Author Topic: CB350F full engine rebuild  (Read 13234 times)
Offline camshaft1991
« on: November 13, 2017, 12:59:05 PM »
I’m starting this post as a complete rebuild of a CB350F engine and will stick to it until everything is done.
Most of the rebuild has been done already. The only problem I’ve had was: smoke, and idling on 3 cylinders. (Exhaust #4 warm to touch at idle)
The previous crankcase was damaged and replaced in a failed attempt to remove a broken tensioner bolt, but the rest of the components were salvaged. The replacement case was put together with new o-rings, gaskets, and solid bearings for the crankshaft and connecting rods. A fully rebuilt 400f starter clutch replaced the previous destroyed starter clutch. The oil pump has new gaskets and o-rings. The clutch is fully rebuilt with new plates and springs. The pistons are .5 OS. Camshaft is new along with refurbished rockers, and new timing chain components (except the timing cams on the crank and camshaft). On top of this I️ have a good set of carbs that can hold a reasonable vacuum when operating.
I’ve rebuilt the engine to almost new, however, I️ have had the same problems now as I️ did before the rebuild: excessive continuous smoke, and idling on 3 cylinder.
The previous cylinder head was rebuild with new exhaust valves and refurbished intake valves. I️ ground them in by hand until I️ couldn’t hear the grinding compound anymore.
When the bike was ready to turn over, it ran the same as before only it had a significant loss of power, maxing at 3500 RPMs. I️ disassembled the engine two more times and once experimented with an improper copper gasket and then with a NOS gasket. Both failed but the copper gasket leaked oil. The cylinder head was bead and chemical blasted before the engine rebuild. I️ washed the head out with 8 gallons of distilled water, but I️ did degrease it with a hot detergent bath prior to sending it off for blasting.
I️ brought it to a shop and they told me I️ had to replace my cylinder head. With everything done so far, it made since. The spark advancer springs, and the electrical components related to engine firing time had been replaced as well.
With all that being said this is where I️ am now, a NOS CB350F cylinder head
It looks great but nothing is perfect after being shelved for over 40 years.
This piece is complete but it has some shelf wear on it and some.. blemishes that were never taken care of since it was made. The cylinder head base has some scratches on it that can be felt with a fingernail and there is no threads where the exhaust studs go in. I️ know where I️ can get that work done, as for the rest, could I️ correct this myself?
In these pictures there is: shelf wear, excess metal overhanging, scuffed flat surfaces, and leftover metal shavings when this block was cut. The contact surfaces on both sides of the head are flat.
What can I️ take away or make better without compromising anything? I️ have an air Dremel/ pneumatic rotary tool, various polishing and grinding attachments and an Emory Rouge kit. I️f I️ had someone do light deck work to my cylinder head base could they deck the top of it after I’m done grinding ridged edges?
I’ll keep to this thread after I️ get this cylinder head put together and resume engine build
Re: CB350F full engine rebuild
« Reply #1 on: November 13, 2017, 01:04:37 PM »
 Sounds like your thread needs to get put over to the 'project shop' area if its going to be an ongoing thing.  Good Luck on it,another member here has done a lot of 350F work lately also,
« Reply #2 on: November 13, 2017, 02:25:01 PM »
I️ asked the guys at the shop about replacing the valve guides and they said that might fix it. Hearing that wasn’t too assuring. Also there would have to be more labor and new parts put into what ‘might’ work. My cylinder jugs were already milled with my previous head, would I️ need to do that again?
My head leaked when I️ experiment with copper but not too much with the NOS gasket, only when it was retorqued. When I️ relieved torque from the head oil seeped out from the front left corner. After retorquing oil would build on the front left corner a little.  It was acting like a worn cylinder head gasket but less leakage. And it probably would have gotten worse with time.
So with the “beauty” marks should I️ go with a hand file?
whats a good liquid to check for leakage?
Can I️ check the valve guides’ tolerances with an OEM Honda shop book and a vernier caliper?
And I’ll be sure to repost this to the “projects” section
Offline markreimer
« Reply #3 on: November 13, 2017, 05:44:17 PM »
Very curious how this pans out. I rebuilt my 350 top end three times now and it’s smoked like a chimney each time. First did a hone and rings, then a big bore, and then disassembled and rebuilt the big bore after crazy oil burning issues. There seem to be a lot of threads for failed 350F engine builds and not many successes.
« Reply #4 on: November 13, 2017, 08:31:35 PM »
I know right? It's daunting over me, but hopefully a fresh cylinder head will do the trick. By the way, how do move an entire post over to a different section? Someone told me how to do it a year or two ago but I cant seem find that post either.
