Author Topic: Changing unit for a 76 cb750a  (Read 1504 times)
Offline Supersportguy
« on: November 14, 2017, 06:16:28 AM »
What is the function of the changing unit on a 76 750A. Thanks.
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: Changing unit for a 76 cb750a
« Reply #1 on: November 14, 2017, 06:53:29 AM »
It uses inputs from the change switch and speed unit to control the gear indicator, neutral light, and the the idle solenoid.
Sorry, I was typing this when you were posting.
....Paul
« Reply #2 on: November 14, 2017, 08:13:26 AM »
How does the idle solenoid work? How does it sence its idling and when does it shut off.
Offline 05c50
  • 05c50
« Reply #3 on: November 14, 2017, 09:43:45 AM »
On the 76 model, it uses an input from the change switch to indicate if it's in or out of gear. When it's in gear, the solenoid is energized and allows vacuum to pass through the solenoid and apply vacuum to the servo that raises the idle. On the 77/78 models, it works the same except there's an input from the speedometer so that the vacuum is only applied when going slow (below 15 mph, I think). That helps to keep the high idle from fighting with the brakes when you try to slow down from high speeds.
....Paul
