Author Topic: CB750K vs CB750A Points plate and advance unit  (Read 601 times)
Offline Yamahawk
  • IGOR!Come here IGOR! ...Yesss
  • 1971 Honda CB750 Four K1
    • Kingdom Run Biker Church and Outreach
« on: November 04, 2017, 04:02:31 AM »
Hi All,
    Is there a difference in the advance mechanism or points plate between a 1973 CB750K and a 1976 CB750A model? I noticed that the CB750K had a 300 on the points plate, and the CB750A has 333 on it. Are they interchangeable? I helped my friend Pat install a CB750A points and advance plate into a 1973 CB750K, to replace a burnt up Dyna ignition. Haven't had the chance to fire it up yet, but static timed the points late yesterday, and will fire it up today. We kept the green 3 ohm Dyna coils, as they should work fine with the points.
Charlie
1971 CB750K1 (newest bike), 1996 Royal Enfield 500 Bullet (therapy bike), 1981 Yamaha XV920RH, 2006 Kawasaki Concours (retirement bike), 1975 Yamaha RD350 (race bike), 1989 Honda VTR250 Interceptor (race bike), 1986 Kawasaki EX250 Ninja (race bike in progress), 1985 Honda Elite CH250, 1973 Yamaha GT1 80cc, 1974 Yamaha DT360 project bike.
The Only Thing Necessary for Evil to Triumph, is for Good Men to do Nothing.
Edmund Burke
All Things work together for good, for those who love God and are the Called according to His purpose.
Romans 8:28
Though He slay me, Yet will I trust Him...
Job 13:15
will you trust Him...?
Offline CycleRanger
  • No comment about being an
Re: CB750K vs CB750A Points plate and advance unit
« Reply #1 on: November 04, 2017, 09:15:47 AM »
The "333" points plate is for a CB350F, although dimensionally it is probably the same as the 750 plates.
The 750A should use the same points plate as the regular 750/550's.
Consensus seems to be that the points plates are the same and Honda had different part numbers for inventory purposes.
The advance mechanism for the 750A may be marked 333.
(PN: 30220-333-004)
I would expect the advance assembly for the 750A to be unique due to the automatic transmission regardless of the markings.
Honda changed the profile of the advancer cams over the years on the 750K's without changing the part numbers.
Hondaman has a whole write-up about this somewhere here on the forums.
You can get a copy of the 750K parts list here:
http://www.honda4fun.com/materiale-documentazione-tecnica/parts-list/parts-list-cb750
Offline Yamahawk
« Reply #2 on: November 05, 2017, 04:04:52 AM »
Thanks, CycleRanger,
    The advance mechanism is marked 333, and from what I have learned here and the SOHC forum in the UK, I am going to see how it runs. It should be ok, as the CB750A had a slightly later advance, and that's ok too. They look identical, but I believe the springs are stiffer on the 333 advance plate.
Charlie
Edmund Burke
Romans 8:28
Job 13:15
