Author Topic: Advancing the 41a, in 836,for more bottom?  (Read 8670 times)
Offline 1976cb750f836
  • 76 cb750f, 836, 78 wheels
« on: December 05, 2017, 09:15:48 AM »
76,F1,stock carbs,pods,4 into 1,electronic ign,836 Wisco kit, and a 341a
WebCAm
Valve Lift: .335/.335
Duration: 275° / 275°
Duration @ 0.050":242° / 239°
Bike is flat below 4k,rich needle,lean needle,doesn't matter ,it's Sluggish!
4k to 6.5 k it's OK, will lug most riding done Hear!
At 6.5k she comes on hard,still pulling at 9.5k when I Shift!
I'm older now and don't really care bout the best ET?
Would advancing the cam a bit help?
And how much?
I have to replace those leaky pucks under the cam anyway,so why not advance it a bit while I'm in their?
Someone done th is with good results?
Any ideas welcome?
Re: Advancing the 41a, in 836,for more bottom?
« Reply #1 on: December 05, 2017, 11:58:30 AM »
Did you try richer needles?
The other thread about needle setting where you wrote "I went up again to 132s, removed needle shim,now in 4th from bottom."
132 might be OK, needle 4:th from bottom definitely not since that is 2:nd from top which is 1 step leaner than stock (middle) using air box that work as a choke.
Change needles to 4:th from top as the pic show. Notice the difference :)
Below clip at stock position, arrows where you should try on yours and feel that the force will be with you 8)
Check this
http://www.hondachopper.com/garage/carb_info/tuning101/carb_tips.html
When carbs OK you might reconsider your cam timing hopefully done before with an adjusted cam sprocket and equal lobe centers (IN vs EX) as often recommended on these bikes.
« Last Edit: December 05, 2017, 12:28:29 PM by PeWe »
« Reply #2 on: December 05, 2017, 01:53:48 PM »
Did you time the cam with your build? That cam has pretty low lobe center #'s, and..as PEWE said...the cam is split equal.
« Reply #3 on: December 05, 2017, 09:45:13 PM »
If timing cam is a new thing, lobe center method need an explanation.
Below from the must read site Satanic mechanic.
http://satanicmechanic.org/cams.shtml
CALCULATE THE LOBE CENTER
Assemble the top end but leave off the valve cover. Set up a dial indicator on a intake valve, set it to zero with the valve closed. Rotate the crank until the valve is .040" (1 mm) open. Note the reading from the degree wheel (OPEN). Further rotate the crank until it is 1mm from closing. Note the reading at the degree wheel as well (CLOSE). Lobe center for the intake is:
OPEN - CLOSE   +90
             2
Do the same for the exhaust valve. Lobe center for the exhaust is:
CLOSE - OPEN   +90
            2
If these values differ from what the cam manufacturer says, adjust the cam sprocket until the LCs match the specs. If you do not have specs from the manufacturer, adjust the cam to be symmetric, i.e. identical lobe centers for intake and exhaust.
Overlap is also explained here and good to know what it is. Some cams have in and ex valves open at the same time during rather long time leaking compression. These cams need higher CR pistons to maintain the compression and power. There are cams that have relatively short overlap since the duration is shorter, but lift is higher so more fuel mix can be delivered.
« Reply #4 on: December 06, 2017, 05:07:40 AM »
When I built the 836, I just slid the cam in,did not degree it.
I understand how to I was just excited about riding the bike.
I've degreed v8 cams before.
I might be wrong on the cam number, I thought it was the 2nd up from Stock?
It was recomended by a bike shop?
I'll get the number off cam when I attack the pucks.
Before I tear down. I'll try your needle suggestion and go 2nd from bottom?
Bike has always benn lazy up to 4k, since cam Install?
132s might be OK? Should I go up More?
They were only slightly better than 130s?
Thanks
High Temps hear in East TN now in 40s.
Don't want to get it too rich, then do it all over again in spring?
Offline slikwilli420
  • Master of Disaster
« Reply #5 on: December 06, 2017, 06:40:45 AM »
Doesn't matter what cam number, all should be and will benefit from, careful degreeing.
« Reply #6 on: December 06, 2017, 09:58:17 AM »
Yes, verify needles before tearing it down. Set clip as the photo I attached earlier, no washer under clip on these CB750 stock carbs. setting
 If the problem is as I think based on your threads, you'll be much happier.
Main might be OK as is.
Cam timing can be done after carbs. It's a good idea to measure how it open and close, in as ex. Maybe you must have an adjustable sprocket if timing is off. Most likely.
Running lash will show the reality. You measure and time cam with the recommended valve lash. Maybe 0.004 / 0.005) (0.10mm IN/ 0.15mm EX).
Measure with 0 lash (tighten the valve adj screw until the dial indicator start  to move to overcome the play in rockers etc) is to verify the cam card.
With actual lash you can adjust better if the valve train has different play, in vs ex.
Important to double check afterwards if this is something new. Easy to make mistake and set chain one tooth wrong or have the slack on front side. Rotate without plugs and measure again after some crank rotations.
One more thing. The advancer unit has a play on the crank shaft. Youl'l see it before tighten the 10mm nut. I noticed on my engine that turning the advancer to left side of the play, opposite of crank rotation match with real TDC. I have done an alternative mark on case that match advancer set max to the right, same as crank rotation. About 2mm at the right of crank index mark. This for ignition too so all marks line up correctly. T, F and advance marks on 1:4/2:3. ( I verified TDC with screwdriver thru plug hole first time, dial indicator before assemble the head and finally a Piston stop (APE).
The upper dead center is in the middle of the flat area when piston does not move up-down, but crank does.
