SOHC/4 Owners Club Forums
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
News:
SOHC/4 Shop
Home
Help
Login
Register
Donate
Tech Forums
High Performance and Racing Forum
(Moderators:
Sam Green Racing
mlinder
Topic:
rod length
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: rod length (Read 2050 times)
bwaller
Really Old Timer ...
rod length
on:
December 04, 2017, 07:28:36 PM »
Looking for CB650 rod length, anyone? 115mm thanks scunny...case closed.
Last Edit: December 05, 2017, 04:07:36 AM by bwaller
Logged
turboguzzi
Old Timer
Re: rod length
Reply #1 on:
December 05, 2017, 12:48:46 PM »
while we are at it, the length of 500/500s? mine are already back in the engine
Logged
bwaller
Re: rod length
Reply #2 on:
December 05, 2017, 05:54:47 PM »
106.9mm
Logged
RAFster122s
I feel like a really really
SOHC4 member # 2605
Re: rod length
Reply #3 on:
December 05, 2017, 09:38:56 PM »
That would make quite the stroke in a cb550. Are the cylinders of the 650 taller too?
They would give you some room to play if you made your own head.
Are you building a bike for the street or the track?
Logged
turboguzzi
Old Timer
Re: rod length
Reply #4 on:
December 06, 2017, 04:34:23 AM »
ok, tnxs brent
just in case it helps you with your planning, GSXR1000 rods (35mm bearing, 15mm pin) are 111 or 112, two models available.
Logged
bwaller
Re: rod length
Reply #5 on:
December 06, 2017, 04:37:25 AM »
Good info, I'd forgotten about that rod. Thx TG.
Where can I zero in on this info, as in model year?
Last Edit: December 06, 2017, 04:42:48 AM by bwaller
Logged
turboguzzi
Old Timer
Re: rod length
Reply #6 on:
December 06, 2017, 02:39:06 PM »
Suzuki GSXR1000 09-16
Stock rod length is 112mm
Suzuki GSXR1000 05-08
Stock rod length is 111mm
who knows, might let you use one of those pitbike pistons that have really low compression heights
Last Edit: December 06, 2017, 02:41:20 PM by turboguzzi
Logged
bwaller
Re: rod length
Reply #7 on:
December 06, 2017, 04:55:48 PM »
Both those mentioned use a 15mm pin?
Ending up with a rod/stroke ratio of 2.2:1 is aok. Maybe an alloy base spacer.
Logged
turboguzzi
Old Timer
Re: rod length
Reply #8 on:
December 07, 2017, 10:18:41 AM »
yes, both 15
they have bushed small ends so opens options to other size pins
gerrit once wrote that after bush removal one is 17 ID the other 18mm
http://forums.sohc4.net/index.php/topic,63228.msg1102758.html#msg1102758
Logged
Print
Pages: [
1
Go Up
« previous
next »
Tech Forums
(Moderators:
Sam Green Racing
mlinder
Topic:
rod length
