Author Topic: 1975 CB550F0 Rear Light Change to LCD  (Read 894 times)
Offline kitesurfer805
« on: October 28, 2017, 06:14:03 PM »
I have a 1975 Honda CB550F with 21K miles.  I am trying to install a LCD light in my rear brake light and I am embarrassed to say I cannot get the light cover off.  I have removed the 4 screws that hold it on and it as far as I can tell it should come right off.  The only thing I can think of is it wedged in somehow.  I went so far as to start tapping with a rubber mallet on the side and cracked the lens a little.  I stopped at that point and decided to ask for help.  I really don't want to have to replace the cover so can anybody offer some help as to how to get the cover off before I end up breaking it.    In the pic you will see the 3 bolts removed and one partially installed which has since been removed.
Offline evinrude7
  • not a kung-fu
  • something to hüsker
Re: 1975 CB550F0 Rear Light Change to LCD
« Reply #1 on: October 28, 2017, 06:18:01 PM »
there may be a gasket that is stuck in there and sort of glued in after sitting for years.
cb750 k6 - ugly
Offline BomberMann650
  • Holy Cow! I'm a
  • Dr. Bovinestein iBa#80333
« Reply #2 on: October 28, 2017, 06:41:20 PM »
It has a gasket.
But LCD?  Doesn’t seem right to me.
Offline flatlander
« Reply #3 on: October 29, 2017, 12:06:49 AM »
yes it has a rubber gasket that may have turned to glue. maybe try prying around the edge with a small flathead screwdriver to loosen it up.
what's the plan with LCD? i'm with the bovine, haven't heard of one that suits this tail light.
« Reply #4 on: October 29, 2017, 09:12:23 AM »
I got it off.  It would appear that someone had actually glued it on with rubber contact cement, go figure.  I used a Sylvania super bright LED 1157R and it fit no problem and works great.  The only downside like others have mentioned in the license plate is now Red vs white.
  • Holy Cow! I'm a
« Reply #5 on: October 29, 2017, 09:13:21 AM »
I'm sure he might L-E-D  ;)
A programmable image Lcd tail light would be kind of neat.  Push a button and the finger shows on the display  ;D
Offline flatlander
« Reply #6 on: October 29, 2017, 11:50:40 AM »
ha ha you guys crack me up. there's a whole load of new potential there!
