There have been many charging system post tracked back to the rotor itself on Cb650 SOHC4s. It has a wound rotor instead of the metal lump used on other SOHC4s. The heat and centrifugal force tend to damage the wire insulation in the rotor. It also has alternator slip ring brushes that are a wear failure point after long service.
I think when the alternator is in good condition though, it puts out better system power than other SOHC4s. I believe the rotor and brushes are in the $300-$400 range to refurbish.
No kick start on these. If your electrical system gets weak, you are pushing the bike. Or, staring at it with eyes of longing.
