Author Topic: CB750 to GL1000 front end conversion *UPDATED* pics.  (Read 29990 times)
Offline eurban
Re: CB750 to GL1000 front end conversion *UPDATED* pics.
« Reply #50 on: April 23, 2007, 01:15:14 PM »
Jinx-
Wonderful work on the custom fork caps.  The stock steel GL pieces with their plastic caps are definitely in need of an appearance upgrade!
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #51 on: April 23, 2007, 01:32:07 PM »
Thanks for the compliment eurban; I was motivated by necessity more than anything else. The GL fork tubes were a freebie, but they were missing one of the caps and I had no luck finding one on eBay so just decided to make my own.
–Captain Horatio Hornblower
www.thehairynickel.com
Offline ic455
  • 750 K6
    • My Gallery
« Reply #52 on: April 27, 2007, 09:12:01 PM »
Ok, I searched "GL1000 fork swap" and wound up here ;D  Been seeing a bike sitting by side of road about 20 miles from my house for awhile.  Stopped today to see what it was and it's a '76 GL1000.  Looks to be complete, although mostly disassembled.  Still has giant front fairing, hard bags, king/queen seat, everything.  Guy wants 200 bucks for the lot.  I'm thinking about going after it with my trailer Saturday, as the first thought that came to me was "can I put this dual disc front end on my 750 K6?" ;D ;D  I guess by the info I see here the answer is yes?
Offline mkramer1121
« Reply #53 on: April 28, 2007, 08:14:27 AM »
Yes, it will be a direct bolt on replacement using the GL trees.  The trees are wider however, so you'll need to beef up your steering stops a bit.  Also, the forks are longer, they'll need to be pushed up through the tripple trees.
Offline Noel
« Reply #54 on: May 16, 2007, 07:25:07 PM »
Those fork caps are looking fantastic! I'll have to drop by soon and get an eyeful. Actually charged up the battery and rode around a little bit last week. Really ought to sort out the last of the CB500 project. Too many hobbies...
'73 CB500
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #55 on: May 20, 2007, 11:28:17 PM »
I guess this is turning into my "project" thread so here are some pics of an underseat battery box I made out of 1/16" aluminum to hold the undersized TR5-12C battery from www.batteryspec.com. I still need to make the two side pieces, but it feels pretty darn rigid as it sits right now. I'm hoping that with some flat black paint on the sides it will almost disappear from the final side view of the bike.
Offline xtalon
« Reply #56 on: May 21, 2007, 06:06:05 AM »
WOW!!!  That's impressive.  Not that I have the skill to do anything like that... so I don't need a step by step how-to, but I am curious how you made that?  It looks pressed.
--xTalon
1976 Honda CB750K
2006 Yamaha R6v
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #57 on: May 21, 2007, 08:27:00 AM »
Thanks X, but it's actually my first attempt at sheetmetal work. My neighbor gave me an old press brake/shear/slip roll machine. This is the type that bends the metal by pressing the metal down into a V-shaped groove which explains the scars on the metal about 1/4" on either side of each bend. Aside from that, it worked great. I made cardboard templates just like I've seen them do on OCC, then measured again and transferred the measurements over to the aluminum. Shear, shear, bend, bend...it's mostly just being careful and using common sense. Making curved pieces seems like it would be a whole 'nother deal though.  ;)
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #58 on: May 21, 2007, 09:41:07 AM »
          Boy Jinx, that IS impressive work! ;) Very nice indeed!  8) Sure makes me wonder what you'll be up to next? ??? :)  It's cool to see fabrication at work. Keep up the good work guy.
                                                      Later on, Bill :) ;)
Member # 1969
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #59 on: May 21, 2007, 11:16:56 AM »
Thanks for the compliment Bill, nice to hear.  :)
Now that I've got a bit of an idea how to bend the stuff, my next project is an oil tank made from brass sheet and brazed together. Gonna be tricky, but I think I can pull it off.
Offline Noel
« Reply #60 on: May 21, 2007, 10:22:09 PM »
The battery mod is going to be killer. What are you going to do with the rest of the electrics?
'73 CB500
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #61 on: May 22, 2007, 09:17:22 AM »
Thanks dude. The rest of the electrics are going to fit under the tank (I hope). Anything that doesn't will get stashed somewhere else...under the seat hump, in front of the coils, in the headlight, etc. I'm using a tank that has a bit more room underneath it than a stocker so my fingers are crossed.
