Author Topic: Two Shifters?  (Read 2554 times)
Offline Lumbee
    • My pics...
Two Shifters?
« on: November 03, 2017, 01:14:34 PM »
OK, I feel like a complete tool asking this, but here it goes. I spent some time looking online with no luck. I have a 750a I am just getting back on the road. Its a chopper, so the engine is in a custom frame. Actually, a couple of questions...
What are both the shifters for? I know one is high/low, how about the other?
Does anyone have a close-up pic of the configuration of the shifters and how each is installed? I have two shifters; one like just like on a regular 5 speed 750, and the other is a bit shorter and stubby. I see the two shafts coming from the left side. Which goes front, and which back? I'd like to see a pic of them both installed because I can't see how you get the set screw in the shorter one and still clear the engine cover.
Finally, I'd like to get the one or more the indicator lights working, specifically the neutral and oil light. I suspect these are the Red wire and the other is Blue w/Yellow Stripe coming from the engine (these two are separate from the main bundle). Is this right?
Thanks in advance.
"I'm not a welder, but I play one on HondaChopper.com"
Offline jukku
  • Happy with my Hondamatic
Re: Two Shifters?
« Reply #1 on: November 03, 2017, 01:42:10 PM »
http://manuals.sohc4.net/cb750a/service_manual/SM750A.pdf
Page 2-11  gear shifting lever and neutral keeping lever.
Offline Lumbee
    • My pics...
Re: Two Shifters?
« Reply #2 on: November 03, 2017, 04:32:32 PM »
To easy! All else fails, read the manual right?  ::)
I see that the other shaft next to the shifter is the neutral thing-a-ma-bob that connects to the center stand. So if nothings connected to it does that mean its in drive, or I it the other way around (nothing connected it stays in neutral?
The wiring doesn’t quite line up with what I am seeing come out of the motor, but I will do some probing with tester and see what I can decipher.
Offline jukku
Offline underdog
Re: Two Shifters?
« Reply #4 on: November 09, 2017, 10:27:56 PM »
  I've kinda got the same problem. What do we actually do with the neutral lever? Make a small hand lever or a foot lever or? I need to keep the neutral safety switch, but I can't have it getting bumped or vibrated into neutral. I'm open to any good ideas too.
Offline Lumbee
    • My pics...
Re: Two Shifters?
« Reply #5 on: November 10, 2017, 03:49:30 AM »
I am treating it just like a gear shift on any other bike. It's not so sensitive that it needs to be treated any differently.
« Last Edit: November 11, 2017, 07:03:13 AM by Lumbee »
Offline jonnycakes
Re: Two Shifters?
« Reply #6 on: November 11, 2017, 12:05:54 AM »
I used an early and a late model shifter so they clear each other..
'Matic-Fanatic
Offline scunny
  • don't call me expert
Re: Two Shifters?
« Reply #7 on: November 11, 2017, 12:25:44 AM »
That's a great looking bike
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline Lumbee
    • My pics...
Re: Two Shifters?
« Reply #8 on: November 12, 2017, 06:35:26 AM »
Here is a pic of mine. Runs and stops. Still need to wire up the charging, and would also like to have indicator lights for neutral/hi/low.
Offline underdog
Re: Two Shifters?
« Reply #9 on: November 12, 2017, 05:08:03 PM »
 Thanks for the pic Jonnycakes. The auto's seem to get photographed most from the right side. Yours turned out pretty nice!  :)
Offline jonnycakes
Re: Two Shifters?
« Reply #10 on: November 12, 2017, 05:16:25 PM »
With no clutch or oil bag, Hondamatics make great chopper.....
'Matic-Fanatic