« Last Edit: December 06, 2017, 09:05:37 PM by PeWe »
Offline turboguzzi
« Reply #7 on: December 06, 2017, 02:35:53 PM »
back to your original question, there's nothing wrong in advancing the cam to try get more oomph. nothing holly about symmetrical lobe centerss, plenty of bikes run asymmetrical. after you time it to say 2-3 degs, make sure to check the inlet clearance as it will get closer to the piston now.
« Reply #8 on: December 07, 2017, 03:02:14 PM »
Thanks for the honda chopper Link!
Needles are set, I also jb welded the air screw holes as per Link!
Rear wheel painted and on.
Going to test ride before I change out the front wheel.
Hope to test tomorow,hope u r right bout needles?
And do I understand the jb welded screw correctly, it makes it richer?
Thanks all!
« Reply #9 on: December 08, 2017, 02:17:48 PM »
Starts and revs good in shop, snow hear today,  I might get to test ride tomorrow.
« Reply #10 on: December 09, 2017, 05:58:32 AM »
Ride carefully on cold roads. I'm curious about the result even if I "know" ;)
« Reply #11 on: December 09, 2017, 12:51:06 PM »
OK Mr, I know, u were right sir!
Kinda it is much improved ,above 3k.
3k to 4k still  doesn't pull hard? But way better than before.
And I know get a rich, dah,dah,dah, when backing off to just above idle while causing 4k to 6k.
Think I need to go back to 3rd. Clip?
And it's only 40 hear today,I let it idle bout 10 min, then only rode bout 5 mile,would probably get worse with longer ride, in higher Temps?
Thanks.
« Reply #12 on: December 09, 2017, 01:55:19 PM »
Just above idle is not the needles. Your carbs are clean, pilot circuit, airjet not clogged? Choke devices opens completely?
Adjust the air screws. I should remove airscrews with springs and spray carb cleaner inside just for sure. Set them to 1/2 turn out from bottomed, then ride bike for a while so its really warm, bring a screwdriver with you and adjust air screws 1/8 steps out until it cannot be better that way.  Area 1/2- 1 1/2 turn out.
My CB750K6 with 836cc, cam, ported head, pods, 4-1 must have clip as I showed, 4:th grove from top.
I have had carbs that sounded like too lean but it was too rich with some bangs when closing the throttles while riding on lower speeds.
Next is to time the cam, it might be way too late.
« Last Edit: December 09, 2017, 01:57:45 PM by PeWe »
« Reply #13 on: December 10, 2017, 06:21:05 AM »
Carbs are clean. Chokes open.
I just did the jb mod to the screws.
It idles well anywhere from 1/2 turn out to 1-1/2 Out?
Best at 1 turn out,where it is now.
So I need to go leaner on the Screw? To 1.5 out?
I might try to ride again today, sun is out should get to mid40s by 2.
Thanks.
And I wasn't really looking forward to changing the needles Again?
Hope the screws oestrogen it.
« Reply #14 on: December 23, 2017, 06:22:16 AM »
Christmas shopping done Yesterday!
And so it Begins?
Got the frame section out and cables and wires out of way.
Hope to check where my cam degree is today and find out which cam I Have?
I've benn reading honda man faq, and am considering some timing Mods?
I'll post cam Id when I get some numbers?
Hope I can find my degree wheel?
« Reply #15 on: December 23, 2017, 07:59:08 AM »
Cam marked. WF3
                12 03
What cam do I have?
Springs must be upgrade, I don't remember?
White paint on ENDS?
« Reply #16 on: December 23, 2017, 08:18:09 AM »
The white paint made it fast to identify (when being manufactured) which end of the spring goes up.
« Reply #17 on: December 23, 2017, 10:23:49 AM »
OK, I'll bite - white up or down?
« Reply #18 on: December 23, 2017, 10:53:46 AM »
Found my old cam box, it's a 63a Web cam?
Their site has a card.
Mine was retarded.
So should I set it according to the card? Or advance 3-5 Degree?
I have a adjustable sprocket.
Since mine was retarded I. Tempted to set up as per card unless u all have some advice?
Thanks
Offline TurboD
« Reply #19 on: December 23, 2017, 11:06:54 AM »
The 63a may not give that great of a bottom end, might try advancing it or go a little smaller.
« Reply #20 on: December 23, 2017, 12:50:32 PM »
How much can I safely advance?
It was on 19deg btdc intake open @.050
Now on 23deg btdc.
Should I go more?
Don't want to slap a valve?
« Reply #21 on: December 23, 2017, 01:16:38 PM »
When does it close IN? It can depend how you measure and you'll get other numbers.
Best if you have all numbers of IN open vs close and EX open vs close. This will verify how the cam is set and your method measuring.
IN open and EX closing at similar numbers according to CycleX cam data of CX-3 (63A)
Same with IN close vs EX open.
Upon those possible to advance around 3 degrees.
Offline TurboD
« Reply #22 on: December 23, 2017, 01:22:28 PM »
General rule of thumb is about 4 degrees, any more and you should look for a different cam.
When it comes to advancing a cam, in most cases you actually reduce the chance of slapping a valve.
« Reply #23 on: December 24, 2017, 06:48:53 AM »
Cycle x, opens intake. @ 27 degree.  Btdc. Vs Web  19 Degree?
Mine is set on 25btdc. It's going back together.
Why different ?
I probably needed a smaller cam?
It does really kick hard above 6500rpm.
I'll live with it  however it is.ant buying anot her cam.
It's pretty easy to advance, might play with that more this summer?
Just got a keep it mostly above 4k, and that really ant no problem.
Also going to mess with the advancers, according to honda man, with premium fuel I can add some
Total .
Thanks
« Reply #24 on: December 24, 2017, 07:53:41 AM »
Numbers can differ due to different lift. Running lash or 0 lash another thing giving other numbers.
Thats why you need to  check both IN and EX.
