Author Topic: Alternative performance pistons & squish  (Read 13241 times)
Re: Alternative performance pistons & squish
« Reply #50 on: September 25, 2018, 11:54:08 AM »
sorry captain i miss understood that , not the first time that has happened .
maybe a little bit too advanced in thought, need to retard a little...  8) there are various technical terms and ways of explaining
I did not follow that either. thanks to you we are more that know
Offline Old Scrambler
« Reply #51 on: October 01, 2018, 07:14:48 AM »
Regarding my C.B.R. motor......We retarded the ignition from stock setting and FOUND 5-HP when ONLY tuning for peak power at WFO
Dennis in Wisconsin
'63 CL72 Project(s)
'66 CL77 Red
'67 Triumph T100C
'73 750K3 Owned since New
'77 750F2 Cafe Project
2020 ROYAL ENFIELD Himalayan
Offline Ilja
« Reply #52 on: October 06, 2018, 03:17:21 PM »
I tuned the ignition of my turbo cb750 with an ignitech module with MAP sensor (and GPZ stator+rotor), and just followed the torque curve of the dyno a bit. After peak torque I gradually increased another 2-3 degrees.
And the whole thing is boost retarded from 0-7 degrees at 0 to 15psi.
Works nicely and is also not expensive.  8)
