Author Topic: 1977 CB550F Speedo / Tach rings  (Read 758 times)
Offline Ace Blackwell
  • 1977 CB550F - Resurrection in progress
« on: October 22, 2017, 08:53:26 am »
All,
Just so you know I have searched before bringing a question that's probably been asked a thousand times. I did the Google thing where only sales and Pintest showed up and I've went through 12 pages here as this was a similar topic for me at the start of the project but can't find the topic.
Question,  Is there a secret to installing (re-installing) the crimp rings on the tach and speedo that holds the two halves together.   I've got new faces, redid the needles, painted the black housings (not too bad) but I can't get the seal compressed evenly to get the ring re-crimped.  I tried crimping four corners but once done as i'm working around the edge like lugs on a car, opposite side works loose at some point.   I need a way to compress seal all at once.  It would leave slack in ring.    Plus I'm trying  not to scratch the black paint.
I'm hoping there is a neat trick to holding secure 8-).
Thanks
1977 CB550F Work in Progress
Offline strynboen
    • http://forums.sohc4.net/index.php?PHPSESSID=ku2214f3de4u90kvn0c885a7k6&/topic,60973.0.html
Re: 1977 CB550F Speedo / Tach rings
« Reply #1 on: October 22, 2017, 09:42:08 am »
you can bay some vho are split..and have a small screv in the bottom..so it can be teighten together
i hate all this v-w.... vords
« Reply #2 on: October 22, 2017, 07:56:24 pm »
Thanks strymboen,  I'll check them out.
Offline strynboen
« Reply #3 on: October 23, 2017, 01:31:14 am »
they are not so nice..as the orginal rings.(.you can get nev rings like the orginal..if you have splashed them)
Offline flatlander
« Reply #4 on: October 23, 2017, 01:38:08 am »
you can also ask member lecram. he knows all about these gauges, sells parts and restores them as well.
