Author Topic: adjustin 75 cb750 carbs running rich  (Read 2052 times)
Offline maestro
« on: October 29, 2017, 01:49:01 PM »
My 72 is running really rich. I can smell fuel strong at the exhaust. Also the exhaust smokes blue and smokes more when I whip the throttle. It backfires when I let off the throttle. I've got all air mix screw turned 1 1/8 turns out. This is where it idles best but it still idles just a little rough. Idle rpm at 1100. I pulled the spark plugs and all are identical, a bit wet and very dark colored. I cleaned them but this was without change in results. Here is a link to a video I uploaded. The bike is up to normal operating temperature here.
https://www.youtube.com/watch?v=DOIMajSwjrE
Offline Scott S
Re: adjustin 75 cb750 carbs running rich
« Reply #1 on: October 29, 2017, 02:10:14 PM »
 That looks like oil smoke. Unburned gas smoke is usually black. Oil burns blue or white.
'71 CB500 K0
'17 Triumph Street Scrambler
'81 Yamaha XS650
Offline maestro
« Reply #2 on: October 29, 2017, 06:19:47 PM »
I agree about the color however it smells strong of gasoline.
Offline CycleRanger
  • No comment about being an
« Reply #3 on: October 29, 2017, 06:32:09 PM »
Howdy, welcome!
Can you tell us a little bit about your bike and any work you've done to it?
How long have you had it? How many miles are on it?
Have you cleaned your carbs or checked the float heights or done a sync?
It may be running rich but it does look like you're burning a bit of oil too.
Offline el pachuco
« Reply #4 on: October 29, 2017, 11:52:11 PM »
remove the oil fill dipstick and smell inside. You may have fuel leaking into your crank case and thinning the oil. That will thin the oil enough to blow by the rings and have a very strong fuel smell. Are you turning your petcock to the off position when the bike is not in use?
Offline maestro
« Reply #5 on: October 30, 2017, 07:43:43 PM »
"Can you tell us a little bit about your bike and any work you've done to it?"
First off I mistyped in the title. It is registered as a 72 but if I order certain parts (like the reproduction seat) that are for a 72 they don't exactly fit. I had to modify the seat a bit to get it right. When I looked at the 71 seat it was a match. The bike was made in 71 per the tag but registered as a 72. So I really think its a 71 leftover and sold as a 72. Work I've done; Pamco electronic ignition, had the carbs synced and timing set last season. Took the bowls and needles off last week and they are spotless. Pulled the bowl and screen off the petcock and also spotless. Other than little cosmetics here and there, changing oil (which it is due for), drive chain, brake pads, etc. no other work done. As far as I can tell it is bone stock except the K&N reuseable air filter I put in.
I believe I acquired the bike in 2005 and it had 13000 miles on it. Now its at just over 19000 miles.
When I took the bike in for service last year I paid to have the carbs cleaned, synced and adjusted. Probably only put 500 miles or less on it since then. I supposed he did the float heights at that time. But no I have not checked the actual float heights. When I pulled the bowls I pulled the floats and needles and they were all spotless and needles moved freely and I submerged the floats and could not detect any leaks.
Now that you mention it... What prompted me to check on the bike this weekend is the fact that a couple of weeks ago I took it out for a ride. While at a friend's I cranked it and let it idle because it was running slightly rough on the way over. That is when I noticed the smoke and smell. When I went to my bike this weekend I stood it up off the kick stand to move it and a noticeable amount of gas came from the overflow hoses. This baffled me a bit. Then I noticed I had put the petcock in the reserve mode instead of off. I bet I had inadvertently been doing this for a while. DOH! I checked my dipstick the same day I was checking it out and now I remember the oil was a bit high but I figured maybe it was from me standing it up. I bet I have dumped fuel into the crankcase by leaving the fuel on reserve. Now I have thinned oil getting past the rings and this the oil smoke and the rich smell.
I'm out of town until Saturday but I will smell the dipstick. Bet its gasoline smelling. I'll change the oil and I bet it clears up. I'll post back. Thanks for posting. This got my head on straight I believe.
Offline CycleRanger
« Reply #6 on: October 30, 2017, 07:48:12 PM »
Yes, it sounds like you have had the carbs serviced recently enough so Pachuco is probably correct.
Let us know!  :D
Offline maestro
« Reply #7 on: November 10, 2017, 09:41:13 AM »
Changed the oil and filter last weekend. Cranked and ran still smelling rich. Smoking but not quite as bad. Oil smelled of gas again. I changed it again just now and am letting the bike warm up and will check it again. I may have to change the oil again one or two more times. This reminds me og a time about 25 years ago when I was young an inexperienced. My gf at the time had an 83 Civic. We decided to use one of those cans of engine flush and change the oil. Well it did indeed clean the crap out of the engine. Problem was the engine began smoking and burning oil afterwards. I guess you need some crud in there that actually builds up "sealing" power around parts of the engine. After about two weeks her car quit smoking all together, over the period of the two weeks, and quit using oil. I've probably cleaned the crap out of this engine with the gas/oil mixture. I bet once I get all the gas out of the oil and I run it a while, several rides, it will clear up on the smoking issue. I'll update.
