Author Topic: Need help identifying pistons  (Read 4244 times)
Offline smacd11
« on: October 22, 2017, 10:12:31 PM »
I have a full set of forged 836 pistons and a near complete set (3/4) of cast 836 pistons.  I think the forged ones are RC engineering Venolia from pics I have seen, the cast pistons appear to be Honda pistons as they have ART cast into them. They both measure 65mm. Any help on these would be greatly appreciated. I would like to know the recommended clearance for those forged pistons.
Offline smacd11
Re: Need help identifying pistons
« Reply #1 on: October 22, 2017, 10:13:45 PM »
Here's more pics of the cast piston
Offline smacd11
« Reply #2 on: October 22, 2017, 10:18:33 PM »
And the forged...
Offline Bill/BentON Racing
    • BentON Racing
« Reply #3 on: October 23, 2017, 03:26:48 AM »
Those forged piston's called for large clearances.....005 in.etc.You could probably run .003, .0035, the cast one's @ .002
BentON Racing Website
BentON Racing Facebook
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #4 on: October 23, 2017, 04:06:40 AM »
art made pistons for others too including actionfours
Offline smacd11
« Reply #5 on: October 23, 2017, 07:57:23 AM »
Thanks for the tip, I downloaded action fours 1979 catalog from satanicmechanic, pistons look exactly like the ones in the catalog.  Anyone have 1 spare piston kicking around so I can complete this set?
Offline Big Jay
    • CBRzone
« Reply #6 on: October 23, 2017, 01:39:48 PM »
The forged piston is an MTC.  The cast may be one of ours.
« Reply #7 on: October 23, 2017, 02:10:22 PM »
Jay, stock 350 +1mm or cut down crown?
Offline smacd11
« Reply #8 on: October 23, 2017, 02:25:23 PM »
Forged are definitely MTC - just noticed under the pin it says MTC ALCOA.  Are rings still available for these anywhere?
Offline Big Jay
    • CBRzone
« Reply #9 on: October 23, 2017, 03:06:02 PM »
Yes
Offline smacd11
« Reply #10 on: October 23, 2017, 03:21:06 PM »
Do you know a part number/supplier?
Thanks for your help.
Offline FuZZie
« Reply #11 on: October 23, 2017, 04:59:17 PM »
I can't take the suspense any more!
http://www.aperaceparts.com/
 :D
Offline smacd11
« Reply #12 on: October 23, 2017, 05:11:35 PM »
The only rings I see are for the wiseco and je pistons, neither of which will fit the MTC pistons. Wiseco oil rings for but the comp rings don't. I already have a set of those.
    • BentON Racing
« Reply #13 on: October 23, 2017, 05:38:11 PM »
Try these guys
Offline smacd11
« Reply #14 on: October 23, 2017, 05:42:32 PM »
Already sent them an email, nothing available. Must have discontinued them. From my investigating I may have to buy 2 sets to make them work, BPR650 (I think that's the number I found) should have comp rings that will fit. Just hoping to find a source for 1 set.
Offline cbr954
« Reply #15 on: October 23, 2017, 06:51:25 PM »
Get a hold of MTC, they found rings for my mtc 72mm pistons, they will know the ring dimensions and be able to send you in the direction of who can make them.
03 CBR954RR, 72 750 chopper(970cc
F2 head), 2017 CRF450R, 2001 CR250R, 72 CB500, 79 XR250, 04 CRF50,70's soon to be rebuilt cb750 drag bike.
Offline smacd11
« Reply #16 on: October 23, 2017, 07:12:42 PM »
Will do, thanks.
« Reply #17 on: October 23, 2017, 09:48:23 PM »
Not same rings as CB350 + 1mm?
I have 3 sets of 836, all have same ring sizes.
Forged RC 836 with teflon buttons, older cast RC and Action Fours cast marked Art. I reused the 3 piece oil rings from my forged RC on my 30 years later on eBay purchased RC cast with 1 piece oil rings.
Offline smacd11
« Reply #18 on: October 23, 2017, 10:33:48 PM »
Looks like CB350 rings would work but are as hard to get as the ones for these pistons.  The ones I located are from Bore-Tech PR650.
« Reply #19 on: October 24, 2017, 01:17:10 PM »
I looked for CB350 +1 65 mm rings for a while and found these
http://www.ebay.co.uk/itm/Honda-CB750-Piston-Rings-x4-sets-836cc-65mm-1969-1976-Oversize-rings-Big-Bore-/362023996060?hash=item544a4fca9c
Really low price and correct sizes for my pistons. Better than none.
Cruzinimage sells low cost piston sets that people use. I'll install 61mm pistons from them within a few days. All pistons were very similar in diameter and weight + all rings had correct en gaps, no need of filing ends. So cheap might work  ::)
Offline Big Jay
    • CBRzone
« Reply #20 on: October 24, 2017, 01:46:28 PM »
See if the ring groove width is the same for both pistons. If so,  CB350 twin S4 rings.
Offline smacd11
« Reply #21 on: January 13, 2018, 07:49:01 PM »
Now that it's a new year I thought I would revive this thread.  Just curious if anyone out there has 1 Action Fours 836cc piston kicking around - in the boxes of parts I acquired form the previous owner I can only find 3, and he has no idea what happened to the 4th and it would be nice to have a complete set.
The next question would be which would be the preferred piston, the MTC forged or the AF cast?  The cylinders I got with the MTC pistons have approx. .006- .007" clearance and the guy I got them from said he removed them because it smoked too much (I'm not surprised!).  I found one set of cylinders in my stash that are already bored that would give a final clearance of 0.002-0.003" with the MTC pistons.  I'm kind of leaning that way since I wont have to have another set of stock cylinders bored out.  From your guys' experience would that be adequate clearance for those forged pistons?  I know it would be too much for the cast ones.  MTC engineering got back to me saying the clearance for these pistons should be 0.001-0.002".  I won't be racing this bike - just trying to put together a fun bike to ride on the street with a bunch of parts I have gathered up.
Shawn
Offline gschuld
« Reply #22 on: January 13, 2018, 08:05:34 PM »
This should help. ;).   Ken Tipton seemed to prefer tighter tolerances than most for the forged piston sellers of the day.  Their pistons were also on the heavier side compared to some of the others at the time.
George
« Last Edit: January 13, 2018, 08:10:20 PM by gschuld »
Offline smacd11
« Reply #23 on: January 13, 2018, 08:16:31 PM »
Thanks for the info - that helps a lot.  I will have to do some more accurate measuring before I commit to this build.
Offline cbr954
« Reply #24 on: January 13, 2018, 08:31:26 PM »
MTC told me to go with .001" with my 72mm pistons from them and Jay told me I could go to .0015 no problem.
