Author Topic: Anyone mechanically minded care to help me out on this question?  (Read 1767 times)
Offline Chilli42
    • Google
Hi,
I wondered if any can help me with a quick question. Not very mechanically minded :-(
I have a Street Triple and was out riding today and was pulling you to a stop at a traffic light and must have forgot to change down. I was in 3rd when I stoped and went to change down and it wouldn’t shift into 2nd, pushed down on the shift level and just no clunk. This has happened before on this, and other bikes every now and then and I usually just carefully start to let out the clutch lever a tiny bit and pull it back in, that’s usually enough to jog something and let’s me the shift down.
I did the same this time and when I let the clutch out a tiny bit and heard a slight noise for just a second (pulled the clutch back in) like 2 cogs very slightly rubbing/skimming against each other, not grinding or crunching or anything. Since the transmission is a constant mesh and all cogs are connected all the time, what was rubbing against each other and would this have caused any harm?
Also, what is the best way to get out of a stuck gear like that?
Thanks in advance for your help?
Sent from my iPad using Tapatalk
Offline grcamna2
Re: Anyone mechanically minded care to help me out on this question?
« Reply #1 on: October 29, 2017, 12:15:27 AM »
I would guess that the teeth on the gears were not 100% aligned until you engaged the clutch again;try rolling the bike forward just an inch next time to see if that will align the trans. gear teeth,either that or your clutch is dragging and might need to be serviced.
Offline innovativems
    • Innovative MotoSports
« Reply #2 on: October 29, 2017, 04:57:44 AM »
Not sure if there is shift fork adjustment on the triumph but my Ducati would need the shift forks adjusted occasionally and could do this if it was bad
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
Offline calj737
  • I refuse...
« Reply #3 on: October 29, 2017, 05:43:31 AM »
Also, you can KILL the motor, operate the clutch lever, and then move the shifter and START the motor again. You should be able to rev the engine enough and feather the clutch to take off, even from 3rd. Once moving, a quick downshift to 2nd should be possible.
Offline Chilli42
    • Google
« Reply #4 on: October 29, 2017, 08:10:50 AM »
Thanks guys. Any possible damage or harm caused? It seemed only a slight skimming sound and was for a second or two.
Sent from my iPhone using Tapatalk Pro
Offline calj737
  • I refuse...
« Reply #5 on: October 29, 2017, 10:04:01 AM »
Unlikely.
Offline Kevin D
  • SE Michigan
« Reply #6 on: October 29, 2017, 12:53:16 PM »
stomping on the shifter not advised
71 CB750 K1
104,000 miles
Original Owner
———past———
70 SL100/125/150
70 Candy BlueGreen CB 750 K0