« Reply #5 on: November 14, 2017, 09:40:11 AM »
Just before i had the guys at the shop take the bike apart, I turned over the engine. They saw the smoke and each took turns grabbing exhaust #4. A few days later they gave me call when they finally had the time too look into my top end. They told me the the obvious: there is no combustion in the 4th chamber, but they couldn't figure out what was wrong. That it was spooked me.
Any issue the bike had before they were able to diagnose and fix, or I could if it was the carbs. They could confirm if I was right about something faulty or redirect me to what was really the issue at hand. They actually encourage me to do much of the work myself in order to save money on labor, but there shop isn't exactly one of those co-op shops for anyone to come and go. I think thats what they are called. I've come to an understanding after rebuilding my bike so many times that I need to hand it off to someone who has rebuilt 70s SOHC4s.
The gasket only started leaking when I relieved torque to the head for retorquing. It was like the oil was still under pressure and it came out as soon as the gasket was not under torque. I believe the oil that spilled out while I was retorquing prevented the gasket from sealing completely. I followed the retorque instructions by the Honda manual and used a digital torque wrench. Yes, I could of done something wrong but that is why I am having a shop take over, because I didn't have a second opinion or someone more knowledgable on hand. Not saying anything bad about the forum but it helps having someone actually there.
I think I will get a hold of Nills @Restocycle. The only thing I truly feel comfortable doing aesthetically to the engine is polishing and clear coating.
Offline innovativems
    • Innovative MotoSports
« Reply #6 on: November 14, 2017, 09:55:49 AM »
I would send your head to mrieck on here.  He is the best person to go through the head and make sure it's perfect before you seal it back up.
2007 KTM 990 adv
2003 Honda RC51
2000 Yamaha YSR50
1978 Honda Express
1975 Honda CB400f
1974 Honda CB350f
1974 Kawi H2
1974 Honda CB550f
1971 Kawi h1
1973 Kawi h1
1974 gt 550
1974 gt550
« Reply #7 on: November 15, 2017, 01:02:05 AM »
The problem with cylinder number 4 was always problem from the beginning even before the tear down. My first tear down was because of a broken tensioner bolt. If you are talking about valve gap I've always been on top of that ever since i had a valve tappet go loose while riding.. I had to replace the camshaft a rocker and refurbished the rest of the rockers.
In theory if knock out blasting and milling with Nils and Mike (and assume mike can do valve work too for the sake of simplicity), could I polish the block with the valves in the block? If took the precautions of covering the orifices to the combustion chambers with tape and plastic cellophane/visqueen, could I safely polish without risking getting reside inside the chambers? I'm asking if anyone has polished a cylinder head with the valves in before.
« Last Edit: November 15, 2017, 01:09:53 AM by camshaft1991 »
Offline flatlander
« Reply #8 on: November 15, 2017, 01:38:36 AM »
here ya go. no problem polishing covered up this way:
« Reply #9 on: November 15, 2017, 07:34:48 AM »
awesome to both of ya!
« Last Edit: November 15, 2017, 07:43:06 AM by camshaft1991 »
« Reply #10 on: May 22, 2018, 10:47:43 AM »
Alright I’m back at it. I mistakenly used the wrong o-rings for my carb fuel linkage, Hydrogenated Nitrile (HNBR), instead of Nitrile (Buna-N) o-rings. Long story short they started to dissolve and leak. So I instead of going with Buna-N I bought some Viton o-rings. Doesn’t hurt to get something slightly better.
Anyways when splitting my carbs I noticed this.
Aside from leaking, the carbs worked fine. This slide has got to go. I picked at the inside of the carb cylinder with my fingernail and found no rough edge to the wall. The bottom of the cylinder is a little bit chewed up in the last picture. I have an extra set of scrap carbs I can cannibalize a slide from, but I’m worried about the bottom of that carb cylinder. Will it mangle up the next slide I put in? Aside from replacing it is there anyway to fix this? Also I can’t use the corresponding carb on my other set because I believe it can’t hold a vacuum
« Reply #11 on: May 22, 2018, 09:12:44 PM »
I replaced the damaged slide with one from my other carb set and fitted the viton o-rings for my fuel connectors.
They were a little tighter than Buna-N
o-rings but the fuel connectors fit snug. The replacement slide now glides quietly in the carb cylinder. Though it was slightly damaged at the bottom too, but superficial.
The return springs for these small four cylinder carb racks are wound pretty tight. I believe the slides get damaged from force of the return spring. So instead of letting go of the throttle, return it to idle by hand.
Here’s a page giving the just on several
O-rings. Pay no attention FFKM that’s overkill.  Probably made with infused depleted uranium and gold...
