Author Topic: carb float numbers - just curious why, any relevance to performance/operation  (Read 1420 times)
Offline shoemanII
  • just another bike nut
hi all,
noticed my carb floats ( well 3 out of 4) are numbered thusly:
carb #1 - 100 is embossed on the float
carb #2 - not numbered
carb #3 - 127 is embossed on the float
carb #4 - 95 is embossed on the float
is this the float weight in grams/grains or something?  i put 'em back where i found them and set at 14.5mm, but am curious.  thanks.
bobp
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
I have my 627B (CB500) carbs apart right no - no markings at all on the floats.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Offline heffay
it is called the installation rating... it is an approximated number on the number of installations that the particular float can withstand before cracks and leaks occur.
 ::) whistling merrily ::)
Offline kghost
Thought it was the employee number of the person who assembled that carb.......... ::)
Stranger in a strange land
kettlesd
Mine has no numbers either - i just looked as they're on the bench. Maybe the employee needed too scratch down a girls number while on the line!!!!!   ;D
