Author Topic: Lower Handlebars ?  (Read 9804 times)
Offline Dunk
Re: Lower Handlebars ?
« Reply #25 on: November 03, 2017, 05:39:21 AM »
The stock K1 bars are much shorter lower than newer bars. I like the K1 bars better.
https://www.davidsilverspares.com/CB750K1-FOUR-1971/part_188999/
« Last Edit: November 03, 2017, 06:00:03 AM by Dunk »
Offline Bankerdanny
  • Endeavor to persevere
« Reply #26 on: November 03, 2017, 10:57:21 AM »
I ran Euro bars on my 550K and put them on my 550F for my trip last August.
I just removed them last weekend and reinstalled M-bars and the Euro is going on to my 750F to replace the stock bars.
Offline danyo
« Reply #27 on: November 03, 2017, 03:39:38 PM »
Can you guys tell if those bars are from 400f? Got them with other parts and I'm not sure where they belong. Looks OEM, predrilled for control wires.
Sent from my SM-N900T using Tapatalk
Offline rddcw
« Reply #28 on: November 03, 2017, 05:33:09 PM »
Could be these   http://4into1.com/honda-cb400f-replica-handlebars-53100-377-000-1975-1976/
Or   http://4into1.com/honda-cb550f-replica-handlebars-53100-390-000-1975-1976/
Do some measurements and compare  :)
These CB 550 F Handlebars looking interesting too !
« Last Edit: November 03, 2017, 05:35:46 PM by rddcw »
Offline rddcw
« Reply #29 on: November 04, 2017, 04:43:20 AM »
ar - Stock Type ~ CB750K 1972
Add to Cart
Handlebar - Stock Type ~ CB750K 1972
Stock Type Handlebar for the CB750K (1972) - Chrome. Drilled for wires like the OEM type.
Width 28 1/4" - Rise 3" - Pullback 4" x 7/8"Dia.
Replaces OEM# 53100-341-000
Note: These Are Drilled For Wires
Part #: 25-0127
US$46.95 ea
I wonder if these Bars are the one's that Dunk tried to described from David Silver's web-site even though they are stated 72' ?  Sold thru Vintage CB750 .
« Last Edit: November 04, 2017, 04:45:45 AM by rddcw »
Offline rddcw
« Reply #30 on: November 05, 2017, 01:44:28 PM »
Does anyone know who makes a reproduction 72' K-model Handlebar ?
1972 K-model: 53100-341-000
Width- 28.25 inches    Rise- 3 inches     Pullback- 4 inches
« Last Edit: November 05, 2017, 01:52:22 PM by rddcw »
Offline Dunk
« Reply #31 on: November 05, 2017, 02:46:56 PM »
K1...............
Offline Dunk
« Reply #32 on: November 05, 2017, 02:47:44 PM »
K5.............
Offline rddcw
« Reply #33 on: November 05, 2017, 03:44:46 PM »
Dunk,  This 72' appears to have much lower bars than the one you picture ?  So, I'm wondering if it's the K2 that has the lower bars ?
« Last Edit: November 05, 2017, 04:07:16 PM by rddcw »
Offline evanphi
  • Apparently I'm an
  • Rhonda the Basket Case
« Reply #34 on: November 06, 2017, 05:46:58 AM »
Are you using the Road Low or Road "Ultra" Low ?  The clamping area width is about a 1/2" wider with the ultra bar .
And what about the throttle and clutch cable ?
I use the "Low" model. I kept my throttle and clutch cables the same. No adverse bending. They just swoop a bit more.
--Evan
1975 CB750K "Rhonda"
Offline Dunk
« Reply #35 on: November 06, 2017, 06:45:27 AM »
K1 is definitely lower than K5. It's possible K2 is lower, though that is a foreign market bike and there were some differences in bars, lighting, brackets, etc. between different markets so that may be a factor as well.
Offline rddcw
« Reply #36 on: November 06, 2017, 05:09:54 PM »
Just got an email back from David Silver's.  His 71' Honda CB 750 K1 Handlebars Part # 53100-300-610P  measure :  720mm ( 28.34" )  width
        60mm ( 2.36" ) rise
        60mm ( 2.36" ) pullback
Definitely appears to be a lot lower than the 71' you picture on your K1 ?  So who knows ?
