allows full electrolyte conversion for areas farthest away from the plates.
The stock Vreg has a three position, two contact solenoid inside it. (See pic below)
It allows, full alternator output (RPM dependent) until the vreg monitors 14.5V.  Then the solenoid pulls the contacts apart from the full power contact (thereby inserting a 10 ohm resistance in the field coil circuit, which reduces alternator output) until the monitored voltage lowers to 13.5V, whereupon it re-engages the full alternator output by again engaging the full power contact route.
Normally, with the alternator spinning at higher speed, the Vreg switches between full and reduced output, to maintain at least 13.5V and a higher average, (about 13.8V applied to the battery) as sensed by the Vreg Black and Green connection terminals.
The exception is when the Alternator is turning too slow, and can't provide as much power as the bike's system loads (lighting, ignition, etc.)  At these times, the VReg allows the alternator to put out as much as it can...because the battery sense voltage is below 13.5V.
The above is all stated in different words within the Honda Shop manual charging system description.
There is a second contact in the Vreg.  But, is is only used when the Vreg sense voltage is above 15-16V or thereabout. At this voltage, the vreg actually grounds out the Alternator field coil, effectively preventing ANY alternator output at all.  It's a safety feature, rarely encountered, almost certainly a fault condition, as when the battery electrolyte has been allowed to fall to very low levels disconnecting the battery plate material from the electrolyte conduction path.
I'm thinking you misinterpreted the Honda manual statements.  The 0.7A refers to alternator field coil control current.  Which is in no way equivalent to the alternator output current.   Further, "full charge mode" is the default position of the regulator internal solenoid switch contact.  Don't need any voltage applied to the Vreg for that pathway to be enabled.  The Vreg can only interrupt that pathway when it senses appropriate voltage levels to activate its internal solenoid and open that contact.
Per the book, 13.5V.  But, the actual voltage in the system may dip below that if the alternator isn't spinning fast enough to overcome system loads and have available energy to raise the battery voltage.
Actually, that would be "no charge mode" related to the Alt. RPM and electrical loading.) And the voltage, being less than the 12.6V resting full charge battery state, shows a bit of depletion for the battery.  (See chart below.)
Please look again at the Honda Shop manual Charging circuit description.
« Last Edit: October 22, 2017, 11:08:12 AM by TwoTired »