Stay away from HNBR O-Rings. The US standard is green. The color standards are different in other countries
My bike is still at a shop but I would hope my carbs would not leak anymore. I’ll leave them to tune it so I can get a good reference on how it should be tuned. Also I’m tired of lugging half a motorcycle across town via truck and trailer.
« Reply #12 on: June 01, 2018, 11:27:00 AM »
So far I have another 3 weeks before the bike shop can even look at my bike again and all that is left is to fit the carbs and boots on. The carbs are already assembled along with the engine but I think I can take over from here.
 Everything should be said and done. All I need to do is check the carbs for balance and retorque my head after a heat cycle. I read that the modern composite gasket does not need much retorque like vintage gaskets. So instead of backing out half a turn you check the torque values and tighten anything under what it should be. Is this true? Also should I do so with the engine still warm?
« Reply #13 on: June 02, 2018, 11:32:59 AM »
Great so a gasket can be retorqued without a heat cycle. That’s a relief. The shop I went to assembled my engine and being a motorcycle shop I would assume they did retorqued it.
« Reply #14 on: June 04, 2018, 12:15:19 PM »
Good well now I have another tid bit problem, mounting the exhaust. The aftermarket pipes that came with the bike were pretty much plug and play, you could probably install them upside down if you didn’t know what your doing. I decided to go with 4into4 and they are quite a handful. Each pipe and muffler is a sing piece so no wiggle room. I’ve managed to install pipes 1,3, and 4 but 2 is catching on the kickstand. I even removed the kick stand and now it’s catching the mounting point for the kickstand on the frame.
And I tried staking washers in this last picture but not even close
« Last Edit: June 04, 2018, 12:17:37 PM by camshaft1991 »
Offline carnivorous chicken
« Reply #15 on: June 04, 2018, 12:48:10 PM »
Pipe #2 is supposed to go in between the side stand and the oil pan, not on the outside of the side stand... The side stand is between pipes 1 and 2.
« Reply #16 on: June 04, 2018, 12:49:02 PM »
Or I could try riding like this lol
« Reply #17 on: June 04, 2018, 12:53:02 PM »
Ok I’ll try that but the spring for the kick stand would catch on pipe 1
« Reply #18 on: June 04, 2018, 01:05:44 PM »
Shouldn't.
If you google image 350F you'll see how the pipes mount, e.g.:
https://www.motorcycleclassics.com/classic-japanese-motorcycles/honda-cb350f-zmwz12jfzbea
There's some spce in between #1 and #2 pipes.
« Reply #19 on: June 04, 2018, 01:06:33 PM »
Although I also have to admit I kind of like the overhead #2 pipe. Could catch on.
« Reply #20 on: June 04, 2018, 01:41:28 PM »
Fits but was more of a pain than pipes 3&4 but I still have trust issues with that kickstand, may be warped, so I’ll leave it off for now
I’m going to take them off after tuning because I need to do some engine cleaning and polishing. My head seems a little out of place next to the rest of my engine
Before I take them off I think I’ll try to make my pipes look like an X-Wing from star wars lol
« Reply #21 on: June 04, 2018, 01:43:55 PM »
The kickstand mount on these (but more so on 400Fs in my experience) can be a weak spot -- people sitting on the bike on its side stand can definitely bend it or even tear the mount off.
« Reply #22 on: June 04, 2018, 08:02:45 PM »
If it is the kickstand I can always try find another.
So the bike runs but the carb floats are locked up so I have to nurse it gas. Also my clutch only works when it is set as tight as can be. Any looser, it doesn’t work. But the bike runs clean and doesn’t burn anymore oil . I tried to tune it for 30 min before a rain came in and I put the tank on to cover everything and I noticed I didn’t have my filter or air box lid after opening my seat up. Maybe tuning will go better the second tome around
« Reply #23 on: June 05, 2018, 06:29:30 AM »
Help me out with this one. All of your floats are stuck -- up? or down? how are you feeding it gas? Regardless -- pull them, clean them, make sure everything is work ing as it should, check float height, verify with clear tube, and make sure the floats are opeating as they should. Sometimes the tang will bind on the float valve.
Do you have a carb sync tool? That's got to be part of the equation as well.
Sounds like you're making progress regardless.
« Reply #24 on: June 05, 2018, 04:01:37 PM »
Yeah I have a carb synch with vacuum gauges but I just want to have engine run in full range. Currently it’s limited to 6500 rpm. I’m Running ethanol free gas through it but I don’t think the floats will unstick anytime soon. The floats are stuck in the open/down position so no control on the amount of fuel. So I  give it a little gas bit by bit until it drips from the overflow. Then shut off the fuel after a few drips. It’s not safe but I got a full extinguisher at hand. I also only smoke when I drink so I try not to drink when I work on my bike ;)
It could be the floats locked up or the float needles themselves.
