Author Topic: Alternatives to rusty finned exhaust spigot clamps on 750k bikes  (Read 4971 times)
Offline Zenfiddy78
Re: Alternatives to rusty finned exhaust spigot clamps on 750k bikes
« Reply #25 on: November 20, 2017, 10:48:06 AM »
Evaporust is probably the safest rust remover out there- I've done 2 fuel tanks w/great results. It's also eco-friendly. just pour it down the drain when it's no longer effective.
« Last Edit: November 20, 2017, 10:50:56 AM by Zenfiddy78 »
Offline Zenfiddy78
« Reply #26 on: November 21, 2017, 05:41:06 AM »
On the subject of ceramic coating- make sure that they will blast & coat the system inside and out. Most better shops do so
and that often accounts for the higher price...
Offline Dunk
« Reply #27 on: November 21, 2017, 05:57:26 AM »
I had a pair of big block headers ceramic coated once (Jet Hot), with relatively little use and the car stored in a garage, not driven in winter, the coating has failed and is flaking off, holes rusted through. I had these coated when new  inside and out for longevity. They rusted out far quicker after coated when new than anything I've never coated or even painted and just drove year round even in salt and snow. I'll stick to rattle can high temp paint.
Offline calj737
  • I refuse...
« Reply #28 on: November 21, 2017, 07:21:39 AM »
That's an indictment of the applicator, not the application. If they had been properly coated, there would be no exposure to air of the mild steel allowing corrosion. I would strongly suspect the internal application was improperly applied and there was not a sufficient prep of the surface with an abrasive, thereby preventing full and proper adhesion of the coating.
Offline Zenfiddy78
« Reply #29 on: November 21, 2017, 10:54:30 AM »
Thanks CalJ for saying what I was thinking ;)
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
« Reply #30 on: November 23, 2017, 08:07:10 PM »
My coating is 16 years old,no problems.
