Author Topic: Caliper  (Read 2102 times)
Caliper
« on: October 28, 2017, 04:10:00 PM »
Looking for an underslung, opposed piston rear caliper. Must be something available/used during the 70's maybe 80's.
Any suggestions?
Offline slikwilli420
  • Master of Disaster
Re: Caliper
« Reply #1 on: October 28, 2017, 05:33:40 PM »
You can still find the grimeca ones used on the rear. See them on vintage flat track bikes. Not appreciably lighter than a front though. Not much else period comes to mind. If you can go more modern use a Brembo p32 off a Ducati monster. Light, readily available and cheap.  That's what I'm going to use.
Re: Caliper
« Reply #2 on: October 28, 2017, 06:37:21 PM »
The PM small caliper used in the 80,s weighs like 14 oz,  not sure if that would be enough braking they are far smaller than the Grimeca.
« Last Edit: October 28, 2017, 06:41:32 PM by 754 »
Offline Tintop
Re: Caliper
« Reply #3 on: October 29, 2017, 06:58:17 AM »
Be careful using the Grimeca, they have been out of production for a while and rebuild kits are very hard to find.
1980 CB750F (project)
77 CB550 Cafe build
550/750 Filter Thread
Sidecar Rebuild Thread
Re: Caliper
« Reply #4 on: October 29, 2017, 09:18:44 AM »
I've heard that, which is a bummer. If I cannot find a kit for my front when it needs it I'll upgrade to an AP unit. Doesn't give Brent many options to stay period.
Offline Medyo Bastos
  • Gusto mo titi ko?
    • project
Re: Caliper
« Reply #6 on: October 29, 2017, 11:56:46 AM »
You looking for front or rear? I have a few wrapped up under the bed
Offline Tintop
Re: Caliper
« Reply #7 on: October 29, 2017, 06:50:41 PM »
To do the last ones I used some Brembo seals, ebay pistons, and it took a couple of attempts to find a piston seal.  The Brembo is to thin.  Not saying they can't be rebuilt, just not off the shelf, next day parts availability.
77 CB550 Cafe build
Re: Caliper
« Reply #8 on: October 29, 2017, 08:00:56 PM »
Which Grimeca is hard to get kits for, the big caliper Or the smaller 41 mm type .
Re: Caliper
« Reply #10 on: October 30, 2017, 08:25:08 AM »
Thanks all.
That little Brembo should fit the bill and is lightweight. It probably uses the same pads I use on the front, parts & pads are easily available. I can always invert it after it's bled. I plan to talk to Mr. Morse about a proper sized master cyl.
Re: Caliper
« Reply #11 on: November 05, 2017, 09:25:08 PM »
 Sandy Kosman is now making new AP knockoffs... without the name on them.
Brand new less pads 139.00 plus shipping.
 SK Racing Products 707 799 7639