I think if a person is looking for  "drilled" bars, then Part # 53100-300-610P ( 71' CB 750 K1  David Silvers )
        Part # 53100-390-000   ( 75-76' CB 550 F  4into1  )
        Part # 53100-341-000  ( 72' CB 750 K2  Vintage CB750  )
        Part # 53100-377-000  or EMGO 23-93142  ( 75-76' CB 400 F  4into1  )
Anyway,  that's what I came with.   Drilled bars are definitely more expensive than non, but what ever a person is looking for  :)
Offline rddcw
« Reply #37 on: November 06, 2017, 05:22:59 PM »
Evan,  You mentioned that you are using the Renthal "low" handlebars. Looking at their spec's, the clamp area width measures 105mm ( 4.13" ) which appears too narrow for the handlebar clamps on the 750's ?  Can you enlighten me on that concern ?
Did you run your control cables on the outside of the bars since their not pre-drilled ?
« Last Edit: November 06, 2017, 05:59:49 PM by rddcw »
Offline evanphi
  • Apparently I'm an
« Reply #38 on: November 07, 2017, 04:49:44 AM »
Yes I ran them outside. They fit perfectly.
--Evan
Offline Dunk
« Reply #39 on: November 07, 2017, 06:01:03 AM »
        60mm ( 2.36" ) rise
Interesting, I'll have to measure mine. I suspect the ones I'm using on my K1 are 53100-300-000
Offline DV Red Herring
  • Army RETIRED
« Reply #40 on: November 08, 2017, 08:16:05 AM »
I use the Norman Hyde "M" bars.
Offline BassHog
« Reply #41 on: November 08, 2017, 10:05:07 AM »
These are 400f bars
Offline rddcw
« Reply #42 on: November 08, 2017, 11:07:58 AM »
BassHog,  How's the comfort on the 400F bars ?  I have re-upholstered my stock seat to a very low profile seat. It now measures 2" thick.  Being short in height, I'm now wondering how a low profile handlebar will feel ?
And Evan,  How do your Rental bars feel to you ?
Offline BassHog
« Reply #43 on: November 08, 2017, 11:22:14 AM »
I like the height on them, but I'm also 6 foot tall. I have euro bars on my CB500 and the main difference I notice between the 400f bars and the euro bars is the width, the 400f bars are a bit narrower.
Here is a better pic of the bars.
« Last Edit: November 08, 2017, 11:26:17 AM by BassHog »
Offline rddcw
« Reply #44 on: November 08, 2017, 04:49:34 PM »
 Dunk,  Did you ever get a chance to measure your bars on your K1 ?  They appear to have more than a 3" rise ?
« Last Edit: November 09, 2017, 07:10:44 AM by rddcw »
Offline evanphi
  • Apparently I'm an
« Reply #45 on: November 09, 2017, 09:14:54 AM »
The Renthals are the best I've tried. I also used the Euro bars from vintagecb750 (with holes), and I just find the renthals dampen much more vibration, and have less pullback. More like a motocross bar... but not. Make sure you use a grip glue (I used Shoe-Goo) on the Left grip. The anodized Al is pretty slick, even with the knurling.
--Evan
Offline rddcw
« Reply #46 on: November 10, 2017, 08:14:35 AM »
Went ahead and order David Silver's Euro Handlebar  # 53100-300-610P .  Had them in stock . People their ( Matt ) extremely Nice and Helpful.  I appreciate "All" that responded to this Post which helped greatly in making my decision.
They have the shorter Euro cables in stock. Hopefully I don't need them but will address that issue if needed .
Offline przjohn
« Reply #47 on: November 10, 2017, 08:31:30 AM »
I used the David Silver Low Bars on a 750F restoration and also used the 400F throttle cables and brake line, everything fit up perfect. The only cable I had to modify was the clutch.
Offline rddcw
« Reply #48 on: November 10, 2017, 09:02:48 AM »
I see that 4into1 has a pair of throttle cables for the CB400F about half the cost  :)  4into1 gives the measurements of these cables, so once I receive the bars and install them, I'll be able to see how much shorter cables I'll need. As far as the clutch cable, which is probably more crucial,  I'll try to outsource that one. DSS does have that cable.
