Author Topic: CB550k starter motor install  (Read 641 times)
Offline gbal06
« on: October 30, 2017, 10:32:32 PM »
Is there any tricks to the install? I tried a couple of times and the spindle end of the starter doesn’t seemedine up with the hole in the crank case. I don’t want to start tweaking on the black wire untill I ask you guys. I read the manual and it doesn’t make mention. Thanks
Re: CB550k starter motor install
« Reply #1 on: October 31, 2017, 12:40:34 AM »
tweak the wire a little,you might need to turn the starter shaft into a new position to engage its mating gear.
Offline gbal06
« Reply #2 on: October 31, 2017, 09:46:42 AM »
Thanks Dave
