Author Topic: 73-75 Denvers choppers CB750 period correct build thread  (Read 26539 times)
Offline lxcoupe89
Re: 73-75 Denvers choppers CB750 period correct build thread
« Reply #125 on: January 22, 2019, 05:34:47 AM »
These and a 1/16 npt tap might work  I have to look at a bowl..
It might, I don't think there is a lot of meat there if I remember right, I'm wondering if the overflow tube and the barb are 1 piece. If they are it'll be hard to add an elbow. I think I might just plug them.
« Reply #126 on: January 22, 2019, 09:54:52 AM »
They likely are , you tap the bottom, then use a 1/16 npt plug., or ream and push in a short pin
Then tap same thread  in the side  use  a 90 degree fitting.
 But.. I have to look at a bowl see how much meat holds the overflow tube.
 I wil, try to look at a bowl maybe later today,  or put up a pic.
