Author Topic: 73-75 Denvers choppers CB750 period correct build thread  (Read 26750 times)
Offline lxcoupe89
Re: 73-75 Denvers choppers CB750 period correct build thread
« Reply #75 on: March 07, 2018, 09:33:22 AM »
Here's a few pics of how the bike sits now
A dude at work says this one looks like it could have been a David Mann painting. lol I think he's right
Offline Desert-SOHC
  • It's old
« Reply #76 on: March 07, 2018, 04:46:01 PM »
Looking good!
90 F350 Lariat CS S/C Dually
90 S&S 11SC Cabover Camper
97 FLHTP (under construction)
11 Ranger S/C 2wd
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
« Reply #77 on: March 08, 2018, 04:08:19 AM »
do you have an angle finder?  could you measure the rake on this?  how long is the front end?  rear leg top to bottom?
Offline lxcoupe89
« Reply #78 on: March 08, 2018, 09:32:50 AM »
I checked it with an angle finder when i got it, it was about 50 degrees
i'll have to re measure  the springer i think it was 38-39". i think it worked out to 17-18" over.
Offline lxcoupe89
« Reply #79 on: March 09, 2018, 11:58:28 AM »
I measured the springer, with the new rockers and the springs tightened, it measured dead on 40" from the top of the bottom tree to the center of the axle
Offline lxcoupe89
  • Gusto mo titi ko?
    • project
« Reply #81 on: March 11, 2018, 03:44:24 PM »
You seen kj’s collection?
« Last Edit: March 11, 2018, 03:47:23 PM by Medyo Bastos »
Offline lxcoupe89
« Reply #82 on: March 12, 2018, 08:11:41 AM »
I didn't get to see it in person, but I saw pictures. I talked to him awhile back. I believe he sold most or all of the bikes he had. some nice bikes in that line up. I wish I could have seen them in person.
« Reply #83 on: March 12, 2018, 01:00:42 PM »
What's the info on KJ? He goes by something else doesn't he? I'm going to be traveling in the SW and would like to stop by.
Offline greenjeans
  • 1972 CB750K2
« Reply #84 on: March 13, 2018, 02:01:11 PM »
Man, what a cool build.  Can't wait to see this one finished.
Offline lxcoupe89
« Reply #85 on: March 14, 2018, 09:08:01 AM »
KayJohn I believe on Jockey Journal forum. Not sure what his username is if he is on this forum.
Offline lxcoupe89
« Reply #86 on: March 14, 2018, 09:08:44 AM »
Thanks, yeah Its been fun so far.
Offline lxcoupe89
« Reply #87 on: March 28, 2018, 09:08:28 AM »
Santee wiring Box - It took me a while to figure out how I wanted to try mounting all the stuff in the box. Here is what i came up with, Hopefully once I get it all wired up it looks clean and there isn't any electrical interference having all of the stuff so close together in a metal box.
Initial Concept
Flat Pattern sketch
Make Shift Break
Finished off the bend with a hammer and finesse
Offline lxcoupe89
« Reply #88 on: March 28, 2018, 09:21:21 AM »
Recently made the Chainguard. I used two aftermarket CB750 chain-guards I had. The Denver's chain-guards were made out of U channel that was bent. I considered doing that but chose to go this route.
After welding I Used a hammer to touch it up, I ended up turning it into a bananna and had a heck of a time trying to get it straight again, as it turns out I think i was stretching the steel on the flat faces but the corner was not, that caused the bananna shape. At one point I was tempted to scrap it because it looked pretty bad. I kept working with it though and finally got it pretty straight. It may not be good enough to re-chrome though, I'm not sure yet.
Offline lxcoupe89
« Reply #89 on: March 28, 2018, 09:30:39 AM »
Made the tag holder and taillight mount. I didn't like seeing the bulb socket sticking out the back of the taillight so made a cover for it.
Offline lxcoupe89
« Reply #90 on: March 28, 2018, 09:37:15 AM »
Finished up the sissybar. Added the mounts for the taillight and tag holder, welded up the new tab I added for the chain guard. The sissy bar is done just like the original denver's were as best I could anyway.
Offline lxcoupe89
« Reply #91 on: March 28, 2018, 09:38:05 AM »
Here is a pic of how the bike looks so far
  • Gusto mo titi ko?
    • project
« Reply #92 on: March 28, 2018, 04:30:59 PM »
coupe you can run an automotive ignition switch and ditch the starter solenoid.  that frees up a little room in the box.  youre making great progress, keep up the good work!
Offline lxcoupe89
« Reply #93 on: March 29, 2018, 08:02:08 AM »
Thanks. I'll check into that. I think because the current is so high there has to be a starter solenoid. I know Fords all have solenoids. Can you show me what kind of switch you mean?
  • Gusto mo titi ko?
    • project
« Reply #94 on: March 29, 2018, 05:47:19 PM »
The ones from Napa work. Don’t get the ones from autozone or checker auto for obvious reasons.
« Last Edit: March 29, 2018, 05:53:42 PM by Medyo Bastos »
« Reply #95 on: March 29, 2018, 06:16:05 PM »
 Does that eliminate solenoid, I never knew about that.
 I am trying to remember if the coils always went into those chrome boxes..?
Anyway if your coils are down there, you can run your plug wires thru the cylinders near  the center, it looks good... use 7mm  silicone wires.
« Last Edit: March 29, 2018, 06:19:26 PM by 754 »
  • Gusto mo titi ko?
    • project
« Reply #96 on: March 29, 2018, 06:50:03 PM »
I’ve used those switches for several years. I’ve run coils in the boxes too with the plug wires through the jugs.
Santee also made a coil box that mounts off the frame below the triple tree.
These are things more so found at HC.com
« Reply #97 on: March 29, 2018, 09:54:32 PM »
 Amen had a  coilbox that fit  under the neck as well.
Offline lxcoupe89
« Reply #98 on: March 30, 2018, 06:06:15 AM »
I've never see those switches before, That's good to know.
I started looking for one of the coil boxes you guys are talking about but I really wanted to try to get it all in the one box. If I had it to do over again I would have went with traditional  stock style coils rather than the dyna coils.
Offline lxcoupe89
« Reply #99 on: March 30, 2018, 06:12:50 AM »
My Santee box was already cut for the plug wires when I got it, I plan to clean up the shape of the hole a little bit to make it look a little better. I have dyna wires, I'll have to check but I think they are good wires. Thanks for the tips
